Question about LG LSC26905TT Side by Side Refrigerator
Filter bypass for lsc26905TT
I want to connect my RO water supply and remove filter from this refrigerator and use some sort of bypass. Does anyone know where to find a filter bypass for this model?
TIA!
  • Anonymous Mar 14, 2014
    Is there a bypass plug for this model?
  • Anonymous Mar 29, 2014
    Can I just remove the filter and leave out? I cannot find a bypass plug for this!
  • LG Master
  • 909 Answers
Locate water filter bracket(normally in fridge compartment), then use screwdriver to remove from the frame. You will see two plastic pipes connected to this bracket. one will be water in and the other water out. pull the two off the bracket and join them together. (be inventive). Connect your RO system to the main inlet after original water supply is removed. Remember, your "filter to be replaced" light will still flash after a period as the fridge has its own software, counting depressions for cartridge replacement. (you would painstakingly have to reset.}
Posted on Jan 30, 2009
My water tank in the back of the drawer is empty. I removed the filter and pressed the water lever in the door and water comes out from where the filter was. I replaced with cap that came with the side by...
The filter head sounds like it may be defective, the bypass plug allows the water to pass through the filter head to the tank and on to the fountain. You can also try a new filter as the filters can be defective too. Pleazer Appliance....
Dec 10, 2014 | LG LSC26905TT Side by Side Refrigerator
Whirlpool ed25rf can I remove water filter?
You CAN just bypass the filtration system, BUT, you're going to have mineral deposits buildup in various locations over time. If that's not a problem for you, then TAKE OFF OSMOSIS SYSTEM, and just extend the hose that goes into the filtration system---- to the hose that exits the system, connect the two, and that's it, all set. Make sure all your hose connections are secure, so you don't get leaks, or flood your floor. You could put in an activated charcoal sytem, which will take out chlorine, other chemical contaminants and give much more water per minute than a RO system, if that's your reason for wanting to remove it. You could easily use your existing RO unit, merely remove the RO membrane filter, and bypass it, and that would use all the other filters it has, without slowing the water flow excessively. Also, it will, NOT take out any minerals, or heavy metals or viruses, like the RO membrane will do, but the water flavor is more how most people like.
Sep 22, 2012 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
We just had a new RO Unit installed at our sink, and a line run to our Maytag fridge. The water filter is inside, at the top. We don't really need the filter anymore, as the RO water is more tha
Take the filter to the hardware store and get the necessary fittings (and maybe a short piece of tubing) to connect the in and out lines without the filter. Perhaps easier deal is a new filter which should NEVER become clogged on RO water.
Aug 02, 2017 | Maytag MSD2734GE Side by Side Refrigerator
I am installing a reverse osmosis system in my home and need a "dummy cartridge" part to replace the water filter that is in the refrigerator - PureSource RG-100 and how do I get it?
hello.
i know such thing exist but i am having a hard time finding a part number for it. A alternative would be to in essence bypass the ref.filter this way.
The water line on the back of the refrig where the house plumbing connects to feeds directly into the filter first then out of the filter into the water valve to be dispensed to icemaker and door dispenser.you could connect the water supply from the RO system directly to the water valve instead of connecting the RO to the inline refrig filter.
Gene
Aug 06, 2011 | Frigidaire PLHS237ZD Stainless Steel Side...
Water overflows from icemaker & freezes in the freezer. Makes three ice cubes in a day & the water is extremely slow to fill glass from freezer door!
If both the water in door and ice maker are experienceing slow water problems the common point is the water supply itself.
This can be caused by:
1. Water supply shut off valve is partially closed or blocked with debris.
a. TURN water supply OFF
b. Remove the water line from the rear of the refrigerator ABOVE the in line filter (if one is installed)
c. Place the removed line into a bucket.
d. Turn on water supply and check flow. It should fill an 8 Oz glass in about 8 seconds.
If it passes this test then the water supply is fine. If it FAILS this test either cflear the obstruction in the line or replace the water supply valve from the house connection.
Test 2 (Water supply is OK
Reconnect water supply to external in-line filter (If installed) or water valve assy connection.
Your unit has a Verticle filter that if it is clogged will cause slow water flow.
Test water thru the door for the same amount of water flow. It should fill an 8 Oz glass in 10 seconds or less.
If it does ot do this then the VERTICAL internal water filter is clogged. (5 months or 500 Gallon change interval)
REPLACEMENT filter is PN LT500P but there are several like / suitable aftermarket replacements for the LT500P number.
As for the ice maker freezing up. There is only one cause for this and that is the water valve assy itself is bypassing water when it is supposed to be closed. The only remedy for this is to replace the water valve. They are not repairable.
The valve is available through sears parts direct:
http://www.searspartsdirect.com/partsdirect/part-number/LG-Parts/Refrigerator-Parts/5221JA2006D/0046/795/Model-LSC26905TT/3204/0165000?keySuffixId=NA&productTypeId=x&searchModelNumber=LSC26905TT&subCompDesc=Ice/water%20parts&brandDesc=LG&modelDesc=REFRIGERATOR&blt=11
Thanks for choosing FixYa.
Kelly
Sep 19, 2010 | LG LSC26905TT Side by Side Refrigerator
I need a bypass filter for my Frigidaire refrigerator, Model FSC23F7DSB. I have an RO unit pumping water to the frige but hte filter in the refrigerator is doing two things. First it is contaminating the...
I looked for a bypass for your models but none listed . just remove the cartridge. this should work. you could also by pass the filter by connection the two lines lik they do on water softners. . valve or connector in back .. now a word to the wise . they do not recommend hooking the frig up to r. systems as the do not produce enough pressure to the main valve to shut if off ( sometimes ) thus causing a flood . if you do use 3/8 or better line size . this will help .. **** . hope this helped . mm
Dec 23, 2009 | Frigidaire FRS26R4A Side by Side...
I changed the water filter and now the water is not working
For LG LSC26905:
If you replaced the water filter cartridge on the dispenser due to a filter replacement indicator appeared on the display, press and hold the lock button more than 3 seconds to reset the filter timer.
Make sure the water supply line is open.
Nov 07, 2009 | LG LSC26905TT Side by Side Refrigerator
Insall water filter
there are lots better filters then the ones that go into the fridges install an inline filter into the water line before the fridge that way you filter both the drinking water and the ice maker any hardware store will have them usually your water supply is tapped into the cold under your kitchen sink this is a good place to put the filter if you are connected there
Apr 22, 2009 | LG LSC26905TT Side by Side Refrigerator
Water leak from front door water supply
IF YOU HAVE IT HOOKED TO A REVERSE OSMOSIS WATER FILTRATION SYSTEM, YOU SHOULD REMOVE THE FILTER CARTRIDGE AND OBTAIN A BYPASS PLUG. IF NO RO UNIT, YOUR WATER VALVE IS MORE THAN LIKELY THE CAUSE. BEFROE CONDEMNING IT THOUGH, MAKE SURE YOU HAVE GOOD WATER SUPPLY AND PRESSURE TO THE REFRIGERATOR AS THE VALVES RELY ON WATER PRESSURE TO SHUT OFF AND SEAL.
Jan 27, 2009 | Frigidaire Refrigerators
LG LSC26905TT Side by Side Refrigerator Logo
470 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
