Electrical fault was washing and electric tripped i pinpointed the problem to washing machine and when i shut door the electric trips again
  • 15,935 Answers
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Beko wm5121w 5 kg keeps cutting out the electrics can open the door machine starts to fill and eveything cuts out
With the machine unplugged, try disconnecting the heater and then turn the machine back on. If it is still tripping the electrics reconnect the heater and disconnect the motor, then turn on again. Likely one of those is causing the fault
Mar 12, 2014 | Washing Machines
Wmf540 beeps
Not sure your entire question but if no cycle is chosen or running and you close the door and the power trips then it is definitely your door lock mechanism. This is located to the right of the door behind front panel. If it tripped out in the middle of the cycle and by closing the door you are restarting the cycle then it will depend on where in the cycle you are up to. Of course it can always still be the door switch itself I don't usually find them tripping the power. If the machine starts the fill but trips out it is likely the inlet solenoids. If the unit fills some and then trips it is likely the motor. If the unit fills washes and then trips it is likely the drain pump. If the unit fills washes drains and then trips it is likely the motor. Of course at any of these points it can be any of the pc boards. So if you know where in the cycle it trips this will narrow down the choices.
Jul 08, 2013 | Washing Machines
I have a candy go1282 washing machine that has stopped mid cycle and blew the electrics in the house ( not sure if it was the washer or something else that tripped the electrics), now it will not do...
do u still have power to the machine? try a spin cycle? try a rinse cycle if neither works u have a power supply fault.did u wire the door lock correctley?
Jun 28, 2010 | Washing Machines
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint WM51 Washing Machine keeps tripping the electric
I had this problem; it was the motor arthing out on the body. It took a repair man half an hour to sort and it cost me £35. Hope this helps. Domo.
Jan 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Ok that rules out the heating element. There are a number of possible causes so bear with me while i go through them.
Can you open the door? If so leave it open then turn on the machine. Does it trip?
Jan 23, 2009 | Hotpoint First Edition FEW12 Front Load...
Washer tripping the electric
fault probably with heater short to earth posswibly as a result of washing coins etc. take offr back panel and disconnect heater and tape up wires. start machine and see if trip still goes
Apr 19, 2007 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
