Question about Samsung Wireless Receiver Module Swa-4100 No Tx Card Includes Rear Speakers
Trying to bypass module for wwireless speakers.. Is there a code??
I want to use wires instead of wireless module,, is there a code to take the module out of the system.. swa-5000
    Genius:
  • Samsung Master
  • 1,054 Answers
No. If the system came with the wireless rear amp, then it will not work without it.
Posted on Jan 18, 2013
4 Suggested Answers
SOURCE: Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
Posted on Nov 09, 2008
SOURCE: SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit 2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc. 3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash. 4.) Point the system's remote control at the Head Unit and punch in 0135.  Its light should turn from red to blue. 5.) Perform step 3 again. 6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
Posted on Apr 30, 2009
SOURCE: SWA-4000 Sound Interference Problem
i also have this problem not when watching dvds but when watching cable tv. would like to no what the problem is
Posted on Aug 09, 2010
My 2011 ram big horn 4x4 automatic indicator won't go to drive function. Goes to 4.engine light scans a po882 and po883 code. Tipm problem reset to fix?
codes refer to transmission control module problems === causes wiring --poor connections ---short to ground -- wiring short to positive - TCM
check the condition of the wires at the box and the connections for loose, water and corrosion , then replace the TCM unit
Sep 10, 2016 | Dodge Ram Cars & Trucks
How do I remove alarm brain box from wiring on a
"I bypassed the immobilizer circuit only on my alarm module (which is really tedious). Bypassing the whole
module is possible (and little easier), but you will lose the use of the remotes and the ability to arm the alarm.
The alarm module in my '97 900 SETC is located under the carpet, below the driver's power seat switches (a
pain to get at).
If you want to bypass the module completely:
1. Disconnect the battery (make sure you know the radio code-if needed)
2. Unplug the connector from alarm module and remove module from car
3. Install a wire jumper between pin 8 and pin 20 in the connector
4. Install a wire jumper between pin 9 and pin 21 in the connector
5. Install a wire jumper between pin 10 and pin 22 in the connector
6. Wrap securely with electrical tape
If you want to bypass the immobilizer circuit only:
2. Unplug the connector from the alarm module
3. Cut the following wires from the back of the connector and splice together as follows (Don't cut the wires too
close to the connector, because someday down the road you may want install a new module, so you'll have to
reverse this process):
4. Cut the wires to pin 8 and pin 20 and splice together w/ wire nut
5. Cut the wires to pin 9 and pin 21 and splice together w/ wire nut
6. Cut the wires to pin 10 and pin 22 and splice together w/ wire nut
7. Secure all with electrical tape
8. Reconnect the connector to the module
Not knowing the details of your problem, please be aware that this may, or may not, solve it. Good luck and let
me know how you make out."
Oct 02, 2014 | 1997 Saab 900
How can i watch movies with car in motion
Hi, what you will need is a video bypass module
ALL ECLIPSE VIDEO NAVIGATION UNITS AUTOMATIC PARKING BRAKE BYPASS HACK...
I wouldn't really reccommend it, though, as the inability to watch videos while the car is moving is a safety feature built in your stereo for a reason.
Jul 23, 2014 | Eclipse AVN5435 Car DVD Player
What is the passcode for the anti theft system
his vehicle has a the PASSLOCK II key
based engine disabling system.
You can attempt to put the key in the ignition,
turn it on to just before cranking and then leaving
it that way for 10 mins. After that,
some PASSLOCK systems will re learn the code
and allow for starting. But if not, the system
will either need to be seen by GM or, a bypass module
is required to circumvent.
If left unchecked, it will continue to lock down
the fuel injector rail, and you will need to tow
it in to GM for evaluation, and resetting anyway.
Bothersome, but can be fixed.
I suggest the PLJX bypass kit to get around
this issue. www.PASSLOCK2.com
This Passlock Bypass Module is designed to momentarilly
allow the engine to remote start by sending a proper
coded pulse to open the fuel rail passlock injector
cut off circuit.
The output from an alarm/remote starter
would then shut down the pulse, once it has detected
the engine has engaged, and preserve the integrity
of the passlock system.
That is it's designed purpose.
However, in your case, this input wire on the PLJX module,
instead of going to a momentary ground pulse from
an alarm/remote starter,
would go to a constant chassis ground, through
the bypass module, grounding out the PASSLOCK.
The PASSLOCK would then always be bypassed as long
as that wire is chassis grounded.
I can not speak about a damaged passlock system,
like if a thief has destroyed it, because I do not
get into this part of GM'S security application.
But as a happy coincidence to installing
after market remote starters, this does work on bypassing
passlock in most all GM vehicles we've run into,
including your year GM vehicle as well.
Also, this is a self learning, resistor sensing
and adjusting module. Once the VATS wires have been tapped,
you would press the program button to learn,
and it does. The car should then allow start
with any hardware store key.
It would on yours as well.
You might want a car alarm installer to do this
for you, the fair rate being around 50. to 75.
for labor.
Jan 26, 2011 | 1999 Chevrolet Malibu
I am trying to connect wireless speakers to my tv, but if I turn the speakers off to the tv, the wire;ess ones dont work.Any solutions? Thanks!
You should do the following if the TV Audio set up will let you:
1) Turn the speakers TV OFF.
2) Set the Audio line out to 'VARIABLE' instead of 'FIXED' level.
3) Use the RCA jacks Audio line out to feed your wireless speakers line level input jacks.
4) Set the wireless speaker volume to be about half way up and use your TV rempte to control the sound level feeding the wireless speakers.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 25, 2010 | Vizio VX240M TV
What is code 42 for a pontiac 6000 and what do i do to fix it
. This is a common code that is often difficult to diagnose and scan tools can't help. The following understanding of how the electronic spark timing (EST) system works - what is taking place and why - is a big step toward a quicker and easier diagnosis of this circuit. When the engine is turning over, but below the run threshold of 400 RPM, the ECM holds the module's bypass voltage too low (0 volts) to energize its solid-state switch (ignition module). Another way of looking at the solid-state switch is to think of it as a relay. When voltage is applied, the relay is energized. With no voltage applied, the relay is de-energized. The pick-up coil/crank sensor pulses are amplified and shaped by the ignition module. These pulses are used to complete the circuit creating a magnetic field in the ignition coils primary winding that, when collapsing, will induce a high voltage in the secondary winding. Therefore, for every crank sensor/pick-up pulse, the coil is triggered. This is known as the bypass mode or module mode of operation. In this mode, the engine is running on the timing advance that is built into the ignition module. With the voltage low on the bypass wire, the EST is pulled to ground through a resistor in the ignition module. This keeps the voltage on the EST wire at around 300 mV. When the ECM sees the RPM over the run threshold, it will then apply 5 volts to the bypass wire that will activate the solid-state switch (relay). This in turn will switch the EST from ground to the base of the transistor that controls the primary coil. In this mode, the primary coil winding is being triggered by the altered signal sent out from the ECM. The ECM will alter the signal to the ignition module and control the timing based on the inputs from various sensors. This is referred to as the EST mode. This is how the system is designed to work! Now let's look at some of the things that can cause problems and set a Code 42. Under 400 RPM, no voltage on the bypass wire, the ECM expects to see low voltage (300 mV) on the EST line during this condition. If it sees 0 volts, indicating an open in the EST circuit - or higher than 500 mV - it sets a Code 42 and stays in the bypass mode. If the bypass line is open, or grounded, the ignition module will not switch to the EST mode. The ignition module needs the bypass voltage to activate the solid-state switch so the EST voltage will be low over 400 RPM and a Code 42 will set. If the EST line is grounded, the ignition module will switch to the EST - but because the line is grounded, there will be no EST signal. A Code 42 will set. To check the ignition module to see if the solid-state switch is capable of switching when the 5 volts are applied, the engine should not be running and the ECM connectors should be disconnected. An ohm meter and test light can be used. With the ohm meter on the EST circuit, it should read less that 500 ohms (in some cases, a lot less). Using a test light to battery voltage, probe the bypass wire. With this voltage applied to the bypass wire, the solid-state switch inside the ignition module should switch and the ohm meter on the EST circuit should go over 5,000 ohms. There is also another way to check this with the engine running: by removing the bypass and the EST wire from the module or ECM, run a jumper from the reference wire to the EST circuit. The reference signal is the signal that is used in the bypass mode to trigger the primary coil voltage. Apply 5 volts from one of the 5-volt reference circuits or a test light to battery voltage. This voltage on the bypass wire will activate the solid-state switch, in turn switching the module. On some models, the 5 volts or test light will have to be applied before starting or the motor will stall when the voltage is applied to the bypass. If the module is switching OK, the car will continue to run on the reference signal. If it stalls, the ignition module is not switching properly. There are some other checks that can be made when working with an intermittent Code 42. When using a digital volt ohm meter (DVOM), there should be 5 volts on the bypass wire. On the EST wire, with the engine running, there will be close to 2.3 volts. The EST is a 5 volt on/off digital signal, so with a volt meter you will see the average of the high and the low. With the EST signal being a digital on/off signal, if you have a meter that will read in Hz, you can also pick up a Hz reading on the EST wire. Normally, you will see about 28 Hz with the engine idling and will increase with RPM. If the EST circuit would become momentarily grounded, or open, the engine will cut out. The voltage reading will jump down to as low as 1.3 volts and the Hz reading will jump from as low as 17 to 128 Hz. If there is a problem in the EST circuit, the voltage on the bypass wire will not change. If the bypass wire is momentarily grounded or open, the reading on the EST wire will be the same as if it was grounding or going open, but unlike a problem on the EST circuit, the bypass voltage will be pulled low if it becomes grounded or goes open. If this happens fast enough, the engine will cut out. The voltages will vary, but the SES light will not come on and no codes will be set. With the EST circuit open, engine running, the voltage will stay low on the bypass wire and the ECM will not put out the 5 volts. With the EST shorted to ground, the voltage on the bypass wire will be high (5 volts) for a very short time (three seconds or less) then the ECM will remove the 5 volts. Using a min/max on the DVOM is the best way to see this voltage. With the bypass open, the EST circuit OK, the ECM will put out the 5 volts. By using a DVOM on both the EST and bypass wire, you can tap on the ECM, wiggle and tug on the wiring to see if the voltage or Hz reading will change. If it does, this is an indication that you have located the problem area.
Mar 17, 2010 | 1987 Pontiac 6000
Hook up wireless speakers
I'm assuming the wireless speakers you have utilize an RCA jack to connect to the receiver.
Solution:
The good news is yes, you can use them on your receiver. The bad news is that the only output on your receiver is "VIDEO OUT" so whatever you want to watch or hear on the wireless speakers must be connected to the "VIDEO INPUT".
If the wireless speaker module uses speaker wire to connect to a receiver you will simply tap into the surround thumb clip speaker jacks.
I will add that wireless speakers tend to be disappointing when used in home theater.
Mar 24, 2009 | Sony STR-DE475 Receiver
Looking for model number of wireless rear syst. for Sony STR-DE91
If you can't find the model number, which is on the speakers, I suggest browsing the esupport pages at Sony Style where you can see pictures of the "Wireless Audio Systems" in "Option 2" to find your product. They only have 11 products listed under the Wireless Audio Systems; you can bypass the "Series" definition and select the "Model" instead.
Nov 28, 2008 | Sony STR-DE915
Brookstone Wireless Rechargeable Speakers with auto-tuning
its probably the interference with the routers. try getting internet by bypassing the router. much easier sound quality.
Jun 12, 2008 | Brookstone Outdoor Wireless Speaker...
Bypass code
What you need is a video bypass module and you can get it at ebay.com
The module number is TR-7
Jan 26, 2008 | Car Audio & Video
Samsung Wireless Receiver Module Swa-4100 No Tx Card Includes Rear Speakers Logo
216 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
