MBR71 Benford Roller Charging problems - Office Equipment & Supplies
Error code E000064-0000
E064-0000 Description The presence of a high-voltage error is communicated by the composite power supply PCB (The output for primary charging, developing, or transfer has deviated from a specific level of voltage) Causes The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty. proce Remedy 1. Contact Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact? YES: Clean the contact, and set it once again. 2. Wiring Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller? a. DC controller PCB (J301) <-> composite power supply PCB (J136) b. composite power supply PCB (J130-7) <-> primary charging roller contact c. composite power supply PCB (J130-1) <-> developing assembly contact d. composite power supply PCB (FT133) <-> transfer roller contact NO: Correct the connection. 3. Composite power supply PCB, DC controller PCB Try replacing the composite power supply PCB. Is the problem corrected? YES: Yes. NO: Replace the DC controller PCB
Nov 19, 2014 | Canon Ir 3300 Black & White Copier
I am using canon ir 400s copier machine the copier did not show any error but the copier it work but the printing time its did not printing
there may be problem with primary charging roller. to replace the primary charging roller, take out the drum unit, remove plastic cover, remove three screws of the shaft plate, take out the drum,detach primary charging roller from stand and replace .
Feb 11, 2011 | Canon imageRUNNER 400S Copier
Errore000064 occured
Power supply voltage error (high-voltage error)
power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause: The contact has poor connection. The wiring is faulty. The composite power
Action
1. Contact
2. Wiring
YES: Yes.
NO: Replace the DC controller PCB.
Jan 19, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
How dum unit works ? There is black lines appear on copy
if the black line is in the direction of paper travelling, change the dc blade or check heater roller .if the line is vertical there may be problem either with drum or primary charging roller. replace the drum first if problem do not disappear replace primary charging roller above the drum.
Jan 04, 2011 | Canon imageRUNNER 400S Copier
How do I check if I have marks on the drum of my Canon Laser Printer (LBP2900B)?
If you have marks on your drum there would be repetitive marks every 76mm.
Interval (mm; approx) Roller or component
55 Feed roller
46 Transer charging roller
38 Primary charging roller
76 Photosensitive drum
31 Developping cylinder
57 Fixing film unit
56 Pressure roller
Dec 24, 2010 | Canon LASER SHOT LBP-2900 Printer
Primary charging roller problem for HP LJ 3005dn
How long have you had this printer for. To solve the problem you have to buy new roller for the printer
Jul 26, 2010 | HP LaserJet 1320 Printer
Copies and faxes double images how to solve
put an old or new toner cartridge in it to see if the double imaging goes away. If it is still there its the fuser. I can help you with that if you need supplies for the fuser. Steven 818-888-0006
Mar 05, 2010 | Canon imageCLASS D880 All-In-One Laser...
Image source 50 code E64
E064 Error code details Power supply voltage error (high-voltage error)
0000 The presence of a high-voltage error is communicated by the composite power supply PCB.
(The output for primary charging, developing, or transfer has deviated from a specific level of voltage.)
Main cause
Action
1. Contact
2. Wiring
 YES: Yes.
 NO: Replace the DC controller PCB. pls rate for my good deed!!!!!!!!Good Luck
Sep 21, 2009 | Office Equipment & Supplies
How to clear E000064 problem in ir3300 model
E064
Main cause The contact has poor connection. The wiring is faulty. The composite power
Action
1. Contact
2. Wiring
YES: Yes.
Feb 26, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
2. Wiring
YES: Yes.
Feb 24, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
jasbo
jasbo
