Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
My Bissell 7920 pvs tube is split and I need to replace any one have any instructions how to do it!!!
I need some instructions of how to remove the old tube and put a new tube on
  • Official Brand Answer
  • 315 Answers
Hey, sorry to hear you're having a problem with your machine. You may want to a qualified technician at one of our Authorized Service Centers assist you with your machine.
Here's quick link to locating one in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Posted on Jan 18, 2013
reddevil6
  • 1673 Answers
SOURCE: Bex Bissell Pro Heat 7920-E
Remove the cap for the flow indicator, then there 6 screws to remove to take off the top, before removing the top, turn the smart mix valve to about the half way point so the piston won't fall off. When you are ready to re-install the top cover, just before pushing it all of the way down, turn the smart mix valve to the water only setting, then push it into place, re-install the screws and the flow indicator parts.
Posted on May 28, 2008
  • 3 Answers
SOURCE: NEED TUBE DIAGRAM FOR PROHEAT 7920
Hi There!
Here is a PDF link for a Bissell Service Center Repair Guide. Hope it helps! Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Posted on Dec 01, 2008
  • 126 Answers
SOURCE: need a user manual for a bissell proheat pro-tech 7920
Go to bissell.com type in the model number 7920 then go to user guide and you can print it.
Posted on Jan 02, 2009
BissellCSR
  • 276 Answers
SOURCE: I have Bissell 7920. The water is not being
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
Posted on Jul 15, 2010
SOURCE: New replacement pump on Bissell ProHeat Protech not working
Made a mistake, my model # is bissel 7901. Won't spray water. When you turn the machine on, it sprays for a minute or so then stops. All belts are in place..water tanks and spray bottle positioned correctly.
Posted on Jul 16, 2010
How do I use a brissell 7920 proheat carpet cleaner
PDF]ProHeat® Pro-Tech
banksvac.com/.../product_manuals/bissell/Bissell%20ProHeat%20Pro-Te...
USER'S GUIDE. 7920 / 7901 SERIES ... We're glad you purchased a BISSELL ProHeat Pro-Tech heated formula deep .... assembly and operating instructions, safety precautions, as well as ... *SmartTemp heats the cleaning solution for carpet.
Sep 29, 2015 | Vacuums
How do I change the belt on the Bissell Proheat
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vm
Mar 14, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I need instruction on how to put fiber cleaner inside of bissell proheat vacuum. Model number 7920.
heatman101
djhdgj
Dec 20, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920. Took it apart how do i align the solution valve
heatman101
fggds
Nov 23, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Need a user manual for a bissell proheat pro-tech 7920
Jan 02, 2009 | Bissell 9200 Upright Vacuum
Hi There!
Nov 14, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
7920 ebissell instructions
You can try bissel.com, or the part number for a user manual is 2105811, you may be able to order it, if it is available still.
Sep 06, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell proheat 7920 replacement pump
Part number is 2107181, it will cost around $30. Most local shops shoul have this part or can order it for you. You could try bissell.com.
May 03, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
32 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
