Question about Xerox Sharp Ar 168d Digital Imager Laser Printer/copier/scanner-6319 Pages Copied
WHAT IS THE SOLUTION FOR sharp AR-168D laser digital copier with system error H4-00
  • MOSES ADDAE Jan 18, 2013
What's your problem?
Replace the Laser unit.... Good Luck
Jun 08, 2012 | Sharp AR-168D Black and White Copier
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
How do you clear the error message on a AR-168D?
We inject the cartridge int he printer it gives the message on AR-168S
Apr 07, 2011 | Sharp AR-168D Black and White Copier
What does E7 error means?
That is normally a problem with the laser. I would think what is called the polygon motor has failed. That is the motor that spins the mirrors in the laser.
You can replace the motor or the laser. It is possible that the laser is not putting out a beam . But most of the time that motor fails.
Aug 09, 2010 | Sharp AR-168D Copier
Error code F2-04 and E7-10 on AR-168D
F2-04 is an improper cartridge code and the E7-10 is a shading/lamp brightness issue. I would say the F2-04 is causing both coded, Change the toner cartridge. I have seen those chips on the back of the cartridges cause weird problems. That or the developer unit has failed.
I strongly suspest that once you resolve the F2 issue the E7 will simply go away.
Aug 03, 2010 | Sharp AR-168D Copier
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
My SHARP AR-168D is not recognizing a new toner cartridge.
Make sure what you've got is Sharp's AR168NT and not AR152NT. Sharp mades changes about a year ago to their toner and the chip on an AR152NT will not work with an AR-168D model.
Aug 18, 2009 | Sharp AR-168D Black and White Copier
Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
Apr 09, 2009 | Sharp AR-168D Black and White Copier
Error on Sharp AR-168D Copier
The manual says to turn off and unplug the machine and wait for 10 seconds. Then plug it back in and turn it on. If this doesn't get rid of the problem contact your sharp dealer/service man.
Jan 12, 2009 | Sharp AR-168D Copier
Xerox Sharp Ar 168d Digital Imager Laser Printer/copier/scanner-6319 Pages Copied Logo
32 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
