Question about Crosley Dryers
Will not heat
Dryer is not heating up
    Scholar:
  • 197 Answers
Try the Breaker Box. If the Breaker hasn't been tripped, it's more than likely the Heating element or one of the two heat sensors on the Element.
Posted on Jan 18, 2013
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
DRYER WON'T HEAT
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
www.partselect.com/Repair/Dryer/Not-Enough-Heat/
When your gas or electric dryer is not producing any heat or not enough heat to ... If the sensor is defective, either the igniter won't glow or the gas valve won't ...‎How to test a dryer's heating ... - ‎How to open your dryer's cabinet
How To Troubleshoot A Dryer That Won't Heat ' PartSelect ...
? 4:23
www.youtube.com/watch?v=ahb5pt52drE
Oct 6, 2011 - Uploaded by PartSelect
How To Troubleshoot A Dryer That Won't Heat ' PartSelect.com ... If you're using an electric dryer check ...
Oct 30, 2015 | Dryers
Heating elements won't heat up. the settings are
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | Amana NED5400TQ Electric Dryer
What can make my dryer stop heating or to heat randomly?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 29, 2010 | Roper REX4634KQ Electric Dryer
Dryer won't heat up. It starts to heat then goes off
heatman101
May 21, 2010 | Kenmore 63942 Dryer
Dryer only heats on the highest heat setting
Some electric dryers have two heating elements. You probably have one bad heater and one good heater.
Apr 14, 2010 | GE DVLR223 Dryers
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer will not heat
Hello there:
There are 5 things that would not make the dryer heat up i will post you them here ok
Jan 17, 2010 | Dryers
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
Maytag Neptune Dryer not heating
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryers Logo
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
