Question about Dell Vostro 1510 Notebook
Power light on no screen
Have to keep plug in all times but now no screen
  • Dell Master
  • 7,627 Answers
Posted on Jan 18, 2013
Will not charge
Well when the light is green that usually means it is fully charged. If the light is amber then it is charging. If you are having problems with short charged up time duration try this: Plug charger cord into Kindle then plug charger to outlet. Then press on/off button. A screen will pop up asking if you want to cancel or power down the unit. Do not choose either option, keep the button pushed down until every thing turns off. There will be no power light at all. Wait 2-3 hours unplug everything then power up the Kindle. This action will match the battery indicator icon to a truer image of the battery. I do this several times a week, usually overnight. Sorry if I over answered your question.
Apr 01, 2014 | Microtech Corp. ePhotoChest
My Fujitsu lifebook T902 keeps changing the screen brightness levels for no apparent reason.
I would think that if the virtual level controls are not changing, either the power socket/supply, back light or invertor has an issue.
Dec 01, 2013 | Fujitsu LifeBook Computers & Internet
Xbox power light blinks and freezes xbox
That flashing green light meens there is a problem with the power to you DVD drive. the power is being interrupted. ie, when you have power the welcome screen will load and when it doesn't it will shut off. you don't have continuos power. For example if you have the power cable unpluged and then plug it in with the power on the xbox will reboot. Check the wires and the port on the motherboard if all is ok you need a new drive.
Jun 24, 2009 | Microsoft Xbox 360 Console
Laptop LCD Screen won't come on and computer keeps rebooting
Try checking the inverter, if that is intermittent, it could short the system and cause the symptoms you are describing.
Apr 03, 2009 | Gateway 7330GZ Notebook
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
My HP Pavilion dv5000;s monitor is blinking!
This is a possible problem with the inverter that powers the back lighting panel or it could be the power adapter connector on the latop.
Wriggle the power connector which plugs into the laptop, if the LCD screen flickers then the power connector is faulty or needs resolderng (repairing).
Jan 28, 2009 | HP Compaq Pavilion dv5000z Notebook
Blank Screen - Panasonic PT-50LC13-K
Hey Ben, The TV is alerting you it is about time to change your light bulb, it will keep on doing this until the light bulb just dies.
Order your Bulb via On Line at any of the places, there are different prices, but average for the authentic one with the chasis included is @ 260.oo and only takes @ 5 days to get delivered. You can save up to 140.oo if you just order the pure light bulb, and go the extra mile changing it, I just explain someone how to about it, only takes you 30 mins. Good look, I hope I get help for my problem too.
Mar 16, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Satellite receiver
dont need factory to reflash.
turn of set at plug.press and hold backup on set(keep pressed)
turn on at plug.keep backup pressed for about 15 seconds.all lights on set will flash.if you have tv tuned to set screen will display updating system.dont turn off.when lights on set go off(about 10min later)set is reset(flashed)Press power on remote sky will restart like new.
Sep 03, 2007 | Panasonic CR-SRF100 SIRIUS Radio Receiver
Dell Vostro 1510 Notebook Logo
23 people viewed this question
Alun Cox
