My Indesit WIL1435 flashes as soon as I switch it on at the plug, but won't turn off, only at the plug and I can't put it on a cycle.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
The door lock is faulty
Posted on Jan 18, 2013
4 Suggested Answers
SOURCE: Indesit W93, the light flashes but does not work
On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Posted on Mar 29, 2009
beltronic205
  • 1466 Answers
SOURCE: Indesit wahing machine WIE 167 keeps filling with
You need to clear out pressure chamber the part the at tube plugs into the chamber it will be clogged, stopping air going to pressure switch...This should cure..
Posted on Oct 07, 2009
SOURCE: all lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Posted on Apr 19, 2010
All lights flash on indesit washing machine soon after switch on
Feb 17, 2010 | Indesit W 123 Front Load Washer
Indesit IDL 500 Pump noise when switched on not continuous, sounds like it is acting in surges, and the pre-wash indicator light flashes in time with the surges. Is this a fault, what is the solution?
this indicates that there is water in the base of the unit activating the safety float switch... usually a leak..or an overfill due to blocked filter
Power off & remove plug
1st port of call would be to drain the base by pulling forward and tipping back.. make sure you have large towels to hand...
Once drained power up again and put on quick wash...
if cycle completes verify no leak by tipping back again and no water should flow..
if there is a leak then the flashing would resume during cycle... and best get someone in to locate as there are a few possibilities...
Dec 18, 2009 | Indesit Dishwashers
Indesit wahing machine WIE 167 keeps filling with water and did flash H2O have replaced the switch mechinism inside but to no avail tube is not punctured or coroded - will not go onto wash cycle but will...
Oct 07, 2009 | Washing Machines
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Indesit wia 121 door lock keeps flashing and when put machine on it goes to a wash without turning dial to correct wash no.
these machines have a memory built into the pcb's which means that if they are switched off or there is a powercut etc they will just carry on from where they were in the cycle as soon as they next power up. if there is a black dot on the timer settings turn the dial to it then switch machine on and this should reset it for you after a few seconds. if this does not work count how many times the doorlock light flashes as this is a fault analysis code they will usually flas then pause for a second then flash again and repeat this sequence until a longer pause (3 seconds) then the sequence starts over.
hope this helps
Jul 28, 2008 | Indesit Washing Machines
Indesit W1A 111 front load W/M
hiya
no need to worry they do this.
hope this helps
please dont forget to rate the helpfulness. thanks kj
Jul 20, 2008 | Indesit W 123 Front Load Washer
Indesit evolution DE73 frozen program
I have the same problem. You need to switch it off at the mains for at least 20 mins.
Aug 14, 2007 | Indesit 24 in. DE73 Evolution...
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
