Question about Epson Artisan 800 All-In-One InkJet Printer
Espon printer's ink pads are at the end, how do i reset or fix it? thank you
    Problem Solver:
  • 6 Answers
Try unplugging the printer for a few minutes. Then plug it back in. When it runs through the initial set up it should reset.
Posted on Jan 18, 2013
Lonewolf1038
  • 6 Answers
SOURCE: epson stylus photo r320 ink pad relacement
Here's 3 things you can do to get around this...depending if your printer is new and still under warranty or not (do NOT void your warranty!).
I have used all 3, but the third one was a lifesaver (AND money-saver!). About once a year I have to reset the printer using #2, but other than that....#3 is the greatest!!!
1. Try resetting it by, unplugging the power cord then while holding down the POWER STOP and MAINTENANCE buttons simultaneously while replugging the power cord caused a reset to zero on the counter. You will still have to replace the pads or redirect the waste ink tube to a receptacle on the outside of the printer, hope this helps?
2. If you go to inkjetprinterhelp.us there you will find the ssc service utility. Once you open the page click on the service utility and then choose the english version unless you can spk russian.If you then scroll to the bottom of the page and install the prog. Once you have installed the prog you will get the ssc utility logo in your bottom tray. Right click the icon and then select reset protection counter from the protection counter drop down. Once you have done this restart your computer and this should reset the system.
3. INSTALL AN EXTERNAL WASTE TANK and forget all about those gunky ink pads forever!
On the left rear of these printers is a small trapdoor held by a single screw.
Remove it, look inside (down and to your left) and you'll see the waste ink tube.
The tube is free at one end, and with a suitably curved piece of wire you can hook it and wangle the end out through the opening (you may dislodge a small piece of plastic in the process -- just put it back where it was, it's only a vibration damper.) I found the tube to be rather short....so I added an extension since I do not have room directly behind my printer for a container. I used the tubing you use with oxygen tanks or fish tank bubblers. They also make a little plastic connector so you can join the two together.
At this point, you're almost there.
All you need now is a suitable container for the waste ink, and I drilled a small hole in the trapdoor cover so you can put it back on without pinching the tube (or you could just leave it off.)
The container is a small square one with a snap-on lid, approx. 60mm square and holding about 150ml -- they're sold in sets of three for a few cents and are for making ice-blocks etc. in your freezer. Any small container will work.
Make a hole in the lid (slightly larger than the tube to let air escape) insert the tube and forget about the internal pads forever.
I've had mine in place for almost 2 yrs now and it works like a charm. If you need photos, let me know and I have a couple I can send you.
Posted on Jul 01, 2008
Joed911
  • 4338 Answers
SOURCE: Epson 2200 printer ink pads
First download this Epson utility to reset the ink counter:
http://inkjetprinterhelp.us/epsonSSC.html
Read the disassemble instructions on this link:
http://www.fixyourownprinter.com/forums/inkjet/35177
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 27, 2008
SOURCE: I have epson TX110 printer. The printer not
Give me your email add. I'll send you the program where you can use to reset the printer's ink pad. Here's my email roy_paulo@yahoo.com.
-Roy Paulo
Posted on Nov 19, 2010
  • 6 Answers
SOURCE: EPSON STYLUS T13 printer's ink
Epson t13 all problem solved EPSON T13 WITHOUT CHIP , INK LEVEL ALWAYS FULL, NO NEED TO RESET INK LEVEL EACH TIME .INK LEVEL AUTO RESET WHEN PRINTER SHUT OFF.INK LEVEL LEVEL ALWAYS SHOW 100 %NO WASTE INK PAD COUNTER MORENO NEED TO WORRY WHILE PRINTING MORE PRINT JOBSnow no more ink cartiledge not recognise problem
Posted on Jun 19, 2011
  • 8 Answers
SOURCE: My Epson L100 displayed messages
There is free reset utility. It can reset ink levels in L100 and l200 printers free. And there is waste ink counter reset function also. you can easy find this utility it is WIC Reset Utility
Posted on Nov 04, 2011
Printer's ink pads are nearing the end of their service life.
The printer's ink pads are nearing the end of their service life. Please contact Epson support.
Dec 04, 2012 | Epson Stylus Photo RX700 All-In-One InkJet...
My Epson t13 are having a Service reuire error
espon T13 printer problem is service required has come how can I solved this problem help
Feb 05, 2012 | Epson Office Equipment & Supplies
The printer's ink pads are at the end of their service life. Please contact Epson support.
Nov 30, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Espon T 11 has "Service
Usually when you receive this error its either the waste ink pads,has already to much ink on it where the inks go to when you clean the printhead.
Try going in this site http://inkjetprinterhelp.us/epsonSSC.html and download the SSC service utility. then reset all the counters. After that the printer will be working fine, but there is a possibility that the excess ink will leak out on your printer. Hope this would help
May 19, 2011 | Office Equipment & Supplies
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
I have epson TX110 printer. The printer not function and says " The printer's ink pad are at the end of their service life". How to fix the problem? Thanks.
-Roy Paulo
Sep 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Thanks, Joe
Dec 27, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson photo r300
Turn Off the printer and Hold Down The stop, Maintenance (Ink/Jam) and the Power Buttons For 10 Seconds and the printer will come on and say " Finished Turn printer power off " press power button and then press it a gain it should fix it
Goodluck
May 28, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Artisan 800 All-In-One InkJet Printer Logo
122 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
