Question about Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair
Fan only worked on 4 (high) now it blow nothing, what could it be beside a fuse?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 23 Answers
It may not sound like it is working as quiet or the projector isn't hot enough to warrant the fan
for protection i would just constantly have it on 4 to save projector from overheating
Posted on Jan 30, 2013
  • Joel C.
    Joel C. Mar 05, 2015
    The blower motor may have quit working or could be control switch is shot that turns blower on.
Blows heater fuse when trying to engaging 4 wheel high. Plus no drive lights lighting up on shifted panel on floor when in 2 or 4 wheel drive
Check connections and the switch on the 4X4, it obviously is powered by the heater fuse and nothing will work if the fuses are blowing cutting power to the whole system
Nov 26, 2013 | Cars & Trucks
Suzuki samuri won't blow on high
what year?
the fan will not blow on high has only 1 cause (besides wires )
1: the fans switch is bad
if others speeds fail the fan resistor is bad.
Aug 13, 2013 | Suzuki Cars & Trucks
Still waiting for an answer about my Chrysler 2002 Town & country. QUESTION : Fan won't blow when car is ideling will start after I start driving again.
I would need more info to give any advice.
I assume you mean the blower for the ac and heater.
How is it not working but works on high ?
And what power are you turning off that makes it blow harder ?
Jul 12, 2012 | Cars & Trucks
95 escort wagon, 118K miles - my heater fan stopped working the other day. checked the fuse box / diagram in the manual, it says that the blower fan takes a 30a fuse in position 15 (fuse box inside car);...
The dealership knows, but they won't tell you so you take it to them and they make the money doing the job!!
First of all, check that fuse. It may be blown. If so, replace it with a 30 amp fuse if that is what the owners manual or fuse panel states.
Now, about your problem, does your heater blow on low and high, but nothing inbetween? Or maybe even only on high, but none of the other settings? If so, it is your 'blower resistance module'. It is an electrical component located up under your dash board, possibly on the passengers side, up beside the fan blower itself. Find your fan vents where they come out the bottom of the dash and locate a black plastic box that resembles a relay. It will have a wiring harness attached to it, with about 4 or 5 wires. Take out the 4 - 1/4" or 5/16" bolts. Disconnect the harness.
The new one will probably have to be ordered in for you, around $30-$40. Try your local auto parts store or AutoZone.
Jan 10, 2011 | 1995 Ford Escort
Cool fan low doesn't work. Doesn't appear to be
It needs to have the blower motor resistor card replaced.
It still works on high speed because on the high setting the voltage does not go through the resistor.
The resistor is mounted beside the blower motor and is easy to replace.
There you are, thank you for using FixYa.
KL
May 01, 2010 | 2003 Saturn VUE
Why wont my heater or ac fan not blow in my car?
Check fuse panel for blown fuse first.
Dec 21, 2009 | 1995 Mercury Tracer
[Identical to earlier posting by stefeckstein]
Check for a circuit breaker on the back. If nothing, pull the plug and remove the case. Look for a blown fuse. If so, look for a shorted high voltage diode in the magnetron power supply or a shorted stirrer bearing located above or beside the cavity area where the microwaves enter. The stirrer is a metal fan-like device with a plastic bearing that often arcs internally. That shorts the microwaves out and blows a fuse. Replace the stirrer.
Aug 24, 2009 | Panasonic NN-SN657SMicrowave Oven
Ac only works blows out in 3/4/5 nothing in 1 or 2 ?? :(
have you tried getting an air conditioner filter? the low air might not work because there is so much dust debree. the high only works because it is able to blow through the debre
Jul 14, 2009 | 2003 Chevrolet Tahoe
Air Fan and Defrost only works on Position 4.
reostat broken,look in air income,locate,remove,look for fuse wire on the device,if electroic,replace all,
but initial problem is that the fan blower does not work well,take apart,clean and grease,
it makes the reostat burn when the fan does not start quick enough
Feb 13, 2009 | 2005 Nissan Pathfinder
I can't locate on either side of the fuse boxes as to whether or
replace blower motor resisteo located beside blower motor right side under dash has about five wires going to it.
Dec 21, 2008 | 1996 Pontiac Bonneville SE CA Value
Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair Logo
129 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
 Russ Hill
Russ Hill
Bill Boyd
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
