Question about Apple iPhone 3G
My iphone 3g have stuck on the apple logo with the loading circle and i restored it and jailbroken it and it is still stuck....plz help (no effect after restoe although it was successful
  • Karim Farahat
    Karim Farahat Jan 18, 2013
    note: that happened after the battery went empty while i was playing and it never booted it again
  • Karim Farahat
    what is the problem here and how can i fix it
feelfemi009
  • 277 Answers
SOURCE: Freezing iphone 3g
if yopu have too much files on the memory pls delete some,if it persist just flash in new memory and the hanging will be detected and it will be corrected.
Posted on Jul 17, 2009
  • 133 Answers
SOURCE: iphone 3g stuck in emergency calls only
Are you using at&t. if not it was jailbroken and unlocked and that went away after you updated it.
Posted on Aug 11, 2009
Joed911
  • 4338 Answers
SOURCE: Iphone 3g 3.0 stuck on iphone apple logo loading screen
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Posted on Aug 28, 2009
Testimonial: "the last option helped alot thanks x"
  • 57 Answers
SOURCE: 3GS restore via Itunes
Maybe you could try the iphone gadget - Daniusoft iphone transfer which can help you transfer music/video files during iphone, iTunes, computer easily...
Posted on Sep 09, 2009
SOURCE: cydia won't load
You need a program like iphonebrowser or ssh with winscp.
Go to /private/var/lib/apt/lists
and delete all the files in /root/private/var/lib/apt/lists/ except for the partial subfolder. Do not delete Partial folder. Reboot phone and restart cydia and it should work just fine.
Posted on Sep 14, 2009
Iphone 3g stuck on apple logo after jailbreak
hy,??,????????iphone?????,????????????,???????(vipprogrammer.com)????DIY????,?????????,
May 21, 2017 | Apple iPhone 3G
Iphones stuck on reboot apple logo
If your iPhone is jailbroken (do not restore from iTunes) Instead try to restore using the jailbreak software used originally.
Please take note as to why I displayed the top message first. As for the iPhone through iTunes, you are stuck in what is known as a boot loop error. A restore from iTunes is required provided your iPhone is not jailbroken. The 5.1.0 release for the jailbreak is not yet out and you will not be able to downgrade back to 5.0.0 once you restore from iTunes.
May 07, 2012 | Apple iPhone 3GS Black (16 GB)
I reset my iphone 3g now all I have is the apple sign. It will not turn on
If your iPhone is jailbroken and you pressed reset all content, the phone will really not load and will be stuck on the apple logo. What you have to do now is to restore the phone using iTunes. To be able for iTunes to detect your iPhone in recovery mode and enable you to restore, you have to enter dfu mode. Just press the home button and sleep button simultaneously for 10 seconds then release the sleep button but still hold the home button until iTunes can detect the phone. Then press restore and let it do the rest of the process.
Apr 13, 2011 | Apple iPhone Smartphone
3gs iPhone froze at boot screen (apple logo)
Re-download the ipsw file that was on your iPhone, Download Spirit to jailbreak, and that should do the trick.
Jul 09, 2010 | Apple iPhone Smartphone
Restore iphone 3gs problem
Your iphone might already have that version, or maybe the phone does not have service, or also it could be tht the phone has been jailbroken. try doing a reset by holding the home buton, and power button down at the same time until the apple logo appears. Then try again
Feb 15, 2010 | Apple iPhone 3G
After jailbreak, app loading issues, now wont start correctly
you screwed your phone, its just a brick now :[
Aug 17, 2009 | Apple iPhone 3G
IPhone 2G hangs at "slide to unlock" - restore not helping
2g solution
3g solution
if it still gives you problems then you have a hardware issue, apple won't touch a jailbroken iphone so hopfully you have the apple care protection. Restore it to factory settings and try to take it in for service.
Feb 04, 2009 | Apple iPhone Smartphone
I have a jailbroken , 3g iphone . i wanted to delete some things that i could only do by going to reset data and settings , so i did that , and now when i power on my iphone it only shows the apple logo...
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Alternative Method:
Step 1. Connect iphone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.
Jan 06, 2009 | Apple iPhone 3G
Apple iPhone 3G Logo
49 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
