Sound reproduction chocking coming
Sound chocking
  • 7,627 Answers
"sound chocking"? Can you be a bit more clear?
Posted on Jan 18, 2013
What to asexual reproduction mean
Asexual reproduction is a type of reproduction by which offspring arise from a single organism, and inherit the genes of that parent only; it does not involve the fusion of gametes, and almost never changes the number of chromosomes.
Asexual reproduction - Wikipedia
https://en.wikipedia.org/wiki/Asexual_reproduction https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=What+to+asexual+reproduction+mean
Dec 09, 2016 | Cars & Trucks
All my records sound really modulated skipping the pitch on longer notes and higher end vocals. It is pretty much brand new, any ideas pleaseeee????
I suggest you begin by ensuring the turntable and tonearm are as near perfect as you can. The reproduction of sound from vinyl depends first and foremost on the operation of the mechanical components.
The correct stylus fitted correctly with the weight of the tonearm adjusted to the recommended value for the cartridge. There should be no friction vertically or laterally in the arm travel, though some high quality types are fitted with hydraulic dampers.
It is also essential the turntable runs smoothly at a consistent speed. Vinyl purists have all sorts of ways of checking the turntable speed is correct. Most turntables have rubber belts or wheels in the drive from the motor and a defect can ruin the quality of the reproduction.
Owning a turntable for vinyl reproduction is a suitable hobby for a keen amateur mechanic...
Once you are satisfied the mechanical components are in good order and functioning correctly there is only the electronics to consider.
There are two approaches. One involves putting a known good signal into the input of your record player amplifier and the other involves using the output from your turntable into a known good amplifier and speaker system.
These steps involve opening up the case of your record player and making and unmaking various connections.
Mar 05, 2016 | Crosley CR49 Traveler Portable Turntable...
I have a presser washer Coleman power mate motor. The intake value was stuck. I pulled the head and cleaned the old gas off that had stuck the value open. It runs now but only on half chock. It runs great...
Sounds like the carb needs to be adjusted by someone that knows how to repair engines. Note: if the carb is set too lean, it will damage the engine.
Jun 07, 2014 | Electrical Supplies
How do I turn off the microphone?
go to the lower right of your screen, right click on the speaker icon there and choose Reproduction Devices option, a window should come up and search for "Recording" tab/option. After you select it, a microphone option should come up. disable it and you'll stop listening to the mic. It should still be ready to record, but it wont come out from your speakers.
Oct 19, 2012 | Acer Aspire AS5336-2524 Laptop
Only runs with chock on
sounds like a dirty jet inside the carb
Jun 08, 2012 | Yard Machines 155 Torque Briggs Stratton...
How is the female reproductive system different from male reproductive system?
Females produce Ovum ( Egg cells) Males produce ***** cells Philosophically males and females are each half of the same reproductive system.
Please post in the right category,
Jun 08, 2011 | Computers & Internet
I have an panasonic pt-ae2000e projector, how do i get sound?
The sound must be sent to an external amplifier system and speakers.
Audio cables must be connected from each peripheral device directly to the audio reproduction system
Mar 21, 2011 | Panasonic PT-AE2000U Projector
Refrigerator will not cool after it was restarted, the motor and lights are both working but there is no cooling or freezing in spite of being on for 2 hours now
No gas or chocked system. Check first compressor is working. Then, Check by keeping your hand on condenser coil (discharge line) if no warm-gas leak.If warm, hear any whistling sound in freezer. If no whistling sound system chocked.
Gas leak/chocked system can be rectified by leak test, flush out the system, vacuum and do gas charging. Call repairman to do it. Thanks.
Jan 28, 2011 | Maytag Refrigerators
Clunking sound between 30 and 35 mph. Doesn't happen all the time. Sounds like it's coming from the rear of the car.
Check the U-joints. (Vehicle parking brake on, wheel chocks to insure safety. Transmission in neutral. Try to turn driveshaft one way, then the other.
Be sure wheel stud nuts are tight.
Aug 05, 2009 | 2000 Jeep Grand Cherokee
Cannot get digital output
Digital output is for the reproduction of 5.1 or higher surround sound.  Though it will support 2.0 audio it is not meant to be hooked up to a tv, but meant to be hooked up to a surround sound reproduction device.
Jan 06, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
