Question about HP LaserJet 4345mfp All-In-One Printer
Hp 4345 printer
Error code 49.ff03
  • 66 Answers
SOURCE: sir my prinetr mfp 4345
This is a firmware error. Switch off and on the printer. Upgrade the firmware. Try printing from different documents and applications.
Posted on Dec 23, 2008
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
  • 21 Answers
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
Posted on Jan 07, 2010
indus3
  • 212 Answers
SOURCE: I get an error in HP LaserJet 4345 MFP printer,
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
Posted on Apr 21, 2010
brett207
  • 231 Answers
SOURCE: Error 49 Cycle Power FFF
49 errors are possibly one of the most difficult to diagnose.
49 Indicates that a firmware error occurred that caused the processor on the formatter to abort an operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor quality parallel cables, poor connections, or home-grown applications.
On some occasions, the formatter is at fault, but this is usually
indicated by a 79 Service Error.
I see you state a 49FFF? any other letters or digits displayed?
Specifically 49 FFFF can be a problem if the ribbon cable from the DC controller to the interconnector board is not connected. The control panel display will also be dark.
Other 49 FFx errors can be:
NEC firmware chip error - replace the Firmware
Unsupported EDO Memory installed - Remove unsupported RAM
Fuser life test error during Boot cycle - Replace the Formatter
A Large print Job (>800 pages) or complex graphics can cause the device to quit printing. - Simplify the Print Job, lower DPI etc.,
Good luck
Posted on May 03, 2010
Hp 4345 49. 4c18
99% of 49 errors are caused by outdated firmware, which is the operating system of the printer. Go to http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=415205&lang=en&cc=ca and download the current firmware. Select Windows 7 32bit as the firmware files there will install from any operating system. Also ensure that you have a 4345 and not an M4345, as they are different machines and use different firmware. Follow the instructions to install on your printer. I recommend the Easy Firmware Updates as it works all the time whereas using the RFU method can often result in a time out error, if your existing firmware is too old. Be patient, if your existing firmware is too old, it can take a long time to install. The only other catch is if you have a print job stuck in your printer queue on your PC you will need to clear that first so you can install the firmware as the printer must be at a ready state for the upgrade to work.
Oct 01, 2016 | HP Office Equipment & Supplies
How to fix Error 60.02 for hp 4345
Easy steps to fix Error Code Clr20r3 occur in HP Computer/Laptop/PC on Windows OS by dialing HP Customer Support Phone Number 1-844-355-5111 (toll-free) with the help of customer support services.
HP Customer Support Phone Number 1 844 355 5111 HP Help
Sep 08, 2015 | HP Office Equipment & Supplies
My HP LaserJet CP4025 has a device failure screen and error code 49.FF03 what does this mean? It will not do anything.
The first course of action with any 49 error is to get the newest firmware installed, if the machine will come to a ready state. Unplug any USB or network cables and power cycle the printer. If it comes to ready, check any computers configured to print to ensure that no stale print jobs are stored in any print queues. (this is an important step, double check that all workstations are cleared). Once you are sure you have all queues cleared, plug the network or USB cable back in and see if printer stays are ready. If it does, go to HP.com and download the current easy firmware installation file for the 4025 and follow the instructions to update the firmware. If the machine will not come to ready even with network/usb cables disconnected then you may have a bad formatter or faulty memory on the formatter.
Oct 06, 2014 | HP LaserJet Office Equipment & Supplies
49.4 C18 laserjet 4345
49.XXXX is a fatal catch-all error. Could be firmware problem, network, print job. If the error occurs when you try to print, clear the print queue. If the error occurs when the printer is just sitting idle, reseat the formatter. Try powering on without the network cable attached. If it still happens replace the formatter. Could be a corrupt print job being sent to printer. Print something else.
Mar 28, 2014 | HP LaserJet 4345mfp Printer
ERROR 49.FF81
From HP support forum possible defective hard drive.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-Setup/M3035-MFP-49-FF81-Error-Code/td-p/1272713/page/2
you may be able to disconnect the drive to get the printer operational,
but you lose some functionality
49 errors are communication errors with other devices in printer.
Mar 20, 2014 | HP LaserJet M3027 MFP Printer
I get an error in HP LaserJet 4345 MFP printer, 49.ff95 error, Tunr off and the turn on
Apr 21, 2010 | HP LaserJet M4345 MultiFunction Printer
Sir my prinetr mfp 4345 so printer problem 49.FF95 error code
Dec 23, 2008 | HP LaserJet M4345 MultiFunction Printer
HP LaserJet 4345mfp All-In-One Printer Logo
149 people viewed this question
Seeker5211
Seeker5211
