Question about Liebherr KES4260 Refrigerator
Fridge is freezing up most on the first shelf
Fridge compartment is freezing food it seems to be worse ont the first shelf above the draws any ideas?
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: hi,i have a liebherr fridge
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Posted on Sep 17, 2011
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
Why is water leaking into cool (deli) drawer?
Hi,have you got a drain at the back of the fridge just above the veg draw,if yes is there eney food above that that is tuching the back wall of the fridge above the veg tray,if so then the water that runs down the back wall will be going onto the food that it tuches and into the veg draw,hope this was some help,all the best.
Sep 16, 2015 | Refrigerators
Fridge partly freezing at top and bottom , middle staying neutral, why?
Check your evaporator fan motor also make sure there is no obstructions such as plastic bags blocking air flow.
Aug 02, 2017 | LG Refrigerators
THE FRIDGE SECTION IS FREEZING , AFTER WE HAD THE FREEZER REPAIRED
more than likey a provisions compartment fan ,(fridge compartment) symptoms include temprature stratifcation( where product freezes in lower part of refrigerator eg: crisper draws and top shelf warmer....
fan may appear to be functioning but broken wire may cause intermittent operation ..you can test these fans remove fan ...and test with square 9 volt battery or 12volt d.c supply....i hope this could be of use
ozzie fridge tech...;)
May 21, 2010 | Fisher and Paykel Active Smart E522B...
I have an Caloric GFS207- 1L 01. before the winter came i had to turn down the freezer one number because it was to cold. now my problem is in my fresh food top self next to the box thing(damper maybe?)...
Yes - there is a cold air damper.
This regulates the cool air flow from the freezer to keep the fridge cool.
If there is condensation - i would suggest checking the door seal for warpage, tears or other abnormalities allowing hunid room air into the fridge.
Thanks
Feb 16, 2010 | Refrigerators
Water collects, runs alot, food freezes
Sounds like the defrost timer may be out of whack. Is the temp control turned all the way up?
Are the coils clean? Are the door seals sealing?
Are the penguins still working when you close the door.
Hope these help,
Matt
Sep 14, 2009 | Refrigerators
Freezing in refrigerator
Inside the fresh food compartment on top left there is something called an air baffle. It runs between the freezer and fresh food compartment and its purpose is to electrically control the amount of cold air coming from the freezer. Sometimes they freeze open and will not close. So you may need to turn off the refrigerator during the time you examine it. Look for ice blocking the movement of the baffle damper. Sometimes just one time clearing the problem is all you need to fix it. Let me know what you find and if you are able to get it going again, Thanks, Sea Breeze
May 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
My frdge compartment is freezing
I really need more information. Like exact model number of said refrigerator. Here are some good tips. There may be a vent that leads to the freezer, if so close it. Second question is place a thermoeter on the top shelf in a glass of water for 4 hours, what is the temp. Do the same thing on the shelf that is freexing. If the tempatrues are equal turn up the tempature again. If not the circulation in the compartment is blocked. Make sure the the back of the carptmen has a gap to let air circulate vertically. Modern refriderators use air circulation to help reduce energy costs from compressors overworking.
Thanks PJ
Dec 01, 2008 | Refrigerators
Liebherr KES4260 Refrigerator Logo
22 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
