Question about Riverdeep Calendar Creator 9 Business Suite 9
AN ATTEMPT WAS MADE TO ACCESS DOCK BAR PAST ITS END
I GET THE ABOVE MESSAGE WHEN I TRY TO OPEN CALENDAR CREATOR 9. HOW DO I FIX IT?
Calendar Creator 12.1 art browser fails to open
See this... http://forums.encoreusa.com/tm.asp?m=47646
Also, you could go here, click on the closest problem, and if it does not solve yours, at the end will be options to contact Technical Support. http://support.encore.com/technicalsupport/product_detail.aspx?product_id=2685
Jul 16, 2014 | Broderbund Calendar Creator 12 for PC
Tip
Prinshop 23 Deluxe, fix character banner display in calendar
This is a fix easier explained than titled...
When using Calendar Creator in Printshop 23 Deluxe you can add multiple events across multiple days. But while a single event can use box, when adding multiple events it cuts off the message so many use banner to get them in the box for that day. The problem is that when you print, although the box event prints fine, the banner events will cut off part of the last character on the right side. This effects any character including space, so to fix this; just add a space at the end of each event you're importing.
on Mar 22, 2010 | Computers & Internet
Calendar creator 6.0 windows xp
If you can get to the cd and explore it, open the NT Setup folder. Then open the DAO folder. Open Disk 1 folder and run setup.exe. Then try running the program. It worked for me after I had the same error.
Jun 24, 2012 | The Learning Company Calendar Creator...
How to remove calendar creator 12 from Windows Vista
  • The traditional method --- uninstall Broderbund Calendar Creator with windows add/remove program
    1. Start-->Control Panel-->Add/Remove Programs.
    2. Find Broderbund Calendar Creator in the program list and right click to choose Delete.
    3. Follow the panel wizard and reboot your PC when it finished.
    In fact this way can not remove all the components of Broderbund Calendar Creator. Registry keys of Broderbund Calendar Creator still remain on your computer. It is advised to clear up registry entries of Broderbund Calendar Creator or you are likely to encounter problems like uninstall or install error, registry error and so on.
    Guaranteed Method -- Uninstall Broderbund Calendar Creator with a professional uninstall tool
    A third party uninstall program can force uninstall Broderbund Calendar Creator while windows add/remove program fails. Moreover, a third party uninstall program can clear up all the registry entries of Broderbund Calendar Creator. Among so many uninstaller tools, Perfect Uninstaller enjoys high reputation. Perfect Uninstaller can remove Broderbund Calendar Creator completely in 4 simple clicks.
    1. Free download Perfect Uninstaller form its official website.
    2. Install Perfect Uninstaller on your computer
    3. Browse for Broderbund Calendar Creator folder with Perfect Uninstaller.
    4. Click REMOVE to uninstall Broderbund Calendar Creator from your computer.
    It is important to uninstall Broderbund Calendar Creator thoroughly from your computer, as its remained components will have a side affect on your current antivirus program. Are you tired of trying various methods to uninstall Broderbund Calendar Creator? Do you want a certain effective way to uninstall Broderbund Calendar Creator? What you really need is a third party uninstall program. And before you search for a great uninstall program, have a look at Perfect Uninstaller and then compare it with the other one
    Read more: http://www.articlesbase.com/software-articles/how-to-uninstall-broderbund-calendar-creator-thoroughly-from-your-pc-now-3769861.html#ixzz1CrBj3PaU
    Under Creative Commons License: Attribution
  • Feb 03, 2011 | Broderbund Calendar Creator 12 for PC
    I downloaded Calendar Creator 12 a couple of years ago and have been using it at the end of each year to create calendars. However, when I try to open the program on my hard drive, a window pops up with...
    Symantec is foreign for Norton, probably your antivirus software.
    If you've set up a password for Norton is should be that. You need to tell Norton to allow use of your software.
    If you don't use Norton anymore, you need to un-install it properly.
    Jan 02, 2011 | Broderbund Calendar Creator 12 for PC
    I have Calandar Creator 10 and have created a family calandar which I use from year to year that includes birthday events, holidays etc. and phases of the moon. This year, when I went from Dec. 2010 to...
    Calendar Creator 10 has the four moon phases from Jan 1990 thru Dec 2010. To extend past 2010:
    - File Open Collection ' Local Disk(c:)'Program Files'Calendar Creator' Template'Events'Phases of the Moon.bcc
    -For each of the four events (First Quarter, Full Moon, Last Quarter, and New Moon) change the Repeat Until date past 12/31/2010 to 12/31 of the year you will add data for
    -For each of the four events, click Advanced Repeat Rule you can selete the drop down under Exceptions / Pick exception and there you can see the dates by month and year from Jan 1990 thru Dec 2010 for the event. You need to extend this list. First obtain the moon phases from some web site like www.timeanddate.com/calendar. (note that this site calculates the mone phases base on New York time). The simply select each of the dates for the event you are modifying by clicking that date on the calendar in the upper right hand of the screen. Just advance the calendar thru the months and years you want to enter data for. You can check the list when finished by selection the ExceptionS Pick exception drop down box.
    - Save your changes by clicking OK and Ok again. Make changes for all for events.
    - Select File and Save Collection
    - You need to replace the Phases of the moon events in your calendar by removing the old events and importing the new events. To remove the old Phases of the moon in your calendar, select Events'Categories highlight Phases of the moon and delete. Then add back the changed events by File'Import Events and browse for the Phases of the moon.bcc file you changed.
    I hope this gets you what you need.
    Nov 19, 2010 | Broderbund Calendar Creator Deluxe 10 Full...
    I installed roxio creator 2010 successfully but I can't open the desktop icon.
    go to my computer/program files/roxio easy creator 9 suite and copy and paste the quick launch icon and place it on your desktop
    Dec 30, 2009 | Roxio Easy Media Creator 9 Suite (227100)...
    Am trying to install Broderbund Calendar Creator Deluxe 12 on my HP pavilion lap running Windows XP. Problem is first disk tells me an older version of Calendar Creator must be removed before ver. 12 can...
    Usually in this situation when you loadup the new version it usually says what you are saying then goes on to ask if you want it uninstalled, you click yes, it then removes, you then usually restart and new version kicks in?
    Reload new version see if it gives the chance to remove before it installs. It has to be removed as you are aware. ?
    Nov 14, 2009 | Computers & Internet
    FaceBook/FarmTown My farm won't load, have access to other features of farmtown . The error message was, Syntex error, code 0, Line 9, Char:1
    The Farm Town error message that you receive is probably not on your end of the connection. Farm Town has been having a lot of problems for several months. I have been reporting a lot of them on their support site. They have been fixing bugs and upgrading a lot of things. I recommend in a post to them that they fix all the bugs first before upgrading and adding new stuff, but that didn't happen. If you look at the bottom left corner on facebook when you have any one of the Farmtown tabs open, you will see "creator" You can click on the creator to go to their support site to post any problems you find. They actually encourage this. Also, through my personal experience I have found that the Safari browser, the Google Chrome browser, and the Firefox browser works a lot better with FarmTown and other video rich game apps than IE 8 does.
    Nov 10, 2009 | Microsoft Internet Explorer 8
    Riverdeep Calendar Creator 9 Business Suite 9 Logo
    71 people viewed this question
    Top Riverdeep Computers & Internet Experts
    Bosse Photos
    Are you a Riverdeep Computer and Internet Expert? Answer questions, earn points and help others
