Question about Keurig B31 Mini Plus Brewing System
The brewer light will not flash automatically
After filling with water & pulling down the handle, the brewer light does not flash blue to begin the process.
  • 1,511 Answers
Not engaged all the way. Press down Firmly.
Posted on Jan 31, 2014
3 Suggested Answers
  • 60 Answers
SOURCE: After filling with water, plugging in, and
Call Keurig 1800 Cup Brew
Posted on Mar 23, 2010
heatman101
  • 43501 Answers
SOURCE: brewer not filling complete cup,
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on May 14, 2011
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
May 12, 2015 | Bloomfield 8571 Coffee Maker
K75 brand new filled with water blue light flashes but will not dispense or heat up
Handle may not be completely down and make a positive contact. Open and close again, press firmly on the handel and it should start up.
Feb 01, 2014 | Keurig B70/K75 Coffee Maker
Filled with water but blue light flashing says add water
Remove the container, take out the Filter, put two cups of water in the container and shake well for a few minutes. Wipe dry, and without the filter, replace and fill to max line. With out Kcup, try a run and see if you get hot water to flow. The Handle must me down and firmly in place to do this procedure. Flush a few times, and now you replace the filter, water, and Kcup. Try that. Use Distilled Water!
Getting the message "prime" and blue light is
heatman101
Apr 15, 2011 | Keurig Platinum B70 Coffee Maker
While trying to run through the set up steps, both the Small Mug and Large Mug buttons stay blue rather than flashing. After switching to a dedicated outlet, the Small Mug button finally started flashing,...
I just bought a Keurig Elite B40 Coffee Maker myself, had same issue, Caledl Keurig support, problem solved in seconds. Seems an import step was left out of instructions. The step before the blue lights flash, RAISE THE SILVER HANDLE ALL THE WAY UP AND THEN CLOSE. According to Keurig this tells the brewer that a human is present and aware the brewer is running, a safety feature. Be sure you have a cup in place.
Mar 08, 2011 | Keurig Elite B40 Coffee Maker
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Two blue lights stay on, neither activate the water.
if you are talking about the flashing blue lites, that means tank need waters..if you have water in it..
re seat the tank.. also
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 22, 2010 | Keurig Elite B40 Coffee Maker
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Reservoir heats but won't dispense
If you are pouring water in the manual brew basin, then check the sprayhead holes, then the spray tube, those could be blocked. If using the auto brew, check the solenoid and or brew switch.
Apr 26, 2010 | Bunn 12 Cup Coffee Brewers with 3 Lower...
Keurig elite b40 cup lights don't flash. Both are illuminated solid.
Lift the handle to open the k-cup holder and then close it back up. The coffee mug lights should begin to blink for you.
Nov 27, 2009 | Keurig Elite B40 Coffee Maker
Keurig B31 Mini Plus Brewing System Logo
147 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
