Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Code C-1183 Bizhub C451 - Konica Minolta bizhub 350 All-In-One Laser Printer
5 Suggested Answers
waqar697
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Posted on Aug 23, 2009
SOURCE: error c1183 on bizhub 350
Check this solition
Posted on Dec 02, 2009
SOURCE: Our C451 Bizhub squeeks while idling...the techs
Have the techs replace the fusing unit, and install the update exit guide assembly (A0P0R73711)
This is a on going issue with this model, due to using induction heating, the fusing unit turns constantly, causing the squeak.
Posted on Apr 12, 2011
My machine bizhub c451 display error code p6,p7, p9,p16, p21
Registration errors. Have tech come out clean IDC sensors and replace black i/u
Feb 05, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
C-1183
Sir/Mam,
Did someone leave a trash can or boxes under the output trays? To solve this problem requires removal of the rear cover of the finisher. Then remove the elevation drive motor assemble. Be careful don't want the output trays to fall!!!!!! Then while placing them in their proper position re seat the drive assy. The top tray should be just below the orange rollers (If they are cleaned) you will see several actuators the top tray has to just touch them.
Jan 17, 2014 | Konica Minolta bizhub Office Equipment &...
Bizhub c451 error code c2259?
Black developer motor failure to turn. You mite try pulling out the Black image unit and shake it to spread the toner and developer along the whole unit. The image unit mite have been stored standing up image units should always be laid flat. All the developer may be sitting at one end of the image unit an so the motor is having a difficult time turning.
Nov 27, 2012 | Konica Minolta KONICA BR BIZHUB C451...
Bizhub c451 ERROR CODE C-1183
Elevation drive assy. for the output trays. did some one leave some boxes under the trays or a trash can.? Need to remove the reset the output trays to the correct location. Recommend a qualified KMBS tech do it
Sep 18, 2012 | Minolta bizhub 200 All-In-One Printer
Trouble Code C-1183
Your machine output trays hit something like a trash can or boxes store under the machine. Have to gain access to rear section of the finisher to reseat tray elevator drive assy.
Jan 18, 2012 | Konica Minolta KONICA BR BIZHUB C451...
Error code when copying... C6103 on Bizhub C451
Apr 14, 2009 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
69 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
