Question about Carrier Furnace Control Board Bryant HK42FZ034
Wiring diagram for bryant 80 furnace - Carrier Furnace Control Board Bryant HK42FZ034
Bryant plus 80 furnace no fan/ operation , yellow constant flashing light code , power to furnace was rerouted during remodel and since then furnace stopped working. Any suggestions ?
You need to have/ know the "fault code" chart for that specific furnace. Count the number of flashes and refer to chart. Look on the inside of the furnace blower door or other panel. Also look up on internet and print it off. If the furnace was allowed to run during the remodel it voids the warranty automatically. Read the installation manual.
Try resetting the electronic board by turning the power off then back on.
Mar 29, 2017 | Bryant Heating & Cooling
WIRING DIAGRAM FOR BRYANT 127ANA036-A
The blue wire from the Ac goes to the y2 on the board for the furnace the yellow and brown goes to c on the board for the furnace and the last wire goes to y1 on the board for the furnace
Jun 16, 2014 | Bryant 462AJC021BA Air Conditioner
Why is my furnace filter dirty after 3 days
depends on what you are calling dirty which is relative to each person
Are they so dirty they are clogged or do they just have dust on them
IF they are just dusty then that is normal and it is being pulled from inside the house
If you have a pet door that will cause a lot of dust
The only other way is if there is a hole in the attic or your return air somewhere
Feb 26, 2013 | Bryant Gas Furnace Legacy-310AAV Plus 80...
Carrier furnace HK42FZ011 wiring diagram
carrier plas 90 bryant Gas Furnace wont light - LED has 2 blinks what can be
Dec 25, 2012 | Heating & Cooling
Bryant plus 80 heat exchager is cracked, i'm looking for a replacement heat exchanger
Hate to tell you but heat exchangers are hard to match up. Unless it is relatively new then in most cases they have a warranty of 10 years. So you will have to replace furnace. You might be able to find a used furnace or go to web site and enter model number of your Bryant to get replacement.
Oct 23, 2010 | Heating & Cooling
From the furnace what are the blue, white, green, red wires
here's a link to a wiring diagram which is pretty standard.
http://ingramswaterandair.com/images/HCD1%20AC%20Models%20Installation%20Manual.pdf
Color what it does terminal
Blue 24V common C
White to heat control (gas valve) W
Green manual fan operation G
Red 24V power to thermostat R
Yellow activates comp during cooling Y
Sep 27, 2009 | Bryant 462AJC021BA Air Conditioner
Wiring to bryant furnace/ac
your t-stat maybe now not talking to the furnace remove it temporarily to check
Apr 09, 2009 | Honeywell Electrical Supplies
Why Wont My Bryant Furnace Stay Running
Look on the blower door panel in the wiring diagram there should be a flash code but it sounds like the flame sensor is not picking up the flame and you may be able to clean it
Oct 28, 2008 | Heating & Cooling
Carrier Furnace Control Board Bryant HK42FZ034 Logo
79 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
