Question about Sony CONTROL UNIT, TUNER WITH R Shelf System
Sony RX77 CD tray won't close
5 Suggested Answers
  • 15 Answers
SOURCE: jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
Posted on May 01, 2009
  • 8457 Answers
SOURCE: Sony RDR-GX360 won't respond to
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Posted on Aug 11, 2011
quintonizaak
  • 319 Answers
SOURCE: sony cyber-shot dsc-w570 lens cover won't close
Lens block is faulty you must replace it with a new one
Posted on Jan 17, 2012
gopakumarg43
  • 74496 Answers
SOURCE: tray won't close fully then pops open again what needs to be done.
Hello
Its loading mechanism has the fault. It must be replaced. Check its loading belt, before replacing the loader mechanism.
Picture of the loader mechanism is given here.
http://www.dataentryjobs.us/67948.html2_28_2012_4_54_10_am.jpg
Posted on Feb 28, 2012
CD drive won't close
If the CD tray won't close then it's probably a mechanical issue with the drive and needs to be replaced.
May 07, 2013 | Dell Inspiron 530 Desktop Computer
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
The dvd tray on my Sony BDV-E780W won't stay closed. Whenever I turn it on the tray opens and wont close from the remote or device.
Have you checked to see if it is off track? Sometimes when these machines get bumpbed, dropped, or fall they can jump track. You have to take the cover off and inspect to see if it is off track when it closes and opens. It should go all the way back on the track when it closes. Be careful not to shock yourself. If it is on when you do it and your hand touches the metal parts inside you can get seriously burned or shocked.
Dec 01, 2012 | Televison & Video
DVD/CD disc opener won't workGetting
Usually the tray has to be opened and inspected and if lucky it can be realigned--if not parts may be hard to find as they usually do not sell individual parts for the mechanism.
Nov 05, 2012 | Televison & Video
CD tray won't open or close on onkyo dx-c606 cd changer.
Yes! it sounds very likely that a small loading belt has stretched, or the loading motor is not working, this is not an easy repair because the gears are timed and synced to work together, if the unit has a loading belt pull tray all the way out and look in the empty tray, may be visable! if you can remove it without taking it apart all the better, have a Tv repair shop size up the belt for replacement.
May 01, 2012 | Onkyo Audio Players & Recorders
Cd tray won't close
Use a can of compressed air to clean out any dust or dirt, if that won't work! gently pull all the way out to see if anything is catching, if the tray is stiff to move it is out of alignment. Have a computer shop take a quick look at it, may need to be replaced.
Apr 12, 2012 | Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
I have a Philips CDR820 CD recorder/3 CD changer. The CD tray won't stay in. I push the load/close button, but it closes and then immediately opens again. Won't stay closed. Not sure what to...
I have done this job. taking that think apart can be a pain.
There is probably a switch, that is pressed, and senses the closing or status of the tray,
and it keeps resetting. It could be a leaf switch, that would be lucky.
It could be an encased switch. You would need an exact replacement in that case.
The leaf switch could just need to be cleaned with a folded dollar bill.
Its perfect for cleaning a couple of contacts, and its not destructive.
Its a shame to throw something like that away, for such a small problem.
Maybe you could sell it at a garage sale to some kid after you tell 'em what the problem is.
Point being, taking that kind of thing apart, and putting it back together again, might not be worth the stress that goes with it. I've done it because I am POOR, and if I had money, I wouldn't go through that aggravation.
Aug 29, 2011 | Audio Players & Recorders
Cd tray won't stay open--when you press the "open" button, it opens but then closes again immediately.
It has a misaligned loading mechanism. I have dealt with this kind of problem before. What is happening is that before the tray have a chance to open all the way it gets stuck and gets pulled back in.
May 24, 2011 | Marantz CD5001 CD Player
62 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
