Replace wireless card - Computers & Internet
  • grant710
    grant710 Jan 18, 2013
    Samsung Q439 (UK02)
  • grant710
    Sorry, its Q430 (UK02) not Q439
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 51 Answers
What is your laptop model ?
Posted on Jan 18, 2013
  • 2 more comments
  • grant710
    Samsung Q430 (UK02)
  • baha_emtb Jan 18, 2013
    try this link you can find the manual for Q430-JS03 its the same design and you can find steps to change hardware good luck http://www.samsung.com/us/support/owners...
    i have another solution if changing your wirless card is hard you can buy a mini wirless adapter like that onehttp://ecx.images-amazon.com/images/I/31...
  • grant710
    grant710 Jan 20, 2013
    Thanks for your tips, much appreciated GH
How to replace the wireless card
The wireless card is located at the back portion of your laptop.
Read the manual of your laptop - locate the portion that indicate your WIRELESS NIC
Use a screwdriver to remove the screw.
Then gently press the locks on each side of the card
slowly remove the card
Replace the card and put back the screw
Thanks. Cheers!
Apr 21, 2010 | Acer Aspire 9300 Notebook
I cannot connect to my wireless because I was told that my wireless card went bad. What is the next step to get this corrected
how does an internal wireless card "go bad"? unless you got it wet and it short-circuited... but you should really be able to just download the broadcom driver and then the wireless driver. don't rate me on this, but i don't think it's your card, but rather your router. my router has been sucking teabags lately.
Oct 11, 2009 | Dell Inspiron 6000 Notebook
Wireless connection wont work
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | HP Compaq Presario 2200 Notebook
Laptop states wireless adapter not installed and configured? worked before.
Oct 11, 2009 | Gateway (802.11usb) Wireless Adapter
Need info on replacing zapped T41 modem with new card. Is this a simple switch? Or do I need to call in the Mod Squad? Len
I'm not sure what you mean by the T41 modem. If you mean the phone modem the it cannot be replaced because it is part of the motherboard.
If you mean the wireless card, then this can be easily replaced. To access this wireless card, remove the ketboard. There are four screws securing the keyboard and these are labeled with a keyboard symbol. After removing the screws the keyboard can be lifted up. The wireless card is located towards the top LH corner of the laptop and is held in place with screws, it also has two wires (for the wireless aerial) attached to the wireless card.
Aug 13, 2009 | IBM ThinkPad T41 Notebook
Can I upgrade the wireless card in a Gateway MX6454?
What you can do here is to get a new wireless card for your computer , you can get those new wireless card now in the market which uses the N standard already, You can check them from this manufacturer Linksys, Netgear, Belkin and Dlink....
May 29, 2009 | Computers & Internet
Gateway MT6705 wireless card will not light
You would need to replace the wireless card. It sounds the light is broken in the device. Send it back to exchange for a new one.
Aug 30, 2017 | Gateway M-6755 Notebook
Fujitsu P1510 wireless card replacement
Some laptops have a modem or wireless card that clip onto the motherboard like how the RAM is fitted to the motherboard. This card is larger than the RAM and may have one or two wires connected to this card. If so you will be able to replace this card.
If the wireless is a chip and is mounted on the motherboard then it would be impossible to replace.
Your only solution to this problem is to buy a PCMCIA wireless card and insert into the laptop's PCMCIA slot or use a USB wireless device. You may have to go into the BIOS and disable the internal wireless device.
Nov 25, 2008 | Computers & Internet
Wireless card w 9242 - where is it in the 5100 Insperion???
On the Inspiron 5100, the wireless card can be accessed thru a door on the bottom of the laptop.
1) Remove AC power and Battery
2) Turn the computer over, loosen the captive screw (labeled "circle C") in the modem/Mini PCI card cover, and lift the cover away from the computer.
3) Disconnect the Wireless card from the attached cables. These are the Antenna wires.
4) Use your fingertips to carefully spread apart the securing taps on each side of the Wireless card until the card pops up.
5) Remove the Wireless card.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 29, 2008 | Dell Inspiron 5100 Wireless Mini-pci...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
