Question about Kenwood Ddx4021bt 6.1" Double Din Cd Dvd Bluetooth Ipod Usb Car Stereo
Kenwood DDX4021bt Won't Turn On
Hello, I have the Kenwood DDX4021bt installed in my Corsa and has worked both times since bought it and had it installed. However I just got in the car and it wouldn't turn on. I tried re-setting but that also hasn't worked. Any ideas? Many Thanks!
  • 78 Answers
SOURCE: kenwood 135
sorry about the delay I was on holiday, if you haven't solved the problem yet I would suggest that you check that you are getting both power supplies (red and yellow) and if not the first thing to do is check the fuses in the car. Let me know if your'e still having problems.
Posted on Apr 07, 2008
kenw392
  • 2226 Answers
SOURCE: Hi I recently bought
go into the menu. you should be able to scroll through the menu and turn demo off.
Posted on Sep 13, 2010
kenw392
  • 2226 Answers
SOURCE: I've been trying to put
Did you try pressing the seek up button after entering the code?
Posted on Jun 01, 2011
kenw392
  • 2226 Answers
SOURCE: Hello, my battery went dead
Try checking all of your fuses. There is also a fuse behind the radio itself.
Posted on Sep 21, 2011
  • 7 Answers
SOURCE: Kenwood car stereo face got wet and now won't work, how do i fix it?
If the unit is already fried you may try to soak it in the highest alchol % of rubbing Alcohol for a day then allow the unit to dry Which should happen within a day or so because of the evaporation rate of the alcohol. This should remove the internally locked water and allow for the unit to resume Function without internally shorting.
Posted on Jun 07, 2013
I have a Kenwood KDC - MP 828 that I bought from a friend and it's asking for an unlock code how do I go about this
Hello if you have the remote and the unlock key number
http://www.manualslib.com/manual/85987/Kenwood-Excelon-Kdc-X789.html#manual
Use the above link to the manual
If you don't have the remote you will need to get one as it is required to input the code
Need the code ask Kenwood ,the person you bought it from or take it to a local radio shack to get it read
Aug 14, 2015 | Kenwood Car Audio & Video
Hi, my corsa comfort 2004 model! Won't start, fuel
If the fuel pump works, the Relay is Working. But I have never herd of a corsa comfort
Oct 01, 2014 | Cars & Trucks
Kenwood 6.1 dvd screen won't turn on, but reset
It appears that you may have battery power but, no accessory power. Check you radio fuse in the vehicle and, behind the radio.
Feb 06, 2013 | Car Audio & Video
My kenwood kdu-u7053bt won't keep it's memeroy. Keep going to demo mode when I turn the car on.
go back to the stereo shop and make sure they connected the memory wire on the unit to a constant 12v source
Feb 03, 2013 | Kenwood Car Audio & Video
The kenwood KDC-MP333 in my truck is connected to a set of kenwood speakers. But when I turn it on they won't work the stereo still shows the display but when I turn the stereo on it makes a sort of...
Disconnect the speakers and try it with another speaker or speakers not in the truck. If it works, the speakers or the wires to them are messed up. If it doesn't you probably damaged the output capacitor in the radio by turning it on without speakers attached. Realize that the speakers are part of the radio circuit and act as resistance. Without them, there is no resistance and it puts a strain on the radio.
Jan 02, 2013 | Car Audio & Video
Kenwood prospero km262 stopped working
In my case, capacitor C1: 470nF (on the circuit board) proved to be the cause. It measured only half its normal value. It's part of a voltage divider used in place of a transformer. Replacing it solved the problem.
Came already across the same problem in another circuit.
Dec 02, 2012 | Kenwood KM800 Major Classic Stand Mixer
The back light won't turn on and the volume is turned all the way up but the buttons won't work for me to turn it down. I had to take the whole thing out
Assuming your deck is a kdc 516s the flexible cable that goes from the face to the main motherboard is probably bad. If you are not good at desoldering and soldering. , I would suggest you have it replaced by a professional.
May 06, 2012 | Kenwood KDC-516S CD Player
Kenwood kna-g610 map upgrade problems
Which Garmin update did you use?
The correct update is Garmin Part Number: 010-10679-13.
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Jan 08, 2012 | Kenwood Kna-g610 Car GPS Receiver
Kenwood Ddx4021bt 6.1" Double Din Cd Dvd Bluetooth Ipod Usb Car Stereo Logo
141 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
