Question about Philips Magnavox MT1905B 19" TV
I have a MAGNAVOX mode MT1905B101 television that all of a sudden stopped working completely besides a high pitched buzzing sound that seems to come from the circuit board.Can someone help
    New Friend:
Nesesito el diagrama del magnavox : modelo :mt 1905B101
Posted on Mar 17, 2014
4 Suggested Answers
  • 81 Answers
SOURCE: Sound does not work in television mode but has white noise in DVD mode
is there a switch on the back of the set?
Posted on Dec 13, 2006
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
SOURCE: philips 7 year old 32inch cuts off while a high
IF PICTURE PULLS ON RIGHT ADJUST BRIGHTNESS AND AND TINT UNTIL SCREEN SHOW FULLY AROUND PICTURE
Posted on Apr 23, 2009
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Squealing sound on magnavox tv
if a high pitched whine or buzz it is likely coming from the power supply board.
May 15, 2012 | Philips Magnavox 42MF521D/37 Television
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
There is a constatnt high pitch buzzing noise that will not stop, there is no volume coming from the set, just th buzzing.
Sounds like theres a blown resistor on the sound board. When a resistor goes out you get a buzz through the speakers. Most t.v.'s also go into protection mode and shut off after a few secconds. You can take it to a t.v. repair shop. It wont cost as much as it would to buy a new t.v. and they usally warranty their work.
Jun 11, 2011 | LG 47LE5500 TV
Picture ok but loss of sound with high pitched buzz
Power board have problems.Take the tv aparts put some super glues on all around the transformers.Will help lower the buzz alots or stop it completely.
Feb 17, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
Magnavox E10839 has no picture and a high pitch buzzing sound
that seems to be an issue with your color wheel, it's starting to go out, beofre you replace it you need to verify if you have a gol or silver bearing, because if you don't get the right one, it will not work on your tv, since they have a different mechanism, but just make sure whihc one it is and you'll be fine :)
Jul 16, 2009 | Philips Televison & Video
TV HAS HIGH PITCH SOUNDS
most likely the HOT high voltage transformer is squeling
good luck
please mark the post with a fixya
Feb 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
Philips Magnavox MT1905B 19" TV Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
