Question about Pioneer SD-532HD5 53" Rear Projection Television
Off Screen Picture
Hi received my sd-532hd5 from my brother-in-law. When I set it up in my house it seemed to be working fine. However I noticed that the picture seems to be chopped off at either side. For instance... The channel logo is only half there and looks like if I only had another inch of screen I could see everything.
    President:
  • 3,130 Answers
There is a width problem. There could be a control inside to control this but the TV should not change so drastically. There is most likely a problem in the width circuit.. This is a high voltage circuit, and is very dangerous to tinker or experiment around inside of. Your best bet would be to call an Authorized Pioneer repair shop and have them have a look at the set. Good Luck
Posted on Jul 14, 2007
How do I get rid of just a blue screen?
It means for whatever reason the set is seeing no signal---could be a glitch--unplug set for a while and plug back so set may reset.
Also see if set on right input or set to tuner etc.
Check the simple things first before you panic,
Call up the menu and see if some setting got changed by accident or set is on video input when should be on one for the antenna etc.
May 27, 2012 | Dynex DX-L42-10A 42 in. LCD TV
My wife was cleaning around our Pioneer sd-532hd5 tv and she moved the tv to clean behind it. When the did, the color went awry. The sound and video is ok, just the color was affected. We have checked the...
now in the front of your tv you will see a weird piece of wood that looks like it doesent belong now its a piece of wood in the front of your tv sicured by a few screws and 2 dowels and inside you will see 2 circut bourds infront of you and a few more behind them , you will also see some connections to the botom of the projectors themselves , now you need to look to your left side and on your left you will see a little black or white casing with what looks to be 6 screws on it , but there not screws there the adjustments for your tv now just fiddle with those 6 screws til you can find your favorite color or setting and close it back up and ENJOY!!!!
Jan 18, 2011 | Pioneer SD-532HD5 53" Rear Projection...
My ps3 was working fine four days ago. I took it to my brother-in-laws two nights ago and hooked it up. We played it on his tv with an xbox hdmi cord and it was fine. I took it home and plugged it up to...
Ok you must be using a a/v cable at your house? And the hdmi cable at your brother in laws? If this is the problem its not the xbox hdmi cable. It doesnt matter all hdmi cables work the same. Its your settings. You need to hold you power button down and it should come on and beep twice then release it and a settings menu should pop up if it doesnt hold the power button down until it comes on and shuts off then hold the power button down again until it beeps twice. Hope this helps.
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
How much is this television worth. I bought a house and the owner wants to sale the tv to me.
if the picture looks really sharp and there is no 3-d effect on the screen. it is worth at least 250 to 300 bucks!
Larry Dillon
Aug 16, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Alinement of blue cross with red and yellow.
you will need to call someone in to realign the picture...
Feb 16, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Picture is to big it won't fit the screen.
You have a pincushion correction problem.This is not an easy problem to troubleshoot.Even as a technician I find that schematics are usally needed to correct these problems.I reccomend that this unit need to be checked by a qualified service technician.I can give you a ballpark figure of cost of repair of any where between $185.00-$325.00.Good luck.
Feb 09, 2009 | Pioneer SD-532HD5 53" Rear Projection...
My Pioneer 55 inch screen tv SD-P5553 has a solid black horizonta
This sounds like a picture mode issue. You maybe in a ZOOM mode. Try adjusting your set to FULL mode. If you are using a Sat receiver or cable box, some of these may have picture viewing mode as well, wich may need to be set in FULL or NORMAL viewing mode.
Good Luck!
Jan 18, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer SD-532HD5 - Picture Bowed on sides only on 1080I
The problem you are describing is known as a pincushoin problem. I'm a bit surprized that you only see it on the 1080i signal though. I've inquired at my Pioneer contact about this and will update this soon.
Stay tuned...
Dan
Jan 07, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-532HD5 53" Rear Projection Television Logo
59 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
