Question about Electrical Supplies
No lights upstaires circuit breaker keeps tripping
Was ok yesterday but now keeps tripping out
  • 5,245 Answers
Jan 2013
1) Move wire to another same-size circuit breaker to eliminate bad circuit breaker as suspect.
Do NOT increase size of breaker or it will cause fire.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html
2) Put hand on each appliance and outlet to see which ones are warm. Outlet should never be warm or hot. Replace outlet. Inspect wires for loose and burned connections.
3) If the breaker is good, then add up total watts being used by checking watt rating on each device. 100 watt light bulb is 100 watts. Big screen TV has a label that shows 300 to 500 watts. Computer has label. Space heater has label showing 1500 watts. Iron has a watt rating label. Take total watts and divide by 110Volts and this will give amp load. Total watts used = 2000 and then divide 2000 by 110 volts = 18.8 amps
Compare amp load with circuit breaker.
20 amp circuit breaker has 80% safe maximum, or 16 amps.
If amp load is 18.8 amps, then 20 amp breaker is starting to get hot, and weak breaker will start tripping.
If amp load is 18.8 amps, and breaker is 15 amps, then you are overloaded and breaker is feeling the heat, and tripping because of heat.
Solution is to reduce amp load.
4) If you have short circuit, that can also trip breaker.
Unplug everything and then plug things back in slowly to see which plug or appliance is causing the problem.
Posted on Jan 20, 2013
3 Suggested Answers
  • 142 Answers
SOURCE: The Lights circuit breaker keeps trips without load
try a new breaker, they do wear out over time
Posted on Feb 08, 2010
heatman101
  • 43501 Answers
SOURCE: Circuit breaker trips out when all lights on the circuit are off.
You have a dangerous situation there. If the breaker is tripping like that and espec. if you have no load on it then there is an intermittent short that is happening in the circuit somewhere. The hot wire is shoeting to the neutral or ground wires at some time... This will cause a fire if you leave it and do not find the cause. The best fix would be to rewire the whole circuit if you can not find the cause of the short. To identify the short look for a black spot in the wiring some wher. the arc from the short will cause a burn mark when it happens..
Good luck and be careful!!
Heatman101
Testimonial: "Thanks, but can't work out why doesn't stay shorted."
Why does the circuit breaker keep tripping?
Need more information is it dryer,stove,ac ,heat, water heater,bathroom plug, garage plug ,outside plug, other
Lighting circuit with plugs
Oct 19, 2016 | Dryers
Reset Jandy PS6, still flashing red and green
turn off heater if ok then replace ignitor if not keep removing auxs until stops blowing breaker
Apr 02, 2014 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Kenmore canister - trips 15 amp circuit breaker
Check specs on unit and amperage. If it is less than 15 then the upstairs breaker is kicking off prematurely - Not uncommon event. If unit is drawing more power than specs there is excessive friction in motor bearings. Also check out brushes for good contact since they wear.
Sep 11, 2017 | Kenmore 25512/ 25513 Progressive Canister...
Amana RCE24C2A trips circuit breaker
tripping the circuit means the unit is has a ground, "means some peeled wire inside is touching its metal case"
Jun 01, 2013 | Amana Heating & Cooling
I have three upstairs bedrooms that are all on the same circuit. My sister tried to plug in something to an outlet in her bedroom and it seems that she jiggled the plug into the outlet and the power went...
I know this may have already been checked, but make sure that any gfci may have not tripped, and also, reset all the breakers if the gfci thing doesn't work... Trust me i know it is annoying but resetting all of the breakers almost always fixes the problem.
Aug 02, 2011 | Electrical Supplies
Feb 08, 2010 | Electrical Supplies
Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Dec 09, 2009 | KitchenAid KUDR01TJ Dishwasher
Whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Feb 02, 2008 | Whirlpool LER5636P Electric Dryer
Electrical Supplies Logo
124 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
