Question about Sony VAIO SVE1511MFXS 15.5" Notebook PC - Aluminum Silver
My laptop suddenly hangs while I am working with it. The only thing I can do is turning off & on it and the cpu fan starts to run. In your opinion what the problem could be ?
My laptop suddenly hangs while I am working with it. The only thing I can do is turning off & on it and the CPU fan starts to run. In your opinion what the problem could be ?
  • Sony Master
  • 7,627 Answers
You didn't say what you were doing, on-line? In a Program/software? I would start by running a Full scan with your up-to-date Anti Virus. NEXT, Download freeware MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK the TRIAL PRO version, you want the freeware version. Run a Full Scan, Delete ALL results, Reboot. NEXT, Download CCLEANER at : http://www.filehippo.com/download_ccleaner/ This freeware program will clean the junk from your machine. In the TOOLS section, STARTUP section, Disable ALL unnessary startup programs, this will speed up your starts and running. Here are other speedup tips : http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332 AND: http://www.pcmag.com/article2/0,2817,2364937,00.asp
Posted on Jan 18, 2013
nematics
  • 431 Answers
SOURCE: Sony tr2a turns on, I can hear the cpu and fan fire but no boot.
remove the bios battery for a while and reset it
Posted on Mar 07, 2009
ChipcircuiT
  • 157 Answers
SOURCE: i have a problem with my Vilo VGN-FZ260E/b its
i can get you an advice, a basic advice for you as a user......you can buy in the market such a USB cooling fan...a lot of design in the market...you can check, i think that's the best solution for you.....
but you can check first the processor fun of your laptop cause maybe its not working,it will become hot..and it will shutdown your laptop.be advised you to check first your processor fan..if it is working then you need to buy a USB cooling fan..
Posted on Sep 24, 2009
consaka
  • 661 Answers
SOURCE: My laptop comes on and works good for about 5
You are correct and you are correct. The copper tubing is part of the cooling system and are referred to as heat pipes because they transport heat from the processor to the fan and cooling fin area.
The laptop is shutting down from overheating. Now usually this is caused by the fins getting plugged up with lint and dust. Sometimes this lint/dust/hair buildup can get thick enough that if you try to blow it out it can jam up the cooling fan.
Now if the fan has seized due to bearing failure then it is a bit more complicated and expensive then if it was just plugged cooling fins.
Technically you will have to order a new cooling fan and then take your laptop apart to install it.
If you are pretty mechanical and technically savvy you might be able to get a few more miles out of the fan if you take it apart and clean and oil it with a good synthetic oil.
When I do these jobs for myself and others I always clean and reapply a good heatsink compound to the processor and sink.
If the unit is overheating due to circulation problems, the old grease used in the original heatsink compound can become dry and hard. Dry and hard does not transfer heat nearly so well.
Now if you want to fix it yourself then you should be somewhat technically savvy about delicate electronics. A good understanding of thermal dynamics cant hurt either. One stray static spark and that motherboard may never boot up again. So be very careful. I have gotten a number of laptops for repair because people were inside them.
Personally I only charge about 25 to 30 for a clean up job that includes reseating the heatsink with new compound. I charge roughly 280, depending on model, to put in new motherboards.
If I get the laptop in pieces I charge double. I really hate that as you have no idea what has been lost or hosed.
Note: Shops in your area may charge differently.
Posted on Apr 01, 2010
Testimonial: "Very detailed answers, told me just what I needed to know. Couldnt ask for better."
  • 8909 Answers
SOURCE: i have a sony vaio vgn nr430e laptop the display
That could be a problem with the heatsink/fan assembly on the processor. It sounds like the processor is starting up, getting warm as they do, the fan starts up but does not cool efficiently enough and forces a shut down due to heat.
Clean out the fan assembly and replace the old heatsink compound on the processor heat sink.
Hope that helps.
Posted on Dec 09, 2010
davidmamian
  • 543 Answers
SOURCE: Sony Vaio has started shutting down unexpectedly.
Your pc CPU FAN is not working, you need open it and clean fan,, and under fan, on CPU there is termo cream, don't frgot about it, you need clean it and put new termocream. it is nessasary for cool CPU, that Cpu can not be warm.
Posted on Jun 11, 2011
My system suddenly hang when we restart it, monitor does not get any signal. After when we get rid hard drive motherboard was working. on other system my HDD is working fine.
This is usually dust clogging up the CPU cooler.
When the owner of the PC forgets to clean the fins and the fan of the CPU cooler it plugs up with dust and dirt and looks like the inside of a vacuum cleaner.
There is not enough airflow and thus not enough cooling, so the CPU overheats and the safety circuit shuts the CPU off until it cools down, and the CPU will not reboot the PC until it is cool enough that the safety circuit can reset.
First step remove the CPU fan and check the fins of the CPU cooler. If they are clean, the problem is usually somewhere else.
Oct 03, 2015 | Intel DG31PR Motherboard
My laptop dell inspiron N5010 not get log on
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 14, 2013 | Dell Inspiron N5010 Black 24811, Intel...
Laptop dell inspiron n5010 hanging suddenly
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. Here is a few good virus scanners that you can run to check your PC:
http://c74b6qq6lbo8zlievtv2q810g1.hop.clickbank.net/?tid=DMWDH6W3
Nov 24, 2011 | Dell Computers & Internet
My computer suddenly quit working. The power just went off
The most common reasons for that are
1. power adaptor or battery isn't working - power problem. Some laptops require the battery to be in the machine even when it's running of the adaptor. If it runs out of 'juice' it will just go off suddenly.
2. overheating - It can get full of dust and dander and overheat the cpu which will also cause the machine to go off suddenly. It shuts off to protect the cpu from burning up. Sometimes if they get hot enough it can still take out the cpu... If the cpu fan stops working it will also overheat.
3. Control Panel - Power settings - check to see if there's a timer set to turn it off after so long etc.
Jul 08, 2011 | Fujitsu LifeBook A1110 Notebook
My laptop shutdown suddenly, and I try to run the DELL Diagnostic there's an error "SMBIOS - Processor CPU Internal Temperature Critical. Service Tag # 37PHY1S How could I eliminate this problem
This is a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
When you disassemble the laptop, one thing worth doing is to check the thermal grease applied on the surface of the processor. Most probably it will have been dried up. In this case, clean it up carefully from both the processor's surface & the heat sink's lower surface, & re-apply fresh thermal grease. You can buy it online or at an electronics store.
Dec 11, 2010 | Dell 1525 PC Notebook
I have a toshiba m3 laptop, it was going then it froze, so i turned it off, now it wont start up, ac power and the on LEDs light up, if i remove and replace the battery the battery light goes momentarily...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced
Sep 10, 2010 | Toshiba Tecra M3 Notebook
Laptop gets switched off automatically
If it is switching off by itself & then allowing you to turn it back on it is most likely an overheating problem. The cpu has a built in sensor that shuts the pc off before damaging the cpu. First thing to check is your vents. Make sure they are free of dust & debri. After cleaning make sure your fan is blowing air out of the vents, if it is not then you will need to replace your cpu fan. If all is clean & fan is working then you could buy an inexpensive laptop cooling pad to set the pc on while working to help keep the temps in normal operating range. Hope this helps.
Jun 03, 2009 | Computers & Internet
The system hang during winxp install
If its hanging during install you need to turn virus protection off in the bios. Have a root around in the bios and you'll see it sooner or later, If you need further help just shout.
May 23, 2009 | Acer Computers & Internet
Pc is not starting up
I'm sorry to tell you but your cpu has probably fried. Your pc hanging a lot probably meant something was overheating and the fact that you say your cpu is not hot when you have the cooling fan off of it means it is probably the cpu. When you first turn your system on without a cpu cooling fan, the cpu should be slightly warm, although I do not recommended running a cpu at all without a cooling fan or even touching it when it has power.
Aug 18, 2007 | Intel Pentium 4 1.7G, 1.7 GHz...
Sony VAIO SVE1511MFXS 15.5" Notebook PC - Aluminum Silver Logo
90 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
