Question about IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision 17" Monitor displays for 1 second then black
Light stays green - display is good for about 1 second then black. Rebooting/ shutting off power doesn't help. Swapped out the monitor and the other one works fine (same cables - no config changes). Any ideas?
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Posted on Feb 03, 2009
  • manilvajl Feb 10, 2011
    I can see 2 large PCBs one is the power supply board with the inverter for the backlight and the other is the display logic and LCD driver.
    Are the 4 main capacitors on the power supply board? And are they all the same value?
IBM ThinkVision 17" L170P, the problem is that the screen is black and power indicator is steady green on. Can not turn off the power indicator at all.
Posted on Dec 01, 2009
Lenovo 9227ac1 comes on then goes black light on front stays green
When it have this kind of error is a problem of the power-board.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Mar 22, 2014 | Lenovo 17" Thinkvision L171 9227-Ac1 Lcd -...
Monitorwont come on
When i turn on my IBM ThinkPad laptop the battery and power light is on green but the monitor remains black.
Jan 20, 2013 | IBM ThinkVision L170 17" LCD Monitor
I have a type 6734-LB1 17" Lenovo ThinkVision
where will i get to install the software/drivers of IBM 6734-L-B-1 for listening Music
Sep 30, 2011 | IBM L170M (Black) 17 in. Flat Panel LCD...
My IBM ThinkVision monitor flickers the correct display then blacks out. The light goes green a moment, then goes amber with the blackout. I think it may be stuck in the Energy Star/Power Saver mode. Is...
skeltonh, Have you connected your L170 to a different "known-good" PC that has ALL power-save and screen saver modes disabled? Have you connected an old monitor to your PC to see if it will act same way as the L170? 12fixlouie
Jul 31, 2010 | IBM ThinkVision L170 17" LCD Monitor
17 lcd l170 black screen power on but no display
When powered-on, and *NOT* connected to a computer, most ThinkVision LCD monitors will flash, for a few seconds, the IBM ThinkVision "logo", before going into "power-saving" mode. If you don't see that, then it's time to spend about $120, and buy a new 19" (not 17") LCD monitor.
Apr 08, 2010 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L191p after power on, remain black.
First place to chaeck will be power supply, the problem can also be caused by bad inverter circuits, bad lamps, see example of failed monitors due to bad caps, lamps, http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 11, 2010 | IBM ThinkVision L191p (Black) 19" LCD...
Check the DVI connections on your computer and your monitor. It is possible that there is not a good connection. Do you have access to another working monitor? If you connect a different monitor, and that monitor comes up, it could be the DVI cable or a bad monitor itself. If neither monitor comes up it could be a bad video card or port, or the computer may not recgonize it under Properties, Display, then settings when you right-click on the monitor, if you are using it as a second monitor.
Dec 01, 2009 | IBM ThinkVision L170p 17" LCD Monitor
LCD (IBM) monitor power light is green but no display
Make sure the monitor lead which goes behind the computer is in correctly and has not come loose.
Unscrew it from the PC and put it back in again.
Jan 06, 2009 | IBM ThinkVision L170 17" LCD Monitor
Monitor is dead (black)
ask to moniter service technition
thanks
prasanna
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
2,203 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
