Question about Mongoose 20-Inch Gravity Games BMX Freestyle Bike
Diagram of inside the headstock of a bmx
I,ve overtightened the headstock bolt and it has come out
    Problem Solver:
  • 18 Answers
You will have to purchase new one unless you can somehow salvage the old one and i have never seen it done.its just a little star like wedge with a screw hole very cheep.
Posted on Jan 25, 2013
  • LEE ISBITT Jan 25, 2013
    Thank you for your help
Bmx 4 wheeler
the rear wheel is the adjustment. loosen the main axle bolt and slide the wheel back until chain is tighter. if it has rear suspension there should be a small amount of slack in the chain when done. retighten axle bolt.
Sep 06, 2013 | ATVs
How to put the pegs on?
You need to have a BMX bike with a threaded axle. A bike with quick releases will not work.
The first thing you're going to want to do is go ahead and loosen the bolts on that side of the rim, take the bolts completely off, along with your spacers, pull them off and then you'll slide the peg onto the axle. And you're going to have to have an extension to get into the peg. The easiest way to get the peg on is to take it, put your bolt, your washer and then slide your peg into place on this, or you can put it on there and then you just slide it on, and then tighten your bolt back down, and that will hold your peg into place
Mar 15, 2011 | Conspiracy Shadow Little Ones Pegs Bmx...
Describe how to remove the front tire of a mongoose bmx bike
loosen the bolts on the ends of the axals of the wheels on the forks
Sep 03, 2010 | Freestyle Mongoose Bmx & Owners Manual -...
How to replace headlamp bulbs on Triumph Tiger 955(2006)
Remove the screen 4 plastic bolts,
Remove the indicator mounts, 3 screws, 1 is to inside of the tank on either side of the headstock. you can let them dangle on the wiring if so desired.
Remove the bolts under the screen and the bolts under the indicator mounts , hex bits required.
Remove the fairing from the bike.
3 allan bolts, 1 ether side and one underneath support the headlight assembly. Once these are slackened you will have access to the rear of the lights.
Reassembly is the reverse, allow 45 mins to an hour to complete the job,
Apr 19, 2010 | 2004 Triumph Tiger
Can i straighten the front forks up if I loosen the nut on the headstock, move the fork legs, and retighten the nut again? the bike is a VL800 k5.
Loosen the front fender, the axle retaining bolts, plus the upper and lower headstock bolts and nuts so that the whole assembly is free to align. Tighten the fender last. If that doesn't restore wheel alignment, you may have bent tubes that need straightening or replacement. Was the bike in a front-end wreck?
Nov 15, 2009 | 2005 Suzuki Boulevard C50
Where is the thermostat located on a 94 toy/4 cylider
Follow the top radiator hose from the radiator to where it attaches onto the engine. The thermostat is inside the housing that the hose attaches to. Remove the radiator hose at thermostat housing. Remove the housing. There are usually two bolts. The thermostat is inside. Scrape off all old gasket material and clean the housing. Install new thermostat and gasket. Be sure not to overtighten the bolts on the housing. The housing is usually cast metal and is easily cracked or broken if the bolts are overtightened. Hope this helps and best wishes.
Jul 31, 2009 | 1994 Toyota 4Runner
My bars keep slipping.. I have a Kink Gap 09 - I tried tighting the bars using the 'X' technique, I tried putting saran rap in there.. Any other options? PS: The Stem might be stripped.. if that's...
Try using a strip of sanding cloth cut to fit in a medium grit with the sanding part folded so both surfaces; the bars and the clamp feel the sanding surface. Also look at the threads on the bolts that don't seem to be tightening. If this is an aluminum stem there is a good chance that you may have overtightened and stripped one or more. Hope not.
Apr 28, 2009 | Dynacraft Next Turbo Children BMX Bike
Hot to fix a bike seat on a bmx
usually a 14mm wrench loosen the nut remove old seat put new seat on post tighten bolts
Apr 09, 2009 | Dmm Animal Stump Pivotal Bmx Bike Seat...
Torque setting cbr 1000rr headstock nut?
Hi there!
here are some recommended torque for small nuts and bolts:
Torque Specifications of Small Screws
Screw Size/Torque (in.-lb)
2mm 5-7
2-56 6-8
2.5mm 8-10
4-40 10-12
5-40 11-13
3mm 12-14
6-32 15-17
4mm 18-21
8-32 19-23
5mm 20-24
10-32 22-26
Also, click on the link below and you'll never have to find torque settings for your motorcycle bolts. I use this as a reference all the time.
http://img399.imageshack.us/img399/4280/ac43131btable71torquevalues9cn.jpg
Hope this helps!
Mar 29, 2009 | 2007 Honda CBR 1000 RR Fireblade
Mongoose 20-Inch Gravity Games BMX Freestyle Bike  Logo
110 people viewed this question
Top Mongoose Cycling Experts
Rommel Balcita
M.R.
M.R.
Level 1 Expert
WTF Chuck.....
WTF Chuck.....
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
