Computer is on, but no screen open - Computers & Internet
  • 37 Answers
I dont know what you are trying to ask but if you meant that you switch on your computer base unit starts but dont have any display then that could be some hardware issue.First of all make sure your hardware is connected properly like ram harddrive etc i hope it helps you.
Posted on Jan 18, 2013
The software for my Cisco Flip ultra HD video is not opening up on my computer?
copy the file to the computer , dont run it from that location i assume u are.
Jan 05, 2015 | Cisco Flip Ultra Hd Camcorders
After saving to a disc, how do I then download to my computer?
Once saved to a disk, information can be downloaded to the computer through the "my computer screen".
Insert the disc into the computer and open the "my computer" screen. Then right click on the CD/DVD icon in that screen which should list your inserted disc.
From the right click menu, select "explore".
A new screen will open with the contents of the disc.
ctrl+A selects everything.
ctrl+C copies everything.
Navigate to the address you'd like to download your information to.
ctrl+V pastes everything into that directory.
Dec 12, 2009 | Acer Aspire 5500 5570-2609 Laptop
How do I capture images on my lenovo S10/Windows XP screen? (usage instructions) cruzer SDCZ36-004G-A11
Step 1: Insert your flash drive into your computer’s USB port.
Step 2: You may be presented with a window open that says “Auto Play
If this is the case, simply click on “Open folder to view files”. If you don’t have this window automatically open, open “My Computer”, locate and double-click on the appropriate device to open.
Most flash drives will be labelled as a Removable Disk but some will be labelled as a hard drive. If you have troubles locating your device, remove the flash drive from your computer, open “My Computer” and take note of the drives and devices already there, then reinsert your flash drive into the USB port and watch for a new device to appear. Take note of the name Windows uses to label the flash drive, Removable Disk (F:), for example. Double-click to open.
Step 3: Open the location of the photos and/or folders you wish to transfer to the other computer.
Step 4: Select the photos and/or folders. To select multiple images or folders, hold down the Ctrl key while making your selections.
Step 5: Right-click on your selection, choose “Send To” and then the appropriate destination (in my case, Removable Disk (F:). Alternatively, you can drag-and-drop your photos or folders into the opened flash drive folder, so long as both windows are seen on your computer’s monitor.
Step 6: Once your files have been moved over to the flash drive, click on the “Safely Remove Hardware” icon located in the notification area (bottom right corner of your computer’s monitor).
Select the device and click “Stop”. You may have another window open asking you to confirm which devices to stop.
Select the device from the list and click “OK”. You’ll then be prompted that it is safe to remove the device.
Sep 25, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My computer will not open any programs or cd drive wont open. When I try to open a program the command prompt screen comes up and then closes but the program wont open
YEOW... not fun...
Reboot ---> as soon as you see the very first opening screen (the manufacturers screen, BEFORE the windows screen) press and hold F8 --> the menu that appears will give you some options, choose "Boot in Safe Mode" --> When Windows loads, it will either give you the option immediately to run System Restore (or go to Start ---> Help & Support --> System Restore)
Either way, if the computer is attepting to open a command prompt from a normal icon, you have issues! Try to restore it first to a date sometime before the problem started!
Hope this helps!
-- RT
Sep 02, 2009 | Dell Latitude C610 Notebook
Spyware and Virus Removal
Format your entire disk(s) and do a clean install of windows/linux or whatever you have.
Aug 15, 2009 | Dell Computers & Internet
Ablank screen on ibm thinkpad t41 xp pro
I am a computer tech and it sounds like the cable that connects your screen to your computer has come loose, or is going bad.  You will want to open the computer (carefully) which may take a while and please be careful with it and remember where the screws go.  But there are pads on the front of the scrreen take those off and unscrew the screws, and then open it up carefully prying it open with a screwdriver, be careful because the plastic breaks easily.  and then there will be a wire connecting monitor to a port thingy, and then make sure it is snug in there be carefull with this though.  If you put it all back together and it still doesn't work you need to buy a new screen just look up your computer model number and order one off the internet.
Apr 08, 2009 | IBM ThinkPad R51 Notebook
Acer crystal Eye Webcam shows whats on the computer screen
frist of all open a control panel and also open programmes then acer crystal eye webcam remove and then install a new software of acer crystal eye webcam and restart the pc and use
Feb 01, 2009 | Acer Aspire 5610-4648 Notebook
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Doing siytem restore,and have no operating system.Vista home premium model no s 3460 sofware build 82APv3PrA1.Im under warranty what can i do?.In the start of system restore computer stopped,message reeds...
Starting the recovery from power up If Windows Vista cannot open and if the Recovery partition on the hard disk drive is functioning properly, you can perform a System Recovery by performing the following procedure:
  1. Turn off the computer.
  2. Disconnect all connected devices (such as the Personal Media Drive, USB drives, printer, and fax), remove media from drives, and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, and power cord.
  3. Turn on the computer.
  4. Do one of the following actions depending on how Windows Vista was installed:
    • If Windows Vista came pre-installed on your computer, press the F11 key repeatedly when the first screen opens (the logo screen), until Recovery Manager program opens on the screen.
    • If your computer was upgraded from Windows XP to Windows Vista, press the F10 key repeatedly when the first screen opens (the logo screen) until Recovery Manager program opens on the screen.
    If Recovery Manager does not open, a set of recovery discs is needed to perform a System Recovery. Follow the instructions listed in Starting the recovery from recovery discs .
  5. Click Next .
  6. On the screen that prompts for Microsoft System Restore select No , and then click Next .
  7. The Recovery Manager gives you the option of backing up your data files. Backing up your files is recommended. To back up your files select Yes , and then click Next . Follow the onscreen instructions. If you do not want to backup your files, select No , and then click Next .
  8. After the System Recovery is complete, the computer restarts and continues into Windows setup. Complete the setup screens and wait until the computer finishes the setup. Then, turn off the computer, reconnect all peripheral devices, and turn on the computer.
  9. Before using the computer, update and protect it by reinstalling any virus and security software that was installed before the System Recovery.
  10. Reinstall any software applications that were added after puchasing the computer, and replace any files that were backed up.
Nov 06, 2008 | HP Computers & Internet
Compter won't open windows
first try that safe mode option and do log in . when you successfully log in restart your computer . this happen mainly when there is sudden loss of power supply to the cpu. shut down your computer properly by pushing the power button on the cpu
Jun 19, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
