Question about Whirlpool AWM8123 Front Load Washer
Please describe what does FA error mean? Were I can find this Aquastop switch?
When I start my washing machine at any washing program the key led indicator start flashing. If I run the self test program the FA error appears.
  • Kalin Marev Jan 19, 2013
    The filter is empty. The pump is working and as I wrote the machine drains.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Check your pump is not blocked take bottom front panel off and unscrew it
Posted on Jan 18, 2013
SOURCE: program will not start, door light flashing
Has anyone had any joy with this? I have exactly the same problem.
Thanks
Posted on Jul 27, 2010
ginko
  • 19396 Answers
SOURCE: when i start wash. machi. pump starts and few sec.later led flash
Check the water supplies at the back, if the valve is opening, and the water is getting into the machine, it can be a faulty water level switch, or membrane sensor, depending on the model.
A faulty or clogged inlet valve can also close few seconds from opening the valve, usually becausu of a faulty solenoid.
If valve and water level switch are ok, then this is a faulty control.
Have valve and water level switch checked first.
Posted on Dec 10, 2008
  • 1382 Answers
SOURCE: error code FH on my AWM, what does it mean?
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Posted on Jul 12, 2010
  • 6 Answers
SOURCE: F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
Posted on Jul 16, 2008
SOURCE: AWM8000 AF flashing and machine cut out, very
WHEN I PRESS START - HAS ALARM ON DISPLAY F AND H FLASHING AND TAP OPEN POSTER HAS THE FLASHING LED TOO. HO TO REPAIR IT.
MY NAME XUAN
Posted on Oct 04, 2009
Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
Whirlpool AAA Class Dishwasher
FA - Aquastop error
Check water supply. Low water pressure? Does the machine fill up with water in under 1 min? If not, thats your problem. If this happens during wash cycle, it could be the intake valve for the rinse cycle that is your problem, if you hava doubble/tripple intake valve that is.
Feb 17, 2016 | Washing Machines
What does E-14 in Bosch Washing Machine mean?
E14 stands for an error code concerning the flow meter. This is a sensor which mesures if enough water comes into the machine. There are several causes. Did you open the faucet enough or is there some dirt in the sieve between the aquastop and the faucet?
Jun 16, 2015 | Bosch Washing Machines
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
Led display flashes door
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect. You need to check the voltage to the controller before it can be confirmed.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
May 31, 2012 | Hotpoint Washing Machines
Error code FA
FA is the emergency shutoff switch that detects when water is pooling underneath the machine (a leak)
You may have to remove the back of the machine to check the float switch underneath. Empty any water from the catch tray and check for leaks.
Mar 02, 2012 | Whirlpool Washing Machines
My indesit WIL123 stopped mid-wash with LEDs 3 & 4 flashing with the main button. Pushed the main off button on the machine and it started to fill with water again. Now have a washing machine full of...
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Jul 22, 2011 | Washing Machines
MY NAME XUAN
Sep 29, 2009 | Whirlpool AWM8000 Front Load Washer
Awm8143 FA code
Service manual say FA is "aquastop failure- check aquastop switch", (aquastop switch is flood switch located in base of machine), however looking at the parts view of this machine, it doesn't seem to have a flood switch-odd.
F9 is an overflow problem- manual says to check pressure switch.
Both faults seem to indicate either a leak or overflow problem- remove rear panel and check base for any water, which would indicate a leak.
If OK, next step would be to remove front panel (remove wire and spring from around door seal, remove 2 screws holding door lock, remove 3 screws along base- front panel comes off by pulling down and out towards you-can be a bit tight)
Pressure switch is located just above door lock-it has the black tube going to it- remove tube and blow into switch-you should hear it click.
Also check the chamber that the other end of the tube connects to on the bottom front of tub- this chamber can get blocked up and cause overfill problems.
Please note- always disconnect from power supply before attempting any repairs. If in any doubt, best to leave for an expert.
Good luck!!
Aug 11, 2009 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM8123 Front Load Washer Logo
757 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
