Question about AKG K 141 MKII
Headphones playing only on the left side. - AKG K 141 MKII
  • 5,342 Answers
I have a guide on my blog to deal with this kind of headphone problems.
http://therealchart.blogspot.co.uk/p/technical-help-tips.html
Posted on Jan 18, 2013
Both sides of my headphones are outputting sound however music that is supposed to be left isn't outputted at all. That is, if a song has instruments playing on the left side of the track, it won&
Are you using the 1/4 inch adapter- if so- make sure the mini plug is fully seated- you should feel 2 detents as you push the plug into the adapter- if you do not, you may be bridging the tip and ring colar with one channel and because it is not seated fully, it is not contacting the other channel at all.
Also make sure the plug for the headphones is fully seated into whatever device you are listening to. you should feel the 2 detents each time.
Apr 01, 2012 | Music
My skullcandy agent headphones are only working on the left side,,,,,its blank on the left side
Sounds like there may be a problem with the cord.
Try plugging in your headphones and playing some music and moving the cord around. If the sound cuts in and out then you have a lose connection and will need to replace your headphones.
Mar 25, 2011 | Skull Candy Lowrider Headphones
I have a garmin nuvi 360. It has an audio problem. It usually doesn't play any audio unless I plug in headphones or an audio cable. And when I plug in the headphones it only plays through one ear. But if I...
Please see this link:
http://www.sharc.net/gps_audio_repair.htm
Your headphone jack connections have broken inside, cutting off the speaker and one side od the audio, left or right. The jack needs to be replaced or resoldered.
- Jim
Jun 30, 2010 | Garmin Nuvi 660 GPS Receiver
The left side wont play music but the right side will play it completely
hi there, I had skull candy earbuds in the past. The problem is that the left side has a short in the speaker. It means that you need to get a new pair of earbuds as they are not fixable.
Mar 02, 2010 | Skull Candy Smokin' Buds Headphones
When i take out my headphones out of mu ipod touch it wont let me hear it without the headphones on
you have to hit play again after you unplug the headphones and turn the volume up using the buttons on the left side of the device, if you have no buttons on the left side then you have the 1st Gen iPod touch which you can only listen to with headphones.
Jan 30, 2010 | Apple iPod touch Second Gen (8 GB,...
Problem with MDR-v150
the right side of your wire has a short in it or it has been cut. check wire for cuts if none are visable the your wire has came loose and needs soildered back on...
Jan 04, 2010 | Sony MDR-V150 Professional Headphones
ITouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Apr 16, 2009 | Apple iPod touch
Bose Headphones only works on left side.
Have same problem. Play with the plug in the socket. I'll bet it you can occasionally get both working. Not a solution since it probably won't stay working. I have an old plug and it fails too. I'm afraid they did't make their plugs to the right tolerances. Used to work once. Annoying for this expensive a headphone.
Mar 29, 2009 | Audio Players & Recorders
Left ear no music
Before you worry about repair, verify that the balance control in the iPod isn't causing the problem. The easy way to do this is to try some other audio device (home stereo, etc).
Mar 19, 2009 | Coby CV-190 Consumer Headphones
AKG K 141 MKII Logo
191 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
