Question about Samsung Refrigerators
Samsung sr-l629ev temp light flashing. what does this mean?
3 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: Samsung SR-L3916BSS. Replaced fan blades. Switched
Why did you replace just the fan blades. If the fan wasn't working it could be the fan motor or the motherboard if you have one.
Posted on Aug 20, 2009
caroldon
  • 17129 Answers
SOURCE: for Samsung Refrigerator SR-L629EV my freezer
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Posted on Jul 19, 2011
Freezer temp light flashing and freezer and fridge have both defrosted. What the matter with it
Seems like you have Problem in Defrost timer (fixed near the Compressor or may be on the top back-side of the refrigerator). Replace it, problem will be solved.
Oct 02, 2015 | Samsung Refrigerators
For Samsung Refrigerator SR-L629EV my freezer
Jul 19, 2011 | Samsung RF265AA Bottom Freezer French Door...
Samsung SR-L3916BSS. Replaced fan blades. Switched on. Green light on temp ref flashing no other activity. Any thoughts please
Aug 20, 2009 | Refrigerators
Flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
Mar 25, 2009 | Freezers
Flashing temp on freezer door
take and press the two top buttons on the control panel and reset the unit. it appears the the freezer is not operating properly and may by frozen up
Mar 21, 2009 | Samsung RS2534 Side by Side Refrigerator
Cant reset temp after appliance was switched off
sounds like a bad board unplug for few minutes see if it will reset if not will need to be serviced
Mar 18, 2009 | Refrigerators
Refrigerators Logo
50 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
