Question about Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar
Putting the throttle and handle back together on a poulan chain saw
Took the throttle and handel trigger apart and cant seem to figure out how to put it back togeather
5 Suggested Answers
  • 3 Answers
SOURCE: Throttle assembly
try www.jackssmallengines.com parts look up poulan 2500 they have exploded views of all parts this may help you will probably have to search arond abit
hope this helps
Posted on Nov 01, 2008
dontbother10
  • 2220 Answers
SOURCE: the throttle trigger and trigger lock are both
Clarification Request
Posted by dontbother10 on Sep 16, 2009
We need the make, model, and serial numbers from the manufacturer’s tag to help you farther.
I think your rivits are roll pins but without clarification cannot verify that.
No response to clarification request. Close
Posted on Sep 24, 2009
wireguy212
  • 1627 Answers
SOURCE: how to put the chain back on a 14" Poulan electric
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Posted on Sep 12, 2010
  • 2239 Answers
SOURCE: I need a diagram for the throttle connection to
Sorry there are no diagrams of how it fits, there is a parts list that shows the cable, as far as i remember the end of the inner cable has a dog leg in it, that hooks into the trigger, and the outer cable is secured in the right hand handle half, once the other half is assembled it stops it from popping out, the other end also has a dog leg this hooks into the throttle spindle, and the outer is secured in the air filter houseing.
Posted on Feb 28, 2011
How do I connect throttle cable to throttle trigger?
Search for online manual, that has the diagram, showing the location the end of throttle cable at the trigger. You will have to take apart the handle assembly, to access the cable and trigger.
Nov 05, 2015 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to get your tigger from sticking on my poulan predator chaINSAW
Trun over saw look at BAC handle small screw should b there
May 23, 2014 | Poulan PP4218AV 18" Chain Saw
Brand new Huskie 450e used for two days and the throttle is now broken. The actual trigger itself feels like it isn't attached to anything anymore. Is it an easy fix?
In the 400 series of Huskies I have fixed, the handle comes apart with several screws. Sounds like the simple problem might be in the handle/trigger assembly. The more complex problem is if the throttle linkage rod popped out of the throttle. The outside trigger interacts with a black plastic insert and spring that provides pressure outward to keep the throttle low. This assembly connects to a thin metal rod that looks like the path a drunk would take doing a sobriety test after too many martinis. The rod goes into the housing and connects into a hole in the throttle assembly, then is locked in place with a plastic piece that slides down to keep the rod from falling out. In order to see this area, the cover needs to come off. I'll be honest. The last one I had, the rod fell out of both ends. It took me two days of pondering, playing around, cursing, getting up and walking away, then coming back to finally figure out where the ends went. The blue plastic piece had slid down, covering the hole, so I was at a loss as to where it attached to the throttle. NOTE: When removing the handle, try real hard to keep it together until all screws are removed. THEN VERY CAREFULLY begin to take it apart, looking in from the top of the handle. You might get one good glimpse of how the parts fit together before they fall apart on you. Husky does have a good website for exploded view diagrams, but sometimes they leave a little to be desired for 2-Dimensional art vs. 3-D Reality. Good luck.
Sep 13, 2011 | Husqvarna 450 e-series 18" Chain Saw
Saw is idling to high will not adjust down. What do I do.
Open the carburetor area cover and remove the air cleaner so that you can observe the throttle arm and the idle speed screw which stops throttle movement to set idle speed. If the throttle arm doesn't come back completely to the screw, then likely, the throttle trigger is jammed with sawdust/dirt that prevents the throttle arm from returning. Disassemble the trigger assembly making notes of part placement as you go. You will usually find a plug of sawdust in the trigger mechanism. Recheck the throttle arm motion after putting the trigger back together. You may have to advance the idle speed screw several turns CW to be able to keep the engine running when the throttle works correctly. Idle speed should be set so that the engine continues to run, but the chain doesn't try to turn. Hope this helps!
Jan 04, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw runs wide open
Operate the throttle trigger to see if it returns to the idle speed screw when the trigger is released. If it seems to 'float' somewhat, the trigger assembly may be full of dirt/sawdust, or the throttle return spring on the carburetor is damaged or disconnected. When taking the trigger assembly apart, be sure to make notes so that it can be put back together correctly. Make sure the throttle plate in the bore is tight to the shaft. When the carburetor was off of the engine, did the gaskets and heat insulator seem to be ok? Any air leak behind the carburetor will cause run-away speed. As for the engine quitting, check the fuel filter, air cleaner, and muffler for plugging. Check the condition of all of the fuel lines for decay or other damage. Did you check the condition of the diaphragm in the lower chamber of the carburetor--it should be quite flexible with no holes or cracks. With the jetting set where you have it, the engine should be 4-stroking heavily. Hope this helps!
Jul 20, 2010 | Poulan Pro Chain Saw 46cc 20"
What is the oil/gas mixture for a 20" chain saw?
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jun 28, 2010 | Poulan Pro Chain Saw 46cc 20"
How do i put the brake assembly back to gether
If your saw is indeed a Husky there is likely an illustration of the chain brake on the IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Oct 26, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
The throttle trigger and trigger lock are both jammed in and I can't get the saw started. it's a Poulan 16 inch chain saw. Does anyone know if there is something I can do to release them short of taking it...
May 11, 2009 | Poulan Garden
How to fix throttle trigger on a poulan chainsaw?
The trigger, lockout or trigger/lockout spring has failed of may have debris stuck in handle. remove handle cover and inspect. If parts broken follow this link for parts breakdown.
http://www.ordertree.com/modelinfo/PWE/PP4218AV/75.PP4218AV.1.7.1.html
Apr 01, 2009 | Poulan PP4218AV 18" Chain Saw
Throttle assembly
hope this helps
Nov 01, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro PP4620AVX 46cc Gas Chainsaw With 20" Bar Logo
77 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
