Question about Saws
How do I change the blade on my pro-tech model 3104 bandsaw
The blade doesnt want to stay on
  • Jack Faire Jan 18, 2013
    Before doing anything, check the length of the blade. You maybe have the wrong length. It may not tracked and tensioned properly. Double check the adjustments. Are the tires new? Tires should not be worn out. Guides must be positioned properly too. You may want to check your manual. It can help to figure things out. And oh , try reading this blog :http://bandsawblog.com/replacing-the-ban... . And you can check more informative blogs there. Hope I helped you.
    Sergeant:
  • 468 Answers
blog : http://bandsawblog.com/replacing-the-band-saw-blade-on-your-band-saw/ .
And you can check more informative blogs there. Hop[e I helped you.
Posted on Jan 18, 2013
4 Suggested Answers
SOURCE: hi i have a craftman bench 10 inch bandsaw that has blade drif
The problem could be one of two things. The tires could be worn or glazed with rosin. Try cleaning the tires with mineral spirits to remove the build-up. The other possibility is that the pulleys are out of alignment. To check this, put a straight edge across the face of the lower pulley and see if squares with the upper pulley, if it doesn't, loosen the set screw on the upper pulley and adjust accordingly
Posted on Jan 21, 2010
  • 4088 Answers
SOURCE: I am changing the saw blade on 12 inch Craftsman bandsaw
Go to: Searspartsdirect.com and enter the complete model number minus the decimal point. This will bring you a series of parts drawings and possibly an owner's manual. Generally, adjustment is provided for the upper wheel only--use hand power to check the tracking performance. Good luck!
Posted on Jun 25, 2010
ddebroux1
SOURCE: I HAVE A SKIL BANDSAW MODEL 3104 I NEED A 62 INCH
62 inch bandsaw blades are at haebor freight stores
Posted on Mar 27, 2012
Will a 59 1/2 inch blade fit my protech bandsaw model #3203
Click to open expanded view Olson Tko Special Band Saw Blade (TK17259) by Olson Be the first to review this item Price:CDN$ 24.15 FREE SHIPPING. Usually ships within 3 to 4 days. Ships from and sold by TEXASVALUE. 4 new from CDN$ 24.15 Hard edge Flex back For hard and soft wood, general purpose contour cutting, fast cuts, and medium finishes For Ryobi BS900 and BS901, BandD BS700, Sears Craftsman BS700, Pro-Tech 3202 and 3203, Delta 28-150, Colli Length: 59-1/2" > See more product details
Aug 13, 2015 | Blade Saws
I cant seem to find the blade size for an older pro tech bandsaw model 3101. Is there a newer model that is compatible?
There should be enough adjustment on the tensioner to allow you to use any size blade that will be close to the original size. Set the tensioner/adjuster to the mid position measure the size of the blade, and look for one close to that size.
Nov 10, 2014 | Saws
Where do I get a blade for Pro Tek 10" model 3104
I buy mine on sawblade.com ; they are cutting blade stock to any length. Your bandsaw is using 62" right? Try to use a 1/4" 0.025 6 TPI flex back carbon blade for cutting non ferrous metals.
Jul 04, 2014 | Saws
Where can I get the parts for the upper and lower blade guides for my skil 10" bandsaw model 3104
Try to contact Skil, if they can't provide you. Check with Carter Products ; they supply bandsaw guides for all types of saws.
Jun 12, 2014 | Skil Saws
Where can I get the upper and lower blade guide parts for my skil 10" bandsaw model 3104
Inquire with Skil tools or you can also check Carter's band saw guide kit.
Where can I get a thrust roller for a skil bandsaw 3104
I've been purchasing replacement parts on www.bandsawparts.com . But they don't have for Skil bandsaw. Have you tried checking on toolpartsdirect? Do you happen to know the correct model number of the part?
Feb 15, 2013 | Skil Saws
Jan 12, 2010 | Saws
Clark 6x4 bandsaw
there should be an adjustment knob on the back that changes the angle of the top wheel and this will center the blade so it stays on. I do this by jogging the saw on and off while I adjust it. hope this helps you
Sep 23, 2009 | Grizzly Saws
Saws Logo
344 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
