Question about Camp Chef HOT WATER HEATER / PORTABLE SHOWER
Why does my triton 5L have to run low water water for gas to ignite.It ran fine before.
When I turn on water gas does not ignite until I turn water way down, It will then run but I can't turn the water flow up or the gas will turn off.
Triton 10 L wont light up has inginiton but not getting gas
There is something that must be blocking the pipe for the gas to flow check the pipe
Feb 12, 2014 | Camp Chef Triton 10L Portable Water Heater
Problem with IGNITION LOCKOUT
Air in the system or low gas pressure?
Apr 25, 2013 | Water Heaters
Burner lights and shuts off 3 times and then give warning lights A and B
It depends on the model but AB on most of the AOS the A & B LED's lighting up usually means ignition/flame failure.
Ignition/flame failure:
The gas control valve/thermostat has reached the maximum number of retries (3) for ignition and is currently locked out for one hour. Cycle the power to the water heater off and on to reset.
Basic troubleshooting/solutions:
1 Ensure flame sensor is making good contact with the burner flame and ensure flame is steady. Also ensure supply and manifold gas pressures are within the requirements in the installation manual.
2 Gas supply is turned off - pressure is too low. For low gas pressure, consult with your gas utility.
3 Ensure the flame sensor is clean - use fine steel wool to clean the flame sensor.
4 Check igniter assembly plug and the socket on the bottom of the gas control valve/thermostat for good connection. Replace igniter assembly if the plug is worn or damaged. Replace the gas control valve/thermostat if socket is worn or damaged.
5 Replace igniter assembly.
If this does not apply to your model then here is a link to the instruction manuals for all models:
Residential Gas
Apr 14, 2013 | A.O. Smith Water Heaters
Water Heater will not ignite in cold weather. It will start when a manual gas lighter is introduced to the gas tube orifice. In warmer weather it works fine.
What type of RV is this in? If plugged in to hydro , or running off fully charged battery, low voltage shouldn't be a problem, so the solar panel idea makes me think one or the other or both are problems.
Nov 23, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Pilot light will not automatically light when hot water is turned on
This is a great unit! Try turning the flow nob to the half way point and the flame all the way to low. Run the hot water tap and slowly turn the flame dial until you hear the unit try to light. Every house is different regarding the restrictions in the plumbing and water pressure. Once the unit tries to light that is your minimum setting. It is best to leave it there.
Apr 05, 2010 | Bosch & Tankless LP Hot Water Heater
Low hot water output
do you have a question on this?
You have a water heater that has woked well in the past and now the amount of hot water is diminished?
When was the last time your cleaned the junk out of the bottom? Do it now ... connect a hose to the bottom drain and lead the hose to a drain. Run the water until it is clear + 2 or 3 minutes.
Is this gas or electric? You have plenty of gas ... all other gas appliances work fine in your home?
Electric ... you could turn off the power and check that the elements still good. check contunity first then carefully - repeat - carefully - turn the power and check the voltages. should be 220 V ac
If it put out hot water before and now does not ... the elements are good ... still no hot water, could be the thermostat.
all speculation on my part because I dont know what your question is.
a
Oct 05, 2009 | Water Heaters
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Rheem tankless water heater wont lite
the system was not sized properly, you need to have a 3/4 gas line to the unit for the volume of gas it needs, the tankless water heaters need to have every bit of gas that is says, it sounds like who ever installed di not make sure you had enough gas comming in the house, you might have to either have a new meter installed or run the gas lind directly from the meter to the water heater and cap off the gas line thats there
May 05, 2009 | Rheem Tankless Hot Water Heater...
Camp Chef HOT WATER HEATER / PORTABLE SHOWER Logo
79 people viewed this question
Top Camp Chef Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Camp Chef Water Heater Expert? Answer questions, earn points and help others
