Question about Acer Aspire 9410-4317 Notebook
Cannot change boot order in bios
I need to change the boot order in the bios on my acer 9410. During recovery using the acer discs the proscess failed. When I went into bios the system is user mode and now I cannot change the boot order so I can boot from cd drive.
  • Anonymous Mar 28, 2014
    how do i change bios boot order without using f5 or f6
  • 520 Answers
Dont know how many times Ive told people that recovery disks are not worth a w""k...
you can still enter bios so can you not choose reset to default.
default settings will detect bootdisks.
other than that you will have to remove the rtc battery..
on some models its located in the mem compartment but in most you have to partially strip down pc to access motherboard..it looks like a large digital watch battery...you need to remove it for a minute or so then replace ..reassemble pc and reboot...there is software to do this but unfortunatly you need the use of the cd as its a bootdisk.
next time you want to recover use xp disk or install recovery software..if you want recovery software for future and lets hope its the near future let me know and I'll give you link for it (send me ur email)
Posted on Jan 25, 2009
My satellite Toshiba L875D-s7230 says bootmgr is missing press ctrl alt and delete to restart and does nothing
Which operating you are using?
Method 1: Run Startup Repair from Windows Recovery Environment (WinRE) To run Startup Repair from the Windows Recovery Environment (WinRE), follow these steps:
  1. Insert the Windows installation disc into the disc drive, and then start the computer.
  2. Press a key when the messagePress any key to boot from CD or DVDappears.
    If your PC does not detect the media automatically
    1. During the restart process, read the screen for any instructions that explain how to interrupt normal startup and enter the basic input/output system (BIOS) setup utility. Most PCs use the F2, F10, ESC, or DEL key to begin the BIOS Setup.
    2. Look for a tab in the BIOS Setup Utility that is labeledBoot Order,Boot Options, orBoot. Following the directions on the screen, use the arrow keys to go to theBoot Order, then press Enter.
    3. Locate the CD, DVD, or USB flash drive (this might be called Removable Device) in the Boot list. Following the directions on the screen, use the arrow keys to move the drive up so that it appears first in the Boot list. Press Enter. The boot order sequence is now changed to boot from the CD, DVD, or USB flash drive.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYes in the confirmation window. The PC will restart.
  3. Select a language, a time and a currency, a keyboard or input method, and then clickNext.
  4. ClickRepair your computer.
  5. In theSystem Recovery Optionsdialog box, select the drive of your Windows installation, and then clickNext.
  6. At theSystem Recovery Optionsdialog box, clickRepair your computer.
  7. Click the operating system that you want to repair, and then clickNext.
  8. In theSystem Recovery Optionsdialog box, clickStartup Repair.
Method 2: Rebuild the boot configuration data (BCD) from Windows Recovery Environment (WinRE)
  1. Put the Windows installation disc in the disc drive, and then start the computer.
    4. Press F10 to save your changes and to exit the BIOS Setup Utility. SelectYesin the confirmation window. The PC will restart. Allow the PC to restart normally. The scan will take a few minutes and remove any malware that may be infecting your computer.
  3. Select a language, a time, a currency, a keyboard or another input method, and then clickNext.
  5. Click the operating system that you want to repair, and then clickNext.
  6. In theSystem Recovery Optionsdialog box, clickCommand Prompt.
  7. TypeBootrec /RebuildBcd, and then pressENTER.
Jan 20, 2017 | Toshiba Computers & Internet
Brought acer travel mate back to factory using recovery discs now it wont reboot.I put discs back through with no result
Check the bios settings, in boot settings you must set CD unit as first boot device, then you start PC with recovery disk 1 inside.
Sep 05, 2008 | Acer Computers & Internet
Boot cd acer AX3400-B3802
What operating system is on this machine ?
What do yo see after booting up ?
1. If it is not booting up and you do not see the selftest screens and it gives a number of beeps then shuts down: count the number of beeps, that can tell you what is wrong.
2.If it is finding a harddrive but then gives a black screen which says something like "operating system not found, insert disk" or "grub error, run grub recovery" then you might need a cd or usb drive to boot from.
You might try Acer's e-recovery if you had that on your computer:
https://www.youtube.com/watch?v=H2xoMEPfiPQ
Else look here for Win 7 answer:
http://www.tomshardware.co.uk/answers/id-1751047/copy-boot-disk-win.html
Note on the link to Microsoft the answer of Andre da Costa.
At a friends computer:
1. download the iso
2. burn a cd disk using the program Imgburn as Andre says.
Then run it on your computer:
NB. you might first need to change the boot order in the BIOS, press DEL or F10 (the right button is displayed during the selftest on screen somewhere) find BOOT ORDER or POWER UP ORDER in the BIOS and put CD drive in first position
Look here for what to do:
http://windows.microsoft.com/en-us/windows/what-are-system-recovery-options#what-are-system-recovery-options=windows-7
open the 3rd option:
To open the System Recovery Options menu using the Windows 7 installation disc or a USB flash drive, or a system repair disc.
If you have reinstalled the operating system and Microsoft Genuine Check gets bothering you: call Microsoft support and explain that you had to reinstall due to harddrive failure, you will be given a new key for your windows. I have done so several times after hardware failures and reinstalling, they always have given me a new key. But you will have to make clear it was due to hardware failure, f.i. new motherboard, harddrive failure.
Jun 28, 2014 | Acer AX3400-U3032 Desktop - Black...
I losted my operation system, so I installed a windwon 7, now I want get my old opreation system back which is homevista, cani get it bac now?
When you first bought your PC or laptop, you would have been prompted by Windows Vista to create recovery discs, either CD or DVD. If you did this and still have the discs then you can simply put the recover disc into your DVD drive and re-boot the PC from the DVD drive (you may need to change the boot options in the BIOS or via a function key at boot-up).
If you did not create any recovery discs then there is a small possibility that there is a recovery partition on the hard drive. During boot-up, look at the text on the screen that tells you which button to press to get into the BIOS setup utility. There may be an option to start the recovery process, which would access the recovery partition.
If you have not got the recovery discs or a recovery partition then you will need a Windows Vista Home installation disc. The product key should be on a label on your PC or laptop.
May 26, 2011 | Acer Computers & Internet
How do you restore the factory settings on the acer aspire 5532?
Well, first acer brand is cheap, and they don't give you a factory restore disc or a restore partition drive like most other laptop. However they give you the option to make a factory restore disc yourself, there is a program in the laptop ( browsing through your start task bar) should be a program such as acer recovery management, from there on use that program and make a retore disc. Once disc is created, you can go ahead and procced to restore your laptop in which you need to change your boot option to disc during startup of the laptop in order to boot from the recovery disc you just made.
Apr 17, 2011 | Computers & Internet
How to restore my acer aspire 6920 to it's original setting?
http://acer.custhelp.com/app/answers/detail/a_id/161
In order to recover the Operating System using Acer Recovery Media please perform the following:
  1. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. Using the keyboard arrow keys, arrow over to Boot.
  3. Refer to on screen instructions to set the first device to CDROM.
  4. Press the CD-ROM drive eject button and insert the System CD.
  5. Close the CD-ROM tray.
  6. Press the F10 key, and then the Enter key to save the changes and reboot the system.
  7. The computer will boot from the Acer Recovery Media, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media they may be purchased at our Acer Recovery Media Order Form.
Dec 01, 2010 | Computers & Internet
How to install windows in acer emachine 350?
If you want to use the recovery partition its usually pressing ctrl+f10 or alt+f10 while booting up the machine. if you want to use a cd, you have to change the boot order. access the bios during boot (screen tells you which button to press)change the boot order to set the cd/dvd drive as 1st device, press f10 to save and insert the windows cd.
Oct 02, 2010 | Acer Computers & Internet
My acer aspire 5920 is in chinese and i need to know how to change to english
use your XP install disc (or Vista or whatever OS you use) to boot up your laptop and do a Repair Install. Usually you will get a prompt to "Boot from CD by pressing any key." during the power up of your laptop. If you dont get that option, reboot and go into BIOS and change your boot order ie have the CD drive as first boot option followed by your hard drive. Then try booting again with your XP disc in the cd drive.
You can change the language to English during a Repair installation but you may have to re-enter your serial number and activate again on-line again.
Cheers,
Steve
Aug 21, 2010 | Acer Aspire 5920-6727 Notebook
Cant restore acer netbook back to facotry settings did not do backup when purchased
Recovery procedure for Acer netbooks.
Important Information
The Recovery disc will help you to restore the hard drive with the original software content that was installed when you purchased your notebook. Follow the steps below to rebuild your hard drive. Your drive will be reformatted and all data will be erased. It is important to back up all data files before you use this option.
Restoration procedure:
1. Press the power button to turn the system on.
2. Select to boot from a USB optical drive. There are two ways to do this:
2.1. Press <F2> during the Power-On Self-Test (when the Acer logo is displayed onscreen after bootup) to enter BIOS Setup.
2.1.1. Select the Boot menu.
2.1.2. Refer to onscreen instructions to set the first device to any bootable optical disc drive.
2.2. Press <F12> during the Power-On Self-Test (when the Acer logo is displayed onscreen after bootup), and select the USB ODD from the list that appears.
3. Ensure the Recovery disc is in an external (USB) optical disc drive, and exit the boot selection menu, by selecting Exit Saving Changes from the Exit menu or pressing <F10>, or by pressing <Enter> as appropriate.
4. Select Exit Saving Changes from the Exit menu or press <F10>.
5. Follow the onscreen instructions to complete the installation process.
6. When you finish the recovery process, please remove the Recovery disc and insert the System disc again.
7. Restart your computer.
Create a Recovery USB device
You will need a second computer with an ODD to complete this procedure.
1) Insert the Recovery CD into the optical drive. Plug in a USB/flash drive with a minimum capacity of 1 GB.
2) Enter the BIOS setup and set the first boot device to the ODD. Save the changes and exit.
3) Allow your computer to boot up.
4) From the list of options, select "install2usb".
5) You will see a list of available disks, select the USB drive you plugged in.
6) Click the next button to complete the procedure.
7) Remove the USB ODD and USB/flash drive. You now have the Recovery system stored in your USB/flash drive, for future use if necessary.
Apr 23, 2010 | Acer Aspire One Netbook 8.9" Notebook
How do i restore my acer laptop to factory
Select models have the ability to have the operating system reinstalled from a hidden drive built into the netbook. To start the Acer eRecovery:
  1. Tap the Alt and F10 keys togther during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. When prompted with a boot screen, hit the Enter key.
  3. After the Acer eRecovery program has loaded follow the prompts to reinstall the operating system.
If the ability to reinstall from the previous method is not available or fails during the recovery, recovery of the operating system will need to be from Acer Recovery Media. In order to recover the system using Acer Recovery Media an external optical disc drive is required.
  1. Press F2 to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. Arrow over to "Boot".
  3. Ensure that the external optical drive is plugged into a USB port.
  4. Refer to on screen instructions to set the first device to "USB CDROM".
  5. Press the CD-ROM drive eject button and insert the System CD.
  6. Close the CD-ROM tray.
  7. Press "F10", then press "Enter" to save the changes and reboot the system.
  8. The netbook will boot from the Acer Recovery Media, follow the prompts to reinstall the operating system.
Please rate!
B_R
Jan 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
Open Questions:
Acer Aspire 9410-4317 Notebook Logo
189 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
