Question about HP LaserJet 1020 Printer
Though the printer's software is installed I could not get print
I am very much trying to get the print out but my efforts are futile
    President:
  • 2,976 Answers
Make sure the printer you want to use is being selected by the program you are using. Also, go into the device manager and set it as the default printer, if that's the one you will always be using.
Posted on Jan 18, 2013
4 Suggested Answers
Pinky01
  • 209 Answers
SOURCE: HP 3845 Inkjet won't print color under OSX
Try this test:
Let's say you want to print this present page (of fixya.com from Firefox or another web-browser), try File/Print and see if you have the tab Advanced to change to the color cartridge.
Posted on Oct 29, 2008
SOURCE: printer
you plz check the hardware connections once, printer works as a simplex method, check the connections.
Posted on Jul 26, 2012
  • 121 Answers
SOURCE: hp laserjet 3050 all-in-one printer software will not load on my windows 7 64 bit laptop.
It Depends on if the Fax is available for your region, Roll back all driver and start the installation afresh and be sure the option of Choosing Fax is highlighted.
Posted on Dec 10, 2012
I HAVE A PRINT CARTRIDGE ALIGNMENT problem wiht my HP C7820
Try to find the alignment software in your HP printer's Control Center. If alignment does not work, you could un-install the HP printer software and drivers. Disconnect the printer from the computer. Restart without HP software, drivers, and printer. Shutdown. Now reconnect the printer and turn the computer back on. Re-load HP software and drivers. Follow there direction as you go. You'll be asked to align the printer.
Sep 02, 2012 | HP Photosmart C7280 All-in-One Printer
Keyspan's drivers won't work on Win7 . . . Install MS's Virtual PC. Add usbd.sys to windows/system32/drivers (virtual box doesn't think it needs to load the virtual usb drivers, so i
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose vista sp2
now run it and presto......
regards, dean
Jul 06, 2012 | Keyspan USB Server US-4A (d47710) Print...
FUJI XEROX CM205fw can't set custom paper size
So I am not the only one encountering the same problem! Printing A4 & DL are great but it simply does not let me print A6 properly no matter how hard I tried to configure the paper size (at the printer settings, printer preferences, the application settings etc)
Can Fuji Xerox fix this?
Apr 26, 2012 | Office Equipment & Supplies
I have a Datamax DMX I-4212 Barcode Printer. Computer operating system is Windows XP. I use a third party software package, to produce barcode labels. The company is Argos Software. The printer is set as a...
Welcome to FixYa.
It shows that the printer is not communicating properly with the computer.
Solution:Uninstall the current printer driver from the control panel then re-install it.Your printer should came with a cd (software/driver/installer), use it to re-install the driver.
Thak you for using FixYa.
Dec 23, 2011 | Datamax DMX-I-4212 Label Printer
All time: I have stalled print jobs, my printers is hp deskjet D2460. I've tried so many things , but nothing, please help me or send me a program that can fix my provblem without unplugging my PC.
first remove the power plug and the usb from the printer wait for few minutes and place them back first the power then the usb then press start setting printer and go to printer propertes in printer page you will see the printer drivers which are instaled make the prinriter you are using as defult if you see no printer drivers then install the software which came with the printerall the printer software should be installed then go to the taskbar you will see the printer icon click them to open then delete all the contents then click to close then go back to the printer page right click the defult printer and click tgeneral in general you will see print atest page click it
Jul 03, 2011 | HP Deskjet 2460 InkJet Printer
I am using HP Laser Jet 1320 Printer i have a problem while printing as follows PCL XL error Sub System: Kernel Errror: Illegal Tag Operator: 0x1b Position: 6
This appears to be an issue with the driver.
Before replacing the driver though, make sure it isn't just the document itself that is the issue.
Try printing several different documents. If all other documents print, there's a problem with the document itself.
If several, or all documents from multiple sources (not all generated from the same program) then it's time to completely uninstall the driver, and then go to www.hp.com and get the driver specifically for your operating system for that printer and install it.
Remember to reboot between the uninstall and the reinstall.
If this yields the same results, then install an HP laserjet 4 driver on the same port as the currently installed driver using the add printer function in control panel/printers.
print the offending documents through this driver by selecting the HP Laserjet 4 as the printer when printing. If this solves the issue, make the laserjet4 the default driver.
Jun 04, 2011 | HP LaserJet 1320n Printer
I am getting lines though at least four lines of print per page. I shook the ink cartridges to see if that might be the problem, but no. The cartridges are all full. Please help
If the lines are black, the cartridge probably has bleeding jets.
If the lines are white (unprinted) then there are plugged jets.
In either case, replace the cartridge. You can try cleaning the jets by wiping with cleaner... Using the "cleaning jets" function of the printer is USUALLY futile.
Jan 11, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Try this test:
Oct 29, 2008 | HP Deskjet 3845 InkJet Printer
Lable printer
check if the setings from the printer are like PARALEL
check if is the correct driver ZPL, and if the firmware is ZPL.
Oct 13, 2008 | Zebra 105SL Thermal Label Printer
Printing Problems
Re install the software.
In so doing follow this routine
1. go to start/Faxes and printers remove the existing default printer.
Come off line and disable your anti virus software
Click on add printer and reinstall the software.
If you have no disk for example- use the install from list feature and install from the driver library
Dec 30, 2007 | Office Equipment & Supplies
HP LaserJet 1020 Printer Logo
18 people viewed this question
Seeker5211
Seeker5211
