Question about Dyson DC33 Bagged Upright Vacuum
How do i change the belt
Roller not going round
  • Dyson Master
  • 18,411 Answers
Take the sole plate off to accsess the belt this link is the manual will help you
http://support.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc33_uk_manual_260710%20pdf
Posted on Jan 18, 2013
The brush roller is not going round
Sounds like the roller drive belt is either off or broken. Easy to replace with a screwdriver.
Jun 01, 2016 | Vacuums
Drive brushes not going round- sucks O.K
Hello Les,
Your brush roller is probably bad ( the roller that is driven by the belt). The bearings go bad over time and then cease. Typically the belt will break when the roller bearings cease so both will probably need to be replaced but both parts should be less than $20.00 total. Check the exploded diagram in your manual for the brush roller and belt part numbers.
See the link below for basic instructions:
http://www.wikihow.com/Fix-a-Vacuum-Cleaner
Take Care,
Mario
Apr 17, 2016 | Vacuums
The brush bar isn't going round ?
your problem seems to be the belt has snapped. Underneath the the hover there is a rubber belt that connects around the brush bar and around the motor, this belt will be broken. They can purchased from any hoover shop for a couple of pounds.
Jan 06, 2013 | Dyson DC24 Ball All-Floors Upright Vacuum...
My beater bar is not going round, machine is not picking up I have checked for blockages and everything seems OK
The belt that drives the roller may have broken and reqiures replacement. You need to take the cover off underneath and remove the roller.
Mar 07, 2011 | Dyson DC07 All Floors Bagless Upright...
Hoover windtunnel t series belt is loose- roller brush doesnt turn. Its brand new belt is slipping. we bough new belts and putthem on same problem. Can not find solutio in manual. Is the belt supposed to...
I also have a loose belt and have bought additional belts but have the same problem. I put the it around the metal rotor and around the brush roller a shown by he Hoover video, and it is loose.
Nov 28, 2010 | Hoover S3765-040 WindTunnel Bagless...
Impossible to change belt--cannot get belt to go over pulley.
first put belt on big round roller then use a flat screw driver to pull it onto the motor shaft
Dec 10, 2009 | Panasonic MC-V7515 Bagged Upright Vacuum
Rollers not going round but full suction when using the nozzle
Sounds like a broken belt. Check your manual if you have one on how and where to change it.
Sep 17, 2009 | Dyson Vacuums
Roller brush not spinning?
THIS GEEN LIGHT MEANS THAT THE BELT HAS COME OFF. THE REPLACEMENT IS AS FOLLOWS: FLIP THE BRUSH (RUG RENOVATOR) OVER AND REMOVE THE SCREWS ON THE SILVER GUARD THAT KEEPS THE ROLLER IN PLACE. SLIDE THE ROLLER UP OUT OF THE SLOT, TAKING NOTE ON THE HALF MOON SHAPED SIDE. REMOVE THE OLD BELT(OR WHAT'S LEFT OF IT). PLACE THE BELT AROUND THE MOTOR SHAFT FIRST. THEN AROUND THE WOODEN BARE SPOT ON THE ROLLER. PUT THE ROUND(CIRCULAR) SIDE OF THE ROLLER IN FIRST, THEN CAREFULLY STRETCH THE ROLLER WHILE HOLDING IN THE ROUND SIDE IN ONE SIDE AND ROTATE THE ROLLER UNTILL THE HALF MOON LINES UP TO THE SLOT. PUSH IT DOWN INTO THE SLOT AND PUT THE ROLLER COVER BACK IN PLACE AND RE-INSTALL THE SCREWS. AND THERE YOU HAVE IT. HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANK YOU FOR THE HONEST RATING AND FOR USING FIX-YA.
May 04, 2009 | Kirby Heritage II Vacuum
Chaning the belt
there is a plate on the underside covering belt and beater roller
2-3 screws to secure the plate
then withdraw the roller
put new belt round roller
insert roller
pull belt around motor pulley
reinstall plate
Oct 05, 2008 | Hoover Commercial C1403 Bagged Upright...
Belts keep burning up
It sounds like you have a roller problem. This machine has a carbon fibre roller suspended on plastic end caps. When dirt and hair etc. gets in and damage the bearings, the belt will be the first thing to go. If the roller is noisy, that indicates that it is off centre and is rotating unevenly. You will probably have to replace the roller.
Take the belt off and rotate the roller slowly and observe the ends. If it is off balance, it will not rotate evenly. The plastic caps unscrew to reveal the brngs and usually you will find hair and other junk gumming up the works. If the roller is damaged, you will be able to see melted plastic and chards of carbon fibre there.
Feb 15, 2008 | Hoover U5172900 Fold Away Widepath Bagless...
Dyson DC33 Bagged Upright Vacuum Logo
66 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
