Question about Linksys BEFW11S4 Wireless-B Broadband Router (12503024)
Have wireless connection, but can't get online
HELP! I have a BEFW11S4 wireless acccess point rounter (linksys). I've had this router for a few years, but stopped using it for a while because I didn't need it. Tried to reconnect it. Everything is connected properly, and my wireless network picks up the wireless connection, but I can't connect to the internet (it works when I plug the ethernet cord from the wireless router to my laptop). HELP! I saw a suggestion to uninstall the software, but I couldn't find anything on my computer to uninstall. I've tried trouble shooting on Linksys website, but to no avail. And I am not tech savvy so much of the lingo escapes me. Does anyone have any suggestions? (Step-by-step would be much appreciated)
  • 2 more comments
  • Anonymous Jan 26, 2009
    I have the exact same issue. Very bizarre. i've tried evrything including installing the latest firmware.
    Please let me know what you find out.
  • calex0519 Feb 18, 2009
    The wireless device in my laptop is working fine. I can't connect to the internet but I'm connected to my wireless router on my desktop with excellent signal. I'm not sure why it's not connecting with the internet. I was able to get on yesterday but my security settings for the wireless router were disabled. When I was trying to get my laptop connected again I must have changed something on the laptop. It keeps telling me that the local network is unplugged, whatever that means. I can't seem to connect it. Can anyone help?
  • Anonymous Feb 23, 2009
    i have this issue too. it sucks
  • eecom May 11, 2010
    Hello...another step to try is to check your wireless network adapter, within the Device Manager:
    1. On your laptop, locate the Device Manager (if using Windows). One way is to go to Start > Run (for Windows XP only) > type devmgmt.msc in the box you see, and click OK.
    You can also access it via the Control Panel >System >Hardware tab (in XP)
    2. You should now see the Device Manager. Next to Network Adapters, click any ‘+’ you see to locate the Wireless Network Adapter. First, are there any unusual symbols there, such as a yellow exclamation mark?
    A yellow exclamation mark may (for example) indicate a problem with the driver - which is the software that makes the adapter work with your computer.
    Even if you don't see any unusual symbols, it is still worth trying to update the adapter driver. I don't know your operating system (eg, Vista or XP) so can only give general advice; but if you right-click the wireless adapter in Device Manager, you should see options which enable you to update the driver via the web.
    If the new driver does not help, you can roll it back from the same place.
    An updated driver may solve the problem. However, this is only a suggestion, so if it does not help, please come back to Fixya...
    Problem Solver:
  • 10 Answers
Linksys wireless router has many bugs: connection issues like no connection or constantly having to reset the router. It isn't compatible with many network adapters. Hope this helps!
Posted on Sep 14, 2009
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Dec 23, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
I can setup my linksys befw11s4 v.2
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Mar 01, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
If my pc has a strong internet signal - why can't I go online?
its a wireless signal may have to move it around to get your signal things such as walls ,appliances distance can cause signal loss
May 18, 2017 | Linksys Bundle: BEFW11S4 802.11b Wireless...
Interference between my router and bluetooth headset
I just moved the router farther away from where i use my bluetooth headset and voila.
Feb 08, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
My Router is out of warranty how do I troubleshoot it?
Hi, the BEFW11s4 sometimes is just a plug and play router. If your internet is working when your pc is connected to the modem, just do this steps.
1:Lets reset the BEFW11s4. with the power on, push the reset button at the back of the router for 30seconds, unplug the power of the BEFW11s4 for 10 seconds.
2:Disconnect the pc from your Comcast modem. Connect the ethernet cable from your modem to the INTERNET PORT of the BEFW11s4. Connect the pc to the BEFW11s4. NOTE; MAKE SURE THE PHYSICAL CONNECTION IS CORRECT.
3.Open INTERNET EXPLORER. ONLINE OR NOT?
A. IF ONLINE, clear the address field then type 192.168.1.1, if it ask you for a username and password, then we are ok. THE ROUTER IS ALREADY WORKING.
B. IF NOT ONLINE, TURN OFF PC, TURN OFF BEFW11S4, TURN OFF THE COMCAST MODEM. WAIT FOR 3 MINUTES
TURN ON MODEM, WAIT FOR 3 MINUTES, TURN ON BEFW11s4, WAIT FOR 3 MINUTES, TURN ON COMPUTER
IF STILL NOT ONLINE. Open internet explorer, type on the address field 192.168.1.1, username(nothing, as in blank), password(admin), click ok.
It will take you to the Linksys configuration page(Purple and white screen. On the screen you can see tabs
SETUP WIRELESS APPLICATIONS AND GAMING
MAC CLONE
CLICK THE MAC CLONE TAB, then click on Clone or Clone your pc mac, the save settings at the buttom. After this try the internet. If still offline, unplug the power of the BEFW11s4 for 10 seconds, try the internet again. It should be working now.
If still offline, do STEP 3B AGAIN. IT SHOULD BE WORKING ALREADY. IF THIS DOES NOT WORK, you really have to buy a new router.
I have solved this exact problem more than a thousand times. It always work if the router is still ok.
Good Luck
Mar 08, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys BEFW11S4-RM 4 port wireless router
This is an old router. Look at the power light. You must have a STEADY power light. RESET the BEFW11s4 by pushing the reset button for 30seconds. Unplug the power of the BEFW11s4 for 30 seconds. Connect pc to port 2 or 3. pc should get an ip of 192.168.1.x. If you are getting this ip that means that the pc is already detecting the router.
Good Day
Mar 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Online connection
be sure that it isconnected by accessing the access point.
Feb 12, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Cant go online wireless (working before)
Hi jamesone..
This router will not support vista laptops..and the warranty period for this router is only a single year..better you can go for advanced g or gs routers .. model no's like..wrt54g or wrt54gs..with a warranty perion of 3 years..
HI baby..
this is for u..
It seems that you are not connected to the wireless connection ..i think the operating system in your laptop would be xp..to fix this problem
right click > wireless n/w connection > click view wirelss network connection > click change the order of the preffered network connections > select your wireless network name > from preffered wireless network and remove it..and then right click wireless network connection icon again and try connect to the network.. you will get connect.. and will get an ipaddress..
Nov 29, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Internet connection problems using the BEFW11S4
If you are having problems connecting to the Internet, follow the following steps: 1. Internet service: Check with your Internet Service Provider to make sure that service is active. You usually can determine a good link to the service if you can bypass the BEFW11S4, plug directly into the ISP modem unit, and get a good connection. This will narrow the issue down to either the service, or the router. 2. Network cables: Verify that the network cables that connect the network together are plugged into the current ports as they should (modem into the WAN/Internet port, computers into 1, 2, 3, or 4). Also try to change some or all of the network cables that attach to devices coming from the BEFW11S4. You may have bad cables. 3. Router configuration: Your router may not be configured to use your Internet service properly. While plugged into your provider?s modem and able to get online, run the bundled Router Setup Wizard CD-ROM program that came with your router. This will configure the router automatically for you. Note: this program must be executed on the main computer when plugged directly into the providers modem unit and able to get on the Internet 4. Manual configuration: If the Setup Wizard CD-ROM from Step 2 fails to configure your router, you may need a manual configuration. While plugged into the provider modem unit and able to get online, visit http://kb.linksys.com, and search for the name of your Internet service provider for detailed instructions on manual configurations. 5. Router firmware: Upgrade your router to the latest firmware version. Please go to http://www.linksys.com/download to download the latest version of firmware for your product. After the upgrade, be sure to reset the router, by holding in the router?s reset button for 30 seconds and reconfiguring it for use with your service (Step 3 or Step 4). 6. Malfunctioning equipment: You may have a faulty network adapter, or a bad router. Please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Computers & Internet Logo
490 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
