Schematics for atx power supply
Also on pcb the reference is Wan Nien 101V0
  • artur ribeiro Jan 21, 2013
    the exact Hi Pro reference is HP-D2537F3P LF
SOURCE: how do I replace atx power supply?
yo dawg just do like buy a new connector and stuff you know what i mean dawg
Posted on May 09, 2008
  • 53 Answers
SOURCE: Upgrade for Bestec ATX-1956D (HP p/n: 0950-4106)
How about the LC Power LC350M Micro ATX - 380 Watt
or the
Logisys 350W Micro ATX
They should fit your form factor and output as much as 350W being relatively cheap, but neither gets 18 amps on 12V rail...
I think no power supply of that size has an output like that...think about a cheap but substancial chassis upgrade if you need that power...Have a look at directron for the PSUs.
Posted on Feb 13, 2009
lqv77
  • 6 Answers
SOURCE: i need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Posted on Sep 07, 2009
JaxPlanet
  • 921 Answers
SOURCE: Dell ATX(12v) power supply
The fact that it is made by Dell is irrelivent.
ATX is a standard and so are 20 and 24 pin motheroboard connectors.
You should find what you need by searching for: power supply unit on Wikipedia and Google.
Posted on Apr 08, 2010
  • 11800 Answers
SOURCE: computer has bestec atx-300-12e power supply. it
Actually no, the power does continually comes in but, when stopped, the PS is in a state that could be assimilated to stand-by - only a small side circuit is continually operational.
Posted on Jun 23, 2010
What is sg7006 and how does it function in a sharp dpa-286ap power supply
You need to tell us where you are seeing that reference. Is it on a schematic or PCB? If it is on a PCB can you send a pic of it with a mark showing where it is.
Jul 16, 2017 | Sharp Televison & Video
Apr 08, 2010 | Dell 200W ATX Power Supply GX1 - GX110...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
I need datasheet for AT2005 IC
Datasheet here:
Jan 30, 2009 | OEM Systems ATX P4 350 Watts Power Supply...
I just need a schematic for the ATXpower250 power supply.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm#atx-psu-pinouts
Jan 20, 2009 | StarTech.com (ATXPOWER250) 250-Watt Power...
Thermal resister need a replacement for thr1fwstansbury@mchsi,com
THR1 is reference designator for the component on the PCB. What is the marking on the component. THR1 is a thermo resistor and is probably a TO-237 outline package. On the black tab part of the device it should have a marking like R100 or PCT with a symbol to represent the manufacture.
Nov 30, 2008 | Diablotek / APower / 420-Watt / Micro-ATX...
Schematic diagram for ATX-250-12E
I repair power supplies and various electroics, most cases it will be compacitors, or diodes which have caused it to fail!!
Jul 29, 2008 | Bestec (ATX-250-12E) 250-Watt Power Supply
Busted component
Getting a schematic is rather doubtful. You might be able to get a general idea of the circuit from somewhere on the 'net.
Was the power supply dead?
ATX style power supplies have both a standby and main section. The standby supplies a low current +5 volts to a small portion of the motherboard.
If the component failure is in this section, this standby voltage will be missing or incorrect, and the computer will be dead- won't power on at all.
I've seen a number of catastrophic failures in this standby circuit, and repair isn't suggested or economically feasible, especially as some parts often poof beyond identification.
When the pwr button is pushed, the main section comes on, and supplies +5 (Red wires), +12 (Yellow wires), +3.3 (Orange wires), -5, -12. Look here for this info http://pinouts.ru/Power/atx_v2_pinout.shtml
Voltages are precisely regulated, and any substantial deviation (more than a few 10ths of a volt) indicate a problem, especially on the +5 & +3.3 lines.
Jul 07, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
POWER SUPPLY
ATX PSU are enabled by a signal on the green wire pin 16.
Shorting of pin 16 to ground (0VDC) will enable the PSU
Refer HERE
Also refer HERE for the 20 PIN ATX
Jul 01, 2008 | Intel (ATX350P4) 350-Watt Power Supply
Computers & Internet Logo
1,159 people viewed this question
David Payne
David Payne
