Question about Sony PlayStation Office Equipment & Supplies
Printer Samsung ML-1910 red light on and will not print
First a green light then to red permanently. Have checked no paper blockage, all clear. Reseated toner cartridge. still the same
  • mikeandva619
    mikeandva619 Jan 20, 2013
    Computer says that the printer is not connected when it is and that the toner cartridge is empty when it's indicated a third full
  • 13433 Answers
SOURCE: I have a samsung ml 2851 nd that won't print, and
The counter needs to be reset most likely. I can\t locate a reset code & steps for you. Try calling samsung and ask about the toner reset you replaced the cartridge and its still showing the count from the old cartridge.
Posted on Apr 23, 2009
  • 214 Answers
SOURCE: red status light on. won't print,
Try this.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000071/HL5100_UG_ENG_3.pdf
Posted on May 01, 2009
SOURCE: Samsung CLP300 - All LED lights red and getting very hot when on
drl1069.dyndns.org/Public/CLP-300.pdf Ok above is your service and repair manual, inside is all troubleshooting procedures used by the engineers to troubleshoot and repair these units.
Posted on May 11, 2010
SOURCE: Samsung ML-2010 won't feed paper
This is a step-by-step process for replacing the tire (roller). Thanks to dizzyzuma for helping me get the right part and get the procedure down.
1: You will need to manually shut off the printer in the middle of printing in order to release the tabs. Put in a few sheets of junk paper and print a few blank documents. You want to shut off the printer using the switch in the back when the roller is approximately in this position:
2: Hold the down the two side tabs that are locking the tire into place and press down on the tire with your finger. It should pop off relatively easily.
3: Turn the printer back on. The tire will rotate around to its starting position, but it will now be unlocked. Turn the printer back off.
4: Rotate the tire towards you and unhook the two bottom hinges. It should come off without much force.
5: Replace the old tire with the new tire.
6: Re-insert the tire onto one of the bottom hinges and rotate it around so that both of the bottom hinges (tabs) are in.
7: While holding the back of the metal bar with your fingers for leverage, press firmly with your thumb to snap the tire back into place.
8: Turn back on the print. You’re good to go.
Posted on Jun 01, 2010
SOURCE: Hi have samsung ml 2240 printer top light is
its of Paper count problem. tourn of printer power and open the back cover and find the IC 366...... ita a small 8 pin ic just short Pin NO 1 And 4 just restart the printer ur problem has been resolaved
Posted on Jul 28, 2010
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
The online error light is red on my ML-1610 Mono Laser Printer any ideas how to fix this?
It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear.
Jul 16, 2010 | Samsung ML 1610 Laser Printer
On line error red light come on no printing
check for a paper jam. open it and pull the paper out then reinstall paper. close the from door of the printer and this will reinitiate the printer. the green light should come back on. If this doesn't work take out your cartridge and put it back in. close it up again and it will reinitiate the printer again.
May 28, 2010 | Samsung ML 2010 Laser Printer
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
Oct 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
Lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
My printer has two flashing lights
try to rest the printer by opening the front cover (not the paper tray) and closing it again.
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
626 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
