Question about GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel
My oven door just exploded,, the outer window has shattered but leaving the inner intact,oven was off,,,,
Not sure if its this model,,waiting for landlord,, 6;00 am i was woken from my sleep to find glass shattered everywhere popping on my flloor,,,glass is still popping after 2 hours,,,, outer window only,,,inner still in tact,,Oven was off for min 12 hours,,??? please help
  • s barkers
    s barkers Jan 02, 2014
    don't know if you received a reply. bought my oven in april. used the self-cleaning for the first time and turned the oven off after 3 hours. when i opened the door the glass between the inside and outside is shattered!
    Sergeant:
    Champion:
  • 249 Answers
Can you find your stoves manual then look thew the manual to find the model number then
Posted on Jan 18, 2013
5 Suggested Answers
  • 1073 Answers
SOURCE: Exploding Door
replace the glass it has had a fracture to it in the production cycle at the factory
Posted on Jun 09, 2008
SOURCE: DCS gas oven locked
I let the door stay open, hold the switch closed with my finger, activated self clean. Let it run for a minute then hit cancel, the stove heating element shut off and the locked door blinked for 5 seconds then finally stopped. Back to normal.
Posted on Aug 23, 2008
  • 206 Answers
SOURCE: Replacing outer glass of oven door
This is glass because glass does not burn, does not melt at oven temperatures, and is a pretty good insulator. Also allows the cook to watch the cake rise.
I would not replace with anything but factor glass. Too dangerous, even regular glass is not properly treated to be safe in this environment.
The cash for clunkers gets extended to appliances soon, perhaps this makes a new one more affordable?
Posted on Aug 24, 2009
SOURCE: how do I replace the shattered glass in my GE oven door
No doubt this is a double paned glass panel. Two panes of glass with a divider strip separating the two for a "thermal break". Okay, you will need to remove the door from the hinges, and along the sides of the door, or possibly under the door gasket, you will find multiple screws that hold the two sandwiched halves of the door together. There should be a front panel, formed sheet steel, and an inner formed sheet steel panel which is coated with porcelin. When you have the front and back halves of the door separated, inside of one or maybe both of the panels you will find the clips, screws, or materials that hold this glass panel in place. Possibly it is in it's own frame, and the frame and glass both remove as one unit. Then it will be a matter of contacting Customer Service and Parts for your product, giving the Model #, Serial # and any other data that may be needed in order to replace the part with the correct one. Since this should be tempered glass, it will be quite heavy and at least 1/4" thick or so. The "thermal break" or space between the panes is so that heat does not transfer readily to the outside panel. Watch for any electrical connections for a door switch for the oven lamp, and be careful when removing the springs which allow the door to close and seal when in the closed position. And it might be helpful to take some photos of the disassembly process so that you can have a reference when you are ready to re-install the door. Be careful when removing the broken glass, and dispose of this carefully. Take your time, be patient, and don't force any thing, and you should be fine. Good lock. Kindest regards, Slats.
Posted on Sep 26, 2009
Can I still use my aeg electric oven if the outer glass is shattered I have company tomorrow and need to cook Christmas dinner the inner glass is still intact
Yes you can, in the emergency, but take care that the remaining glass will be at oven temp. You may want to shield it with a piece of plywood or stiff cardboard, taped on.
Dec 27, 2016 | AEG Ovens
HJA 3300 Diplomat Oven Door Issue
my inner glass door exploded while cooking at 200 degrees.
Aug 17, 2009 | Ovens
My over the oven model 665.61629100 kenmore has cracked door
The outer door frame CAN be replaced if you like. You can view an exploded view diagram at searspartsdirect.com. Just type in your model number and locate item 10 under the "Door" parts listing. The part comes in various colors so make sure you select the correct one.
The door can be easily removed by opening it all the way and lifting straight up at the hinges. The door will come off the hinge pins and can be laid on a flat surface for easier access. Place a layer of towels under the door to prevent damage to the door.
You will need to remove the door handle to get the outer door frame off. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you may need to purchase a new door.
The door handle screws are located behind the inner panel. Remove the door handle and and locate any screws that may be securing the outer door (front) frame in place. Once you install the new outer door frame, re-install the door handle and carefully re-insert the inner door panel. Gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
To answer your initial question, the microwave should continue to be safe to use as long as the inner door seal and door glass are intact. Make absolutely sure you reinstall the door components back together properly. Not doing so will render the oven unsafe to use. Refer to the web site I provided as a reference for how the door components go back together.
NOTE: This part is listed a bit cheaper at appliancepartspros.com. Use the part number from the first website I mentioned as your search criteria.
Jul 30, 2009 | Microwave Ovens
Glass is shattered to to replace
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
dd5ebd3.gifclick here
Inner Door Glass
May 15, 2009 | Maytag MER5765RAW / MER5765RAQ /...
Outer oven window shattered
sure should be replacable, youo can cll the manufacture for a replacemnt glass, most only held in by a feww screws, cant see it being the end all for you oven
Dec 22, 2008 | Kitchen Ranges
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Broken glass front panel
Have the make and model number and contact any appliance parts supply, they can order the glass. or call a service man who can do it.
Nov 01, 2008 | Ovens
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Nov 20, 2007 | KitchenAid KGST307 Gas Kitchen Range
GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel Logo
207 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
