Question about Refrigerators
The top shelf of fridge,directly below freezer section keeps getting very warm,why is that?
  • Mrs.Jane Down Parker Jan 20, 2013
    smeg fridge freezer with topshelf significantly warmer than those below
    New Friend:
  • 10 Answers
It's possible that the light is heating it up. I doubt it's that because you'd probably figure out out yourself so. There is most likely some wires or even a temperature controller built between the freezer and fridge. As for why it's warm, I see 3 possibilities. One, electricity travels at a very high rate of speed, thus it creates friction. This can be normal However it could also be signs of a short , which is number two. If too much power travels at one time due to a short circuit, excessive heat and possible fire/explosion/melting of device can occur. Finally, the third, another electrical problem: even if there isn't any electrical components in between, there could be a faulty ground that may be sending the return voltage "through" that area of your fridge. Hope this helps.
Posted on Jan 20, 2013
kachbibi1
  • 979 Answers
SOURCE: Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Posted on Jan 14, 2009
  • 2418 Answers
SOURCE: Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Posted on Mar 10, 2009
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
SOURCE: Replacement glass shelf required
Not too sure what your glass shelf looks like, but if you can't find replacements it might be easier to just get a sheet of plexiglass and glass cutting tool from a home depo (or the like) and cut it to the correct measurements. That's what I did for mine.
Posted on Jun 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
Freezer not working when its cold in the garage.
Where do you keep the fridge? If you keep it outside then most likely the condensor coils in the freezer may be freezing over and the only way to fix that is to keep it above 40 degrees outside the fridge.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jan 18, 2017 | Refrigerators
My fridge is leaking water from the top shelf down to the bottom and onto the floor
You most likely have a clogged defrost drain tube in the freezer, this diverts water through the damper into the fridge section in units with the freezer on top... Remove the back wall of the freezer and look beneath the tubing and you will see an ice pad... Use a turkey baster and warm water to reveal the drain hole, then force warm water down it until it is clear... Have some towels handy. Whirlpool Refrigerator Drain Strap 819043
Nov 09, 2013 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
At work one of our units gets too cold in the fridge and the tenant says it freezes her eggs.Do I need a new t stat?
if the eggs are placed directly where the cold air from the freezer enters the refirigerator section, they would freeze. The temp of air coming into the ref. sect. is about 12 degrees, by the time it fills the ref. section it is around 38 degrees. try moving the eggs to a middle shelf (just not on the top shelf), If that doesn't work then I would replace the thermostat.
Mar 05, 2011 | Whirlpool ET1MHKXM Top Freezer...
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
My Frigidaire refrigerator side by side is freezing drinks.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS26H5AS Side by Side...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Nov 28, 2008 | Zanussi ZTX520W Top Freezer Refrigerator
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
