Question about Kenmore 24032\24036 Top Load Washer
Kenmore 700 Series - No drain/spin
I have a Kenmore 700 Series washer which, after one year of usage, has decided to not go into its drain/spin cycle. Does anyone know of any consumer maintenance I am able to do prior to having a Sears repairman come out and charge me out the yin yang?
After reading the issues with Kenmore washers and dryers, I may never purchase another. Should have learned from experience of their Calypso washer, which if you still have you will eventually have to ditch... and purchase a new washer.
Thanks in advance with any suggestions.
  • Bruce Denton May 11, 2010
    if this will agitate and do everything , but drain/spin..its most likely the lid switch let me know if this is the situation...Bruce
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 154 Answers
WOW, THIS IS AN EASY FIX, YOUR LID CONTROL SWITCH IS BAD, YOU CAN EASILY BYPASS THIS OR REPLACE IT, I THINK THE PART IS AROUND $25
Posted on Feb 07, 2010
  • 163 Answers
Lid switch is bad.flip the face back and you will see where the lid switch plug is at.you will need to tak the screws out before flipping the face back.
Posted on Mar 06, 2009
  • mike cooksey Mar 09, 2009
    lid switch is bad most likely.
  • 68 Answers
Something could be tangled around the agitator, like a gold chain or something small that could keep it from spinning or something could be stuck in water pump such as a baby sock that could keep it from spinning,
Posted on May 08, 2009
Kenmore elite 90 series 11028902790 fills w/ water & agitates. On drain cycle it won't drain unless you put drain hose to floor drain position. Drains water but will not start the spin cycle. Help
It is either a bad pump or a bad control. Call Sears. Hard for the homeowner to fix. If not in warranty, ask them how much to fix and then decide if the old one is worth the money. If the machine is 10 years old, go for a new one.
Jun 01, 2015 | Kenmore Washing Machines
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series: Clothes very wet after spin cycle
I do not have this kind of washer, but I had same problem with my washer and I found the drain trap was full not allowing washer to completely drain. Hope this helps, Good Luck!
Feb 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
Kenmore 700 series washing machine
check to see on the top of the basket if there is a balance ring it will look like a large doughnut if it has one and if it is loose or if the fluid in the ring has leaked out then this will cause the out of balance while in spin let me know if i can help 276 523 4434
Apr 25, 2008 | Washing Machines
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
2,314 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
