Question about HP Pavilion NP218AA p6142p Desktop PC - AMD Phenom-9650 2.3 GProces
Need to replace pegatron motherboard nep253-69001
Motherboard is not functioning properly It does not detect any drives or run consistantly
  • HP Master
  • 5,660 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01746796&cc=us&lc=en&product=3979942#N74
Scroll down a little. Stop at Motherboard - M2N78-LA (Violet)
1) Motherboard Size: 9.6 Inches X 9.6 Inches
(24.4cm X 24.4cm)
This means the Form Factor is Micro-ATX,
http://en.wikipedia.org/wiki/Computer_form_factor
http://en.wikipedia.org/wiki/MicroATX
2) Processor Socket: AM2+
http://en.wikipedia.org/wiki/Socket_AM2%2B
3) Motherboard Chipset:
Nvidia GeForce 9100
http://en.wikipedia.org/wiki/GeForce_9_Series#Geforce_9100G
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01635734&lc=en&cc=us&dlc=en&product=3979942
Since you have an AMD Phenom X4 9650 processor, make sure the new motherboard will support it.
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Agena.22_.28B2.2FB3.2C_65_nm.2C_Quad-core.29
Make sure the new motherboard will support DDR2 Sdram ram memory, at 800MegaHertz. (800MHz)
That is PC2-6400
Up to 16GB of ram memory. Specs state you have 8GB installed now. (Product Specifications)
If you are running XP, Vista, or Win 7 that is 32-bit, you will ONLY see about 3.0Gb to 3.5GB.
You need a 64-bit Operating System for more than 4.0GB of ram memory.
Motherboard getting a 'little light in the rear-end'?
Check the Electrolytic Capacitors on the motherboard.
No. Not the Solid Polymer Capacitors. (Cylindrical small 'cans', with a Red mark on one side)
The Radial Aluminum Electrolytic Capacitors,
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
Yes, bad caps can be replaced. All you need is basic soldering skills.
Why do they go bad, and what makes me think other components aren't ready to go bad too?
http://en.wikipedia.org/wiki/Capacitor_plague
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 18, 2013
Need to find bios for pegatron IPM-SB
http://pegatron-ipm31-bios.driversdownloadwin7.com/
Sep 18, 2014 | Computers & Internet
HP Pegatron M2N78-LA having trouble finding a replacement for my motherboard with the same part number, would i be able to put a HP Pegatron M2N78-LA with a different part number into my machine
Before you give up check on ebay. If you do replace just make sure that the physical size is the same and that the replacement uses the same cpu and memory you have now. Otherwise you will be spending much more dinero.
Apr 01, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
Pegatron M2N68-LA
they are number one on the cables are red
Feb 28, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
Pegatron M2N78-la
Go here and select the operating system you are using and download the "Chipset Driver" and install it:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=4120567&
Also, recheck the connections to the drives, both power and ide or sata.
Jun 03, 2012 | HP Pavilion p6313w -24058
The drives are not recognized in the post. It will not go to bios. the motherboard is a m2n78-la
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions, DE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electrical power and data to travel through every working device its and have an end so any faulty leads will end up with a computer error
make sure your ram and cmos battery are securely seated with no dust in sockets
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS
hope this will help
Jul 26, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
My HP will not recognize sata hard drives
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error or
Restart your computer with the XP Setup disk in the CDROM drive.
If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer. Enter your Administrator password. If you don't enter the correct password, you cannot continue. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed. Your damaged MBR will be replaced with a shiny new one, and you should then be able to boot your system normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead
Apr 28, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
WHY ASROCK MOTHERBOARD m266a cant detect the hard drive
http://www.asrock.com/support/download.asp
Follow this link and Down Load up dates and drivers. Thank YOU for Using FIXYA.
Feb 26, 2011 | Asrock M266A Motherboard
Pegatron motherboard diagram where is one?
MY LAPTOP IS HP COMPAQ SYSTEM I NEED A BOARD DRIVER FOR MY LAPTOP
May 16, 2010 | HP Compaq Motherboard
HP Pavilion NP218AA p6142p Desktop PC - AMD Phenom-9650 2.3 GProces Logo
211 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
