Question about Dell Inspiron 1501 Notebook
Dell Inspiron 1501
I have a weird problem when I turn on my laptop. It won't load past the boot page that says "Dell" really big in the middle and "Bios version 2.3.0" and at the very bottom it says"Entering Setup..." but it never enters setup, it just stays on that screen so I press the Escape button and get to a screen with codes of ram and whatnot and it says
Press to enter SETUP.
Press to enter Boot Menu.
  • 2 more comments
  • coreyv521 Jan 25, 2009
    f2 and f12 make it say entering setup and boot menu but it doesnt go anywhere. hitting escape brings up a black and white computer diagnostic but again f2 and f12 go nowhere.
    it gets stuck and never makes it to the boot menu
  • Anonymous Jan 26, 2009
    i would download the newer bios but i can't even get on the internet on the laptop... it will not start up all the way so i can't even download anything onto it
  • Azz
    Azz May 11, 2010
    When you get to the screen that says push F12 for boot menu, push F12 and select the hard drive. Does the pc then boot ok?
  • 55 Answers
Sounds like your bios may be corrupted, and there's a newer version available so its always worth updating especially if your getting problems. Go to this link and follow the instructions to flash your system bios, its an easy procedure.
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R169537&SystemID=INS_PNT_1501&servicetag=&os=WW1&osl=en&deviceid=13120&devlib=0&typecnt=0&vercnt=7&catid=-1&impid=-1&formatcnt=1&libid=1&fileid=230865
It should solve your problem.
Let me know how you get on, or if you need anymore help.
Posted on Jan 26, 2009
    Novelist:
  • 126 Answers
The very fisrt thing what u can try is that try and log into the computer into the safe mode or alos with the last know good configuration and then check it out the computer should work fine and then if still it says so then try and do the system restore and still if doesnt work what u can do is that repair the computer from the boot disk of os and then do the chkdsk /r on the set up screen fro the disk and then it will definately work.....god luck
Posted on Jan 25, 2009
Inspiron 1501 screen won't come turn on
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 11, 2012 | Dell Inspiron 1501 Notebook
Screen won't turn on
this is going to sound kinda weird but take the RAM memory chips out, now get a #2 pencil and gently rub the eraser on the gold contac's of the RAM memory chips. be careful not to go through the gold of the contac.
Mar 03, 2012 | Dell Inspiron 1501 Notebook
Power up laptop dell 1501 ,stays on until you logg on then after log on and programs load all power is lost
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 15, 2012 | Dell Inspiron 1501 Laptop
My dell inspiron 1501 has a error 0xc0000011 windows failed to load because the system registry file is missing or corrupt also would not load any cd
Go into your bios. Make sure your cd drive is the FIRST BOOT DEVICE. Then put in your windows disc and do a startup repair.
Mar 21, 2011 | Dell Inspiron 1501 Notebook
Go into your bios and make sure that your cd drive is the FIRST BOOT device. Then load the dvd and run a startup repair.
Mar 20, 2011 | Dell Inspiron 1501 Notebook
Boots improperly
try this...clean ur registry....
use Tuneup Utility
get it from my site Download page
www.sureshayyar.110mb.com
Dec 31, 2009 | Dell Inspiron 1501 Notebook
MY INSPIRON 1501 LAPTOP WONT TURN ON. ITS STARTS
Please follow these instruction to predict the possible errors,
Upon powering on the laptop, press and release many time the F8 button of your laptop until this window appear... Select the highligted in yellow... Post the error codes you can see on your screen for the next troubleshooting tip...
Oct 21, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 will not boot with battery or adapter
Take the battery out and try with AC only, if no change, then you will likely need a motherboard replacement
Jun 04, 2009 | Dell Inspiron 1501 PC Notebook
Blue Screen of death.
You might try removing the Hard Drive from the machin and slaving it on your other machine. Then running a chkdsk in the command prompt or norton disk utilities. If either fails, backup your data on other machin and reinstall.
Jan 26, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 will not charge
open thebattery and refix it after clear dust from its slots.
also change adapter of same output.
if still problems then u have to purchase new battery.
Jan 07, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
104 people viewed this question
Alun Cox
