Dead harddisk my pc is not detect in my hard drive
  • 27,725 Answers
Is it a DESKTOP or LAPTOP ?
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 18, 2013
  • 52 Answers
SOURCE: not detect my 320gb hard drive why?
If this is an external USB drive, try connecting it to a different computer. If it works on another computer, it may be a problem with the USB controller on your computer. You may to reinstall the driver for this device. If it doesn't work on another computer also, it may be a problem with the drive controller in your drive caddy. You can purchase another caddy on ebay for around 10.00. You will need to know if the drive inside is IDE or SATA though. Hope this helps.
Posted on Aug 22, 2009
  • 256 Answers
SOURCE: unable to detect hard drive
try a different data cable for it or a different port to connect it to. also try to connect the drive to a different computer to isolate what exactly is causing the problem.
Posted on Apr 08, 2010
KingDWS
  • 1606 Answers
SOURCE: Transcend hard disk issue
The problem is the usb ports in your pc. You know the drive works and is properlly deteced on the laptop so you can ignore that.
IF you can try other usb devices in your pc usb ports and see if they work.If they don't at all then you either have dead ports or drivers are missing. You should see them listed under control panel system hardware.
If they work then I would wonder if the usb drive you have requires a differant usb port than what you have. There is a type 1 and 2 and type 3 which has just come out so we can ignore that one. A type 1 is slower and cannot power devices usually. A type 2 is faster and can power some devices. I don't know how old your pc is so it could be hardware, either failure or drives. You should also makre sure you have the service packs installed for windows. Sp3 is the latest version. There were some changes to the way usb devices were deteced in Sp2 if I remember correctly.
Posted on Apr 13, 2010
  • 11800 Answers
SOURCE: hard disk not detected
You can't do very much, the damage is already done. The only thing you can do is to remove the hard disk from the case, put it in a pc and try to access it from there - most likely you will have to use a recovery soft to get some of your files back. Once that's done test the disk for faults using HDTune, the free version. If it reports errors, even small ones, then it's dying (or already dead) - junk it and buy a new one.
Posted on Jun 01, 2010
muunlyte5608
  • 119 Answers
SOURCE: Transcend 120GB External Hard Drive
Do you have installation disc that came with the Trenscend External Drive?
Other wise visit this website bellow to search for your product and you find it drivers for download.
http://www.transcendusa.com/Support/DLCenter/index.asp?LangNo=0&Func1No=11&Func2No=182#L3
let us know if this solution works for you.
Thanks for using fixya.
Posted on May 17, 2011
HP MINI NO DETTECT HARDDISK
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 19, 2012 | HP Mini 1000 Netbook
GET MESSAGE INTERNAL HARD DISK DRIVE NOT FOUND ON INSPIRON 1545.
Do harddisk is detected in bios setting if no?? so ur harddisk got crashed??and you have to replace ur harddisk
Sep 08, 2010 | Dell Inspiron 1525 Laptop
My harddisk is detected but when ever i format it or try to install os it does not get detected a message comes please switch on the harddisk
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
replace them they are probably old and faulty ?
good luck
Sep 05, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Hard disk not detected
Jun 01, 2010 | Western Digital My Passport Essential SE...
HDD Maxtor 80Gb IDE: Harddisk error! At boot it say's Primary harddisk error. Press F1 to continue. *When I press F1 nothing happens. *When I go to the bios at IDE Configuration and hit refresh at Primary...
OK the only shot you got is to geta USB to SATA/IDE converter dongle, connect to another PC's USB port. Hopefully, you will be able to read it. Otherwise still plugged in you may be able to use recovery software and get you DATA back. Recover my files is one,
http://www.recovermyfiles.com/
Other freeware data recovery software GL.
http://www.freebyte.com/filediskutils/
Feb 15, 2010 | Maxtor Hard Drive
I've dropped my Western Digital 250gb hard drive & now its not working. The light on the device does light up & the computer recognises that something has been connected but you cannot see the...
I've similar problem with Samantha_500, i inadvertently dropped internal Harddisk (Seagate 80GB) with external case (M-Tech), the external case was broken into pieces (only the parts with plastic), the Harddisk is not working anymore, it detects by windows XP as a device connected in USB, but no drives detected in windows explorer. is there any way to recover this harddisk? thanks for the help in advance.
Dec 26, 2009 | Western Digital Passport WDXML800UE...
Is it possible to get the data of a hard drive that pc & laptop cannot detect
its possible to get data from harddisk of the pc, make sure you have connected power to harddisk and its data cable to your laptop so that it will be detected
Oct 19, 2009 | Dell Inspiron 1525 Notebook
PLEASE HELP !! I have a HITACHI Deskstar harddisk (T7K500 HDT725032VLAT80) and it has a clicking sound. The window won't detect this device at all. I got it out of the external enclosure and get a new...
If your drive is clicking and isn't detected by the operating system, your hard drive is VERY dead. There are no user replaceable part inside a hard drive. The only thing you might do is get the very same hard drive and swap the controller card from a known good hard drive to the bad hard drive but the chances of this working are VERY slim. I would resign myself to the fact that the data on that drive is very truly gone.
Nov 10, 2008 | Computers & Internet
Linux Not installing and Not detecting Harddisk
what version of linux are you using, suse, mandriva, fedora etc...
and which release is it (eg. suse 10.1... or whatever)
Dec 30, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
