Question about Freezers
Kenmore Freezer Issue Model 253-28432800
Control Panel goes blank. Unplug and plug back in and control panel comes back on. Should I worry?
  • keary shaw Mar 14, 2013
    kenmore 253 28432800 will not freeze...everything else works
  • 306 Answers
SOURCE: Loud shreaking sound coming from Kenmore Frost Freezer.
The fan behind the molding is hitting some ice build up and causing the sound. Sounds like the timer for the defrost isn't working. Try to turn off the unit for few hours or take off the molding in the freezer compartment and remove the ice build up with hair dryer.
Posted on Nov 23, 2008
Bat1956
  • 585 Answers
SOURCE: Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Posted on Jun 28, 2009
SOURCE: I have a frigidaire upright
OK, this is a failed controller board, any E4* is Power supply & Controller Board, probably caused by a power spike.You need to get the unit looked at to see if it is able to be repaired, and if parts are available. If you wish to try and repair this yourself, you must get a service manual, to do so, and to be able to order parts.
Posted on Apr 06, 2010
SOURCE: My Kenmore Upright Freezer Model 25326432100 flashed "ER."
My freezer was purchased in February, 2004. It is a self defrosting freezer but ice has started forming along the bottom shelf and back wall. Also, after cleaning the freezer the other day it has stopped clycing. The freezer will stop running only if I turn it down to the #1 setting and then it will not come back on. If I turn it up to a higher setting the compressor will not stop running. It ran for over 24 hours and would not cycle unless I turned it off or set it at the #1 setting. When I unplugged it and pulled it away from the wall, there was a green water spot the size of a dinner plate underneath the freezer. Help!! Very Unhappy this freezer is only 6 years old. S in Phila.
Posted on Sep 29, 2010
  • 11800 Answers
SOURCE: Door alarm light is on
The open door alarm is triggered by the small switch that also triggers the internal lighting. This is easy to test: open the door and press the switch - on a normal one the light should go off.
This is the switch
http://www.bizrate.com/refrigerator-accessories/oid1852839097.html
And here is in the parts manual page 4 part 14
ftp://ftp.electrolux-na.com/prodinfo_pdf/stcloud/5995552030.pdf
Posted on Jun 04, 2011
Frigidaire Upright freezer the temp indicator light will go blank and the freezer will stop cooling. You can unplug unit wait a bit and plug back in and it will will work for a while
I would guess the control panel is failing, but due to the cost of the part have a technician come out and confirm that is the issue. You can also go to www.partsdirect.com and email the forum
Sep 21, 2016 | Frigidaire Freezers
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
I have a 2007 model 253.264 upright Kenmore self-defrosting freezer. The control panel on the front door stopped working. No temperature reading and no way to adjust controls. The freezer is still
I have one out in the yard that is doing the very same thing. Works good but the door display is out. I looked underneath and all of the wires seem to be connected. The main control board is on the bottom as well. The battery is also new. You must have a broken wire between that control and the main board below. I imagine it has something to do the the connector that goes through the door.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 21, 2012 | Kenmore 13.7 cu. ft. / 388 liter Upright...
May 31, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
We have a Kenmore freezer chest...lights come on but doesnt freeze model#253.9135381 serial #s409256481
first,have you defrosted the frzr recently?they must be defrosted manually. take the 2 screws holding the side panel on and see if you hear the compressor humming/running. if you do. then the problem is in the sealed syetem. they should to come w/a 5yr. parts & labor warrenty but it looks like your frzr was build in the 1990's...
tip: if you think it's your cold control.you could unplug unit and use a wire,jump out the cold control.
Jul 16, 2009 | Freezers
Freezer has frost in back- frig not coolling
You have a defrost parts issue.
Unplug the fridge. Remove the back freezer panel and check the defrost heater and defrost thermostat.
Without a model number I can not tell you where the defrost timer is.
Mar 04, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
159 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
