....may a safety..? or electronic board that is keeping my fan locked up...but my compressors trips on high head..High Pressure...?
SOURCE: ac unit
wash condensar coil with castic soda then use water n surf clean the condensar properly,check gas back pressure n discharge pressure.suction pressure must be 65 psi
SOURCE: unit tripping on high head pressure but has bad pump down selenoi
high head pressure can be a result of a dirty coil have you tried flushing the coil?
SOURCE: goodman model F48F97A76 need to know what the
if your condenser fan motor is not bad. change out fan capacitor
SOURCE: I own an RCE24C2A a/c that stopped cooling last
Before working around or with your AC unit, be sure that all power to the unit is disconnected. The switch can be replaced without having to evacuate your refigerant, it is shown how in this instructional video: http://www.youtube.com/watch?v=7z7PLhqQAlo. Determine what type of pressure switch you will need according to how many wires you need, then follow this link to purchase the switch needed: http://www.americanhvacparts.com/Merchant2/merchant.mvc?Session_ID=8c7070e8fb882954689484b1e9cd2880&Store_Code=AM&Screen=CTGY&Category_Code=ps-amana. I see that you had a capacitor issue in the past, sometimes the HVAC repair companies won't install the new capacitor correctly on intention so as to get more of your money; if you didn't already know, the capacitor is what makes the fan run so if your system is on but the fan isn't running, your capacitor is bad. Here's how to fix it yourself for a fraction of the cost of the HVAC repair company: go to the back of your outside unit and look inside the access panel with the electrical warning sticker on it, if the capacitor is bowed up at the top, it needs to be replaced. If it turns out to be the capacitor, follow this link for a new capacitor replacement kit. The kit also comes with the proper tools and parts needed as well as detailed instructions on how to replace the part yourself. http://hvacrepairkits.com/index.php/content/article/68
I hope this helps!
