Question about E-Machines eMachines Desktop PC
Computer started beeping and will not power on
  • E-Machines Master
  • 27,725 Answers
How many beeps ??
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove new hardware If any new HARDWARE has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device. Remove any disks or USB devices Remove any disks, CD's, DVD's that are in the computer and if any USB devices (Ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes. Disconnect external devices. Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs. Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for theCPU) your computer could be overheating or detecting the fan failure causing the computer not to boot. Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable. All disk drives should have a data cable and power cable connected to them. Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board (if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA ,SCSI or other data cables from the CD-ROM ,Hard Drive and Floppy Drive from the Motherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard, PSU, CPU, orRAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers. Hope this helps.
Posted on Jan 18, 2013
My Dell laptop makes 12 beeps and won't start, why?
Unfortunately, they are bad news and omens of *****!
  • Beep Codes - General Hardware - Laptop - Dell Community en.community.dell.com > ... > Laptop > General Hardware There is a comment in the User's Guide that you should make a note of beep codes when contacting Technical Support but there is no list of the beep codes - this ...
  • Dell Optiplex and Vostro Beep Codes and Error Messages ... www.dell.com/support/Article/us/en/19/SLN143065/EN 1. OptiPlex Beep Codes. The computer might emit a series of beeps during start-up if the display cannot show errors or problems. This series of beeps, called a beep ...
  • Beep Codes and PSA Diagnostic Chart - Desktop Wiki - Dell en.community.dell.com > Support Forums > Desktop > Desktop Wiki Identifying Dell Computer Models Using the Model Code. On Sept 26, 2005 the System Setup program on certain Dell Dimension™, Inspiron™, and XPS™ computers was ...
  • Alienware Computer Does Not Turn On or Go Into Windows ... www.dell.com/support/article/SLN114868/en Dell support article tagged with ... The following tables illustrate the Beep Codes for Alienware Mobiles and ... For a laptop computer see if you can access the ...
  • Dell Inspiron 15R (N5110) Beep Codes Diagnostic Indicators blog.parts-people.com > ... > Inspiron 15R (N5110) How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming ...
  • Dell Motherboard Beep Codes - What They Mean www.brighthub.com > ... > Computer Hardware Support 2010-05-23 · Technicians and computer users alike can use beep codes to troubleshoot hardware problems on all kinds of machines. This article lists Dell beep codes ...
  • Dell BIOS Post Codes - BIOS Central www.bioscentral.com/postcodes/dellbios.htm Dell BIOS Beep Codes; Dell BIOS System Messages; Dell BIOS Post Codes . Dell BIOS Beep Codes:
  • Step-By-Step: Deciphering BIOS beep codes - TechRepublic www.techrepublic.com/article/step-by-step-deciphering-bios-beep-codes Discover what the beeps your computer makes at start up mean. ... Step-By-Step: Deciphering BIOS beep codes. ... Dell BIOS Beep codes for Dell computers ...
  • http://www.bing.com/search?q=dell+laptop+beep+codes&qs=AS&pq=dell+laptop+beep+codes&sc=2-22&sp=1&cvid=768D6F3CC9284B039CE5B3AB707EFF02&FORM=QBRE
    Jul 31, 2016 | Dell Computers & Internet
    Tip
    Computer beeps
    If you try to power on your computer and nothing happens but a bunch of beeps there is something you can do. The beeps actually mean something. To make sure you can hear the beeps check in the bios options. If there is an option for a silent boot you won't hear any beeps. If you hear one beep every time your computer starts then you don't have to worry about this.
    If you want to check this setting refer to my other tip on how to enter bios and change boot settings.
    If you try to boot your computer and nothing shows up on your monitor do these steps first.
    1-Check all your cables in the back of the computer.
    2-check your power source and power cord to the monitor
    3-try another monitor if possible
    4-If on a power bar try to turn off the power bar and reset the breaker
    If you try to boot your computer and nothing happens and you hear beeps look at this website. The beeps you hear are actually telling you what is wrong. Look at the website by clocking on the link below and click on the computer beep codes link. If you want to scroll down past the link it will show you bios codes to enter the bios in your computer
    http://www.michaelstevenstech.com/bios_manufacturer.htm
    on Jan 28, 2009 | HP Compaq Presario SR1500NX (PX786AA) PC...
    Compaq presario C700 continous beep when starting up
    Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
    1. Remove battery + disconnect power
    2. Hold down power button for 20 seconds
    3. connect power only (no battery)
    4. Turn computer on.
    If the beeps stopped.. get a new battery, if the beeps continue..
    ABANDON SHIP!
    Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
    Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
    When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
    Aug 30, 2012 | Dell Computers & Internet
    How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
    This POST cade is related to RAM problem
    one beep, three short beeps
    three short beeps, one beep
    • Memory problem: bad DIMM or bad DIMM slot
    Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
    May 12, 2012 | HP Pavilion ze2000 Notebook
    Display problem, CPU Fan starts but no Power on self test begin. Pls help
    The computer power-on self-test (POST) tests the computer to make sure it meets the necessary system requirements and that all hardware is working properly before starting the remainder of the boot process. If the computer passes the POST the computer will have a single beep (with some computer BIOS manufacturers it may beep twice) as the computer starts and the computer will continue to start normally. However, if the computer fails the POST, the computer will either not beep at all or will generate a beep code, which tells the user the source of the problem. Once the problem is located, simply replace the defective part.
    Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
    Beep CodeDescriptions1 shortDRAM refresh failure2 shortParity circuit failure3 shortBase 64K RAM failure4 shortSystem timer failure5 shortProcess failure6 shortKeyboard controller Gate A20 error7 shortVirtual mode exception error8 shortDisplay memory Read/Write test failure9 shortROM BIOS checksum failure10 shortCMOS shutdown Read/Write error11 shortCache Memory error1 long, 3 shortConventional/Extended memory failure1 long, 8 shortDisplay/Retrace test failed
    Jul 27, 2011 | Gigabyte Computers & Internet
    Dell Dimension 8400 - screen goes black or just freezes, no mouse or keyboard input works. Power down and then power back up works fine for about 10 mins then same problem.
    Does the computer emit any beeps? If so, how many beeps?
    One quick loud BEEP, at start up means that all is loading OK. If you get more than one BEEP sound, than you could have Memory ( RAM ) that is, or has failed. Sometimes, if one of the internal fans has failed or is failing, a computer will start up, and than shut itsself down again. Look for any error messages that may come across the screen. Get on another computer, and search for "computer beep codes". If you have the original manual that came with the computer, sometimes it will list beep codes in it. As it has been pointed out, it could be the hard drive also, check the beep codes, that is a good place to start.
    Jun 18, 2009 | Dell Dimension 8400 PC Desktop
    Computer beeps when I try to start up
    No Beeps
    No Power, Loose Card, or Short.
    1 Short Beep
    Normal POST, computer is ok.
    2 Short Beep
    POST error, review screen for error code.
    Continuous Beep
    Repeating Short Beep
    One Long and one Short Beep
    Motherboard issue.
    One Long and Two Short Beeps
    Video (Mono/CGA Display Circuitry) issue.
    One Long and Three Short Beeps.
    Video (EGA) Display Circuitry.
    Three Long Beeps
    Keyboard / Keyboard card error.
    One Beep, Blank or Incorrect Display
    Video Display Circuitry.
    Jan 05, 2009 | HP Computers & Internet
    I get one long beep and one extra long beep on startup. Computer just beeps and nothing else.
    The computer POST (Power On Self Test) tests the computer, insuring that it meets the necessary system requirements and that all hardware is working properly before starting the remainder of the boot process. If the computer passes the POST the computer will have a single beep (with some computer BIOS manufacturers it may beep twice) as the computer starts and the computer will continue to start normally. However, if the computer fails the POST, the computer will either not beep at all or will generate a beep code, which tells the user the source of the problem.
    This issue can be caused by any of the below situations.
    1. New hardware conflicting with old hardware.
    2. Bad or failing hardware device.
    3. Connections not connected or connected properly.
    4. Recent electrical storm that caused a surge that damaged computer.
    5. Other hardware issue.
    you can determine the meaning of your beeps finding out with your BIOS System installed on your machine.
    Usually you probably have some memory problem.
    Oct 26, 2008 | HP Computers & Internet
    E-Machines eMachines Desktop PC Logo
    26 people viewed this question
    Top E-Machines Computers & Internet Experts
    Matthew Spark
    Matthew Spark
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
